Subaru engine Vs VW engine |
VW |
54% |
[ 13 ] |
Subaru |
45% |
[ 11 ] |
Total Votes : 24 |
Ghia Nut Samba Member
Joined: December 23, 2003 Posts: 1565 Location: B'ham Alabama
Posted: Thu Jul 02, 2015 5:06 am Post subject: |
hey if some one has figured out how to do rear mount cooling and it work, post that ish up. _________________ '59 typ1 rajay turbo
'72 Ghia rajay 1641 dual 36DRLAs, 1 3/8" SS merged header and fat boy
78" GL Vert with ej22t swap
This will likely change tomorrow to something else. |
Anthonyisawsome Samba Member
Posted: Thu Jul 02, 2015 6:05 am Post subject: |
Yes I have one hear on the samba. http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=80
I notice you also live in Arizona!
dsrtfox wrote: |
Anthony, did you do a built thread ? |
_________________ I have learned so much, but yet I still don't know anything because knowing what you don't know is showing you how much you haven't learned.
1973 Subaru powered supabeetle
(o\ l /o) 1964 Baja bug roller |
RDAY Samba Member
Posted: Thu Jul 02, 2015 8:47 am Post subject: |
Hmm so Many decisions... The car will be a meyers manx and will not be a daily driver just for pure fun I want it fast but also I don't have 10k to spend on a high powered vw engine |
Posted: Thu Jul 02, 2015 10:12 pm Post subject: |
Just remember that you might need to upgrade your trans depending on what setup you do. For now I am using the stock trans but it should hold up fine if I don't abuse it. _________________ I have learned so much, but yet I still don't know anything because knowing what you don't know is showing you how much you haven't learned.
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Thu Jul 02, 2015 11:22 pm Post subject: |
Anthonyisawsome wrote: |
Just remember that you might need to upgrade your trans depending on what setup you do. For now I am using the stock trans but it should hold up fine if I don't abuse it. |
good luck with that!! with great power comes great responsability! _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
