blues412002 Samba Member
Joined: March 07, 2002 Posts: 79 Location: Parkville, MO
Posted: Sun Apr 08, 2007 5:01 am Post subject: SWF red tip turn signal switch |
Anybody out there familiar with how to wire this type switch for semaphores? The wiring diagram that came with it (auf Deutsch) was intended for blinkers, as each diagram shows the blinker relay in the mix. I know someone is going to ask to see the diagram, but I don't have a scanner to get it on my computer. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sun Apr 08, 2007 8:49 am Post subject: |
Are you trying to wire it for use on semaphores? If so, then you'll only need 3 wires. Which switch do you have? There were several different styles. Is the Red tip pointed or domed? |
lee70airbug Samba Member
Joined: May 01, 2006 Posts: 464 Location: Devon, England
Posted: Sun Apr 08, 2007 4:12 pm Post subject: |
i have an nos one of these with instructions that i'd be happy to photo for you in the english morning if your still looking and its the right one,
let me know
ta
_________________ my ride
http://www.thesamba.com/vw/forum/viewtopic.php?t=217056
Adolfs Angels Vee Dub Club
Torbay
You laugh because were different,
We laugh because your all the same |
Posted: Sun Apr 08, 2007 5:03 pm Post subject: |
I have the SWF switch like the one our British friend from Devon pictured here so kindly. Yes, I'm trying to wire it for semaphores and i was able to make a "copy" of the wiring diagram that came with it. but I don't know how to [post a pic here... |
Posted: Mon Apr 09, 2007 3:25 am Post subject: |
ok, these are the four wiring diagrams shown on the instructions, not sure what each is for but am happy to take more detailed photos of a specific one if required mate or if everett wants some more for the archive,
hope they help
Torbay
mrfry3 Samba Member
Posted: Sun Apr 22, 2007 12:40 pm Post subject: |
Im trying to figure out the same thing. In that first picture( I think)
K is power to the red light
KO is ground
54BL is power from the BGDO
HR right semaphore
HL left semaphore
The key is what the BGDO is.
I have never seen a relay with those terminal numbers 54L,KP,15X _________________ 64 Bug |
billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Sun Apr 22, 2007 2:27 pm Post subject: |
the BGDO is the flasher relay, 54 is brake light circuit # so the relay is for a snowflake taillight type system with blinking brake lights, the rear half is for trailer connection, Anhanger, 15 is ignition and KP is the dashboard indicator light, my question is why would anyone want to use one of these things, have you test fitted it to the column yet? I have a few of these cheesy things and most appear to have a much longer than stock stalk on it which is going to hit the window winder handle when you try to roll up the window ...
use lee70airbug's top diagram and you will have to run an additional 15 ignition wire into the switch to light the switch stalk when the semiphores "UP" indicator grounds out the other end of the circuit _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
mrfry3 Samba Member
Posted: Sun Apr 22, 2007 7:55 pm Post subject: |
Will a typical 3 post flasher relay work? _________________ 64 Bug |
mrfry3 Samba Member
Posted: Tue Sep 02, 2008 8:02 am Post subject: |
Well I set it down and forgot about it till recently. I moved, unpacked my VW stuff and found it again! Well since I still could not figure it out, I had my dad look at it (Who teaches basic physics about electronics.) He figured it out in less than 5 minutes. To get the red light working, the + on the light must be to power, the ground must be connected to the two blue wires that go to speedometer blinker indicator lamp connection. When the ground is broken, the lamp goes off, when it is solid the lamp is on.
No flasher involved! _________________ 64 Bug |
VWGILLYBILLY Samba Member
Joined: September 15, 2008 Posts: 3 Location: Chesterfield, U.K
Posted: Thu Sep 15, 2011 1:29 am Post subject: |
I've been looking for this diagram for ages!
Thanks! |
Posted: Thu Sep 15, 2011 7:14 am Post subject: |
Blast from the past!!! This brings back memories..... _________________ my ride
Torbay
jtdoherty Samba Member
Posted: Tue May 12, 2015 3:15 pm Post subject: Rewiring indicator switch |
I have a stock indicator switch and wanted to replace with this. Can you please tell me if it can be done. EXPLAIN SLOWLY as Im a total novice spark.
AceHH Samba Member
Joined: April 24, 2014 Posts: 107 Location: Between Hamburg and Haiti
Posted: Tue Jun 23, 2015 7:16 am Post subject: |
Hi all,
bought on a Meeting also this Switch.
But I heard its not for VW?
And doesn't it need a Coverplate?
Thanks
oldtimercraiova Samba Member
Posted: Wed Dec 16, 2020 9:13 am Post subject: Re: SWF red tip turn signal switch |
Can be used only at Pre61 Aircooleds, or ? |
abgekruggelt Samba Member
Posted: Fri Dec 25, 2020 6:14 am Post subject: Re: SWF red tip turn signal switch |
What do you think about use in an 56' Ghia LL?
best regards,
max |
