irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Wed May 27, 2015 10:19 am Post subject: Gas In Crankcase |
I just bought a 65 VW and it has some gas in the oil. I tried search but haven't been able to find what the causes might be, any help appreciated. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed May 27, 2015 10:31 am Post subject: |
Fuel pump diaphragm is leaking? If so, replace the fuel pump. Or the fuel pump may be pushing way too much pressure. If so, do a pressure check to see if you're at 2.5 to 3 lbs.
Carburetor float is leaking, or the inlet valve is weak. If so, take the carburetor apart and check.
Someone did a recent compression check and kept yanking on the throttle arm like it was a slot machine while doing the test and pumping a lot of fuel into engine (not likelly, but possible).
Tim _________________ Let's do the Time Warp again!
Richard O'Brien
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed May 27, 2015 10:32 am Post subject: |
The fuel pump is the likely culprit. The diaphragm tears and lets fuel travel into the crankcase.
Replace the fuel pump and change the oil before you run the engine again. |
Danwvw Samba Member
Posted: Wed May 27, 2015 10:53 am Post subject: |
My 1967 would do that but only when it was really cold out. I think they can suck the fuel up the emulsion tube inside the Solex Carb when the choke is fully closed. The only real solution I found was to make sure all the stock air-cleaner and pre-heat was in place and when it was below zero to only fill the gas tank 1/2 full and to make sure the engine was warmed up a little before driving it. But still sometimes it would happen. But yeah, I would also check the float in the carb it could be bad and of course the fuel pump diaphragm. Change the oil every time it happens too. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed May 27, 2015 2:36 pm Post subject: |
There's a ton of info on the previous 23 threads- search "fuel in oil" _________________
EverettB wrote: |
FU#5 |
grandpa pete Samba Member
irvanm Samba Member
Posted: Wed May 27, 2015 4:45 pm Post subject: |
Thanks, I don't know if this tie holding the choke lever might be related? I looked in a catalog for fuel pumps and they show for 66 up, I don't know if mine is right or not. |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Wed May 27, 2015 5:12 pm Post subject: |
Could it be that you are running at constant fast idle with the cam tied in that position and this would cause flooding and gas in the crankcase? _________________ '65 Sunroof Bug |
Danwvw Samba Member
Posted: Thu May 28, 2015 9:01 am Post subject: |
irvanm wrote: |
Yes! That's probably the problem. looks like it's fully choked all the time! The heater element must be burn out or the element is not hooked to the choke inside and they (Previous Owner) were just doing that to get it to start. Pull the electric choke apart and see what's going on. Also check that the electric choke is getting warm. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Thu May 28, 2015 9:47 am Post subject: |
Search the "fuel in oil" threads and you will find some mention of rebuild (diaphragm) kits for your pump. The choke problem is almost surely unrelated. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu May 28, 2015 10:06 am Post subject: |
Why do you think having the choke rigged so it stays on all the time would not have anything to do with gas in the oil? Please explain your reasoning with us so we can all learn something new today. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu May 28, 2015 10:54 am Post subject: |
irvanm wrote: |
Thanks, I don't know if this tie holding the choke lever might be related? |
Jaysus Christ! _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Thu May 28, 2015 11:00 am Post subject: |
Gas in the oil has many possible causes:
1) leaking fuel pump diaphragm
2) fuel pump pressure too high, overpowering carb needle valve
3) faulty carb needle valve or float
4) excessively rich mixture.
Before you go looking into the hard stuff, fix the stupid easy stuff. Having the choke zip-tied on all the time is definitely stupid and definitely easy to fix.
With full choke on all the time you will be getting an excessively rich mixture. Some of that extra fuel will not vaporize or will condense in the intake, will wash the oil off your cylinder walls, will get past the rings, and get into the crankcase and mix with the oil. So fix that first.
Then find the guy who put that zip-tie on and punch him in the face. _________________ 1965 Volkswagen 1500 Variant S
Posted: Thu May 28, 2015 11:11 am Post subject: |
60ragtop wrote: |
Why do you think having the choke rigged so it stays on all the time would not have anything to do with gas in the oil? Please explain your reasoning with us so we can all learn something new today. |
The only way fuel could enter the crankcase via the carb is if raw fuel made it down the manifold, into the head and past the rings. He'd have much bigger problems if that were the case. The position of the choke has no bearing.
The diaphragm in that fuel pump is quite obviously the wrong one indicating it has been rebuilt at some point and poorly done. Fuel is leaking past the diaphragm down the base, past the fuel pump rod, and into the case with each pump.
You may be able to see gas moving down the base if you take the inspection cover off. Pull the pump off and rebuild it or swap it with a known good one. Change your oil and go.
Also looking at the base of the fuel pump, the pivot pin looks dangerously close to working its way out. Fix that too. |
Danwvw Samba Member
Posted: Thu May 28, 2015 12:52 pm Post subject: |
nlorntson"The only way fuel could enter the crankcase via the carb is if raw fuel made it down the manifold, into the head and past the rings. He'd have much bigger problems if that were the case"
And this is exactly what is happening or did happen. There is plenty of manifold vacuum to suck pure fuel into the engine and it will run that way until it warms up and floods. If the car is started and driven that way a block or two it would probably have a quart of gas in the oil after that. If you catch it it probably won't hurt the engine though. It's amazing how much gas in the oil they will take. Mine got so bad that it would not rev up. The Mix of oil and gas will just splash out. It's got to be pretty cold out for this to happen though. But tying that choke closed like that it would at least pump gas into the oil when cranking the engine over even if it was too rich to start.
I see something missing in this photo:
irvanm Samba Member
Posted: Thu May 28, 2015 4:12 pm Post subject: |
is it the missing hose from the air cleaner to the tin or is it something else, if something else I would appreciate knowing what. Thanks |
Posted: Thu May 28, 2015 4:23 pm Post subject: |
The missing hose is the pre heat tube. WW sells them. It goes from the oil bath cleaner, through the hole in the tin, and connects to a pre heat pipe/tube attached to the engine. Here's a picture of the pipe not attached to the car. Yours may be missing....they often are, but you should be able to locate one if it is.
Posted: Thu May 28, 2015 4:27 pm Post subject: |
Danwvw wrote: |
The plug for the choke pull off is missing which is likely why the choke won't work and is being held open.
Still not the reason for fuel in crankcase. |
Posted: Thu May 28, 2015 4:33 pm Post subject: |
And here's a picture of the pre-heat tube connection on my '65......
Posted: Thu May 28, 2015 5:25 pm Post subject: |
nlorntson wrote: |
It most assuredly adds to the problem of raw gas in the oil as the picture shows the choke being partially closed not fully opened
Drive your bug around with the choke closed like that for awhile and report back _________________ Rick
tasb wrote: |
sb001 wrote: |
