westfalexia Samba Member
Posted: Thu Jul 02, 2015 2:53 pm Post subject: What FI components are most likely to fail? |
Hi Sambistas,
I have a '91 vanagon and am planning some long road tripping this summer (6k miles plus). With wife dogs and kid. Van checks out fine (130k miles) by vanagon specialist, but I want to "be prepared" and make sure I have the parts I'm most likely to need. As regards the digitronic fuel injection system, I would like input on what components are most likely to fail.
I have spare O2 sensor and air mass meter, but am wondering what is most likely to go bad in an invonvenient place, so I can have the parts on hand.
If this is already covered in another topic please let me know, I searched but did not see it.
Thanks. |
Merian Samba Member
Posted: Thu Jul 02, 2015 3:19 pm Post subject: |
dunno but typically people send the injectors out for cleaning which also gets the rubber hose stubs replaced
FPR and fuel rails are popular to replace
all rubber hoses & brake hoses - so do a search on those
pump & tank
all grounds - nice pics of each one on here; relays
sounds like nearly everything, eh |
Terry Kay Banned
Posted: Thu Jul 02, 2015 3:43 pm Post subject: |
TPS.
And they are NLA.
Big miles & old age contributes to idividual FI parts to give up the ghost at the most inconvenient time.
Is there anything you can absolutely plan on?
Negative. _________________ T.K. |
Posted: Thu Jul 02, 2015 4:01 pm Post subject: |
I was looking at the replacement TPS they sell at van-cafe. Gowesty makes one too. Not too expensive, and a nice little part to have on hand...
Rubber hoses I totally agree with. I have been through them, but will have all double-checked to make sure I didn't miss replacing any (fuel lines especially). I think the injectors are in good shape, the van just sailed through its inspection with very low emissions readings. My guess is that injector performance will degrade over time leading to rich conditions, not fail suddenly. But that is just a guess.
Also just re-sealed the fuel tank. Fuel pump is original. Think I should replace it pre-emptively (along with the filter), or just carry around a spare?
And I know they are not FI components so hopefully I'm not getting too off topic, but what about replacing the water pump and oil pump?
And how about the temp sensor near the thermostat. Does that fail routinely? The temperature guage seems to read accurately as of now. I think the FI system relies on input from it too.
Thanks for the replies. |
Vanagon Nut Samba Member
Posted: Thu Jul 02, 2015 4:23 pm Post subject: |
westfalexia wrote: |
.... My guess is that injector performance will degrade over time leading to rich conditions, not fail suddenly.
The ECU uses input from coolant temp sensor on driver side of plastic thermostat housing.
The other coolant temp sensor is for the gauge. Those parts do fail but are easy to find.
You could check the water pump for play but I'd carry a new spare + seals.
Inspect belts too.
From what I've read, the OEM injectors are quite robust. But they're small.
Some other related stuff I'd carry.
VoltOhm meter, belts, (56?) relay, (fuel pump, ECU relays), ECU, ignition switch, Digifant Pro training manual, Bentley, long spark plug lead, spark plug, rotor/cap, jumper wire with spades for fuel pump relay (testing). And if there's any doubt, coolant expansion tank but a new cap at very least. Also Subaru coolant conditioner. (but then in summer heat, a failing coolant jacket gasket may not be saved by the Suby stuff).
A spare fuel pump is not a bad idea but they are also pretty robust. Did you check for dirt etc. at pump inlet screen when doing tank? _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
kamzcab86 Samba Moderator
Merian Samba Member
Posted: Thu Jul 02, 2015 5:02 pm Post subject: |
injector performance should not fail suddenly, but the stub hoses might |
jmranger Samba Member
Posted: Thu Jul 02, 2015 5:23 pm Post subject: |
Welcome to TheSamba.
I'm a bit puzzled by your question. Why are you more worried about the FI system than the remainder of your 34-years-old van?
A few thoughts - apologies if those are obvious:
- if this van is new in your fleet, the best preparation you can make is to put miles on it before the big start. Get used to how it feels, how it sounds, even how it smells. This would serve as both a shakedown of your recent repairs and a calibration of your brain to what's normal and what's not. My personal experience it that most failures will appear progressively, and can be addressed before they strand you.
- Murphy's law: whatever spare parts you bring, it's something else that'll break. Overloading the van just increases the chances that something will break.
- I'm among those that believe that the quality of many spare parts we can buy today is lower than the original parts. Too many stories of "new" parts going bad after a few 1000s miles. So I'm in favor or preventively replacing parts that are known to wear, but against overdoing it.
- If you don't already have Roadhaus and VRS in your bookmarks, now would be a good time to add them.
Have fun, and safe travels. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Jul 02, 2015 6:43 pm Post subject: |
You can carry a crazy number of parts (that's me) or just accept that you are unlikely to correctly guess what will fail.
In any case, possibly best to focus on things that could leave you stranded (such as the fuel pump) vs those that you can soldier on without (e.g. the alternator).
I buy spares of most components when the price is favorable (particularly those items that can be had used such as the ECU and AFM. Having done that I see no advantage in having them on the shelf at home while I travel, hence the collection of onboard items.
Every now and then I add something when I hear multiple reports of sudden inconvenient failures -- one example I recently added was a throttle cable. |
Terry Kay Banned
Posted: Thu Jul 02, 2015 6:46 pm Post subject: |
Here's a question for you;
How long have you owned the 91, and what have you done to it in preparation for this 6000 mile trip?
Nothing is usual, nothing can be anticipated,
nothing can be expected, other than normal wear items failing.
Bulbs, tires, belts, hoses, wiper blades, etc.
I'd have to say that the digifant hardware other than small electrical control items that can & maybe will fail, is nothing to be concerned about.
Make sure every square inch of the running gear from bumper to bumper is sound, serviced, & tighter than a drum.
You'll be fine.
Just remember, it isn't even close to a late model ride, its got 130k on the clock, and it's 24 years old.
Expect nothing, plan for anything & everything. _________________ T.K. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Thu Jul 02, 2015 8:48 pm Post subject: |
Fuel pump is original. Think I should replace it pre-emptively (along with the filter), or just carry around a spare? |
I would replace the filter if you don't know when it was changed last. I would buy a spare pump but don't change it until the original one craps out - the new one may have different wiring terminals so you might want to also get parts to modify the oiriginal wiring. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
morymob Samba Member
Posted: Fri Jul 03, 2015 5:57 am Post subject: |
In all 5, 25 yrs,norm refresh of fi sys ( hoses,filters ) all grounds etc has ended up being the very least of problems, one temp 2 plug connection ,fairly recent,that area isn't a worry of mine. Getting a flat & changing on todays hhighways is about tops.i carry norm spares, fuel filter,spare pump & water pump. Their shelf life may be a problem in time. Only other spares r ones not easily found at flaps on 1st trip there or one that is expensive, ecu,full dizzy. Some i carried 4 yrs have put back on shelf as i could limp 4awhile if needed. After awhile, & regulator maint, always before a trip keeps things operating. Forgot, had alt reg contacts stop charging, made it ok on batt. I try to remember jumpers,mainly 4 others u see stalled, my 2cts. As usual no warranty offered at this time. |
Posted: Fri Jul 03, 2015 6:05 am Post subject: |
If u suspect a temp2 sensor & have one just plug spare up, take a tie wrap & tie against rubber hose at a convient spot, u can wrap a rag around & tape it down if u like , move on, replace at your leisure, i even tested mine without the wrap, ran normally, my2cts, as usual no warranty offered at this time. |
Posted: Fri Jul 03, 2015 7:30 am Post subject: |
By the time I pulled the WBXer engine out of my '91 to do a Suby swap at around 240K miles, I had replaced the idle control valve once and been through a couple of O2 sensors. Never been into the AFM, never replaced the injectors or removed them for cleaning. It even had the original distributor cap and rotor still. Even my POS 83 1/2 has taken very little to keep the FI working fine. |
Posted: Fri Jul 03, 2015 12:36 pm Post subject: |
Wildthings wrote: |
What I've done to my injection system over 5-1/2 years, 25,000 miles:
Replaced fuel filter
Cleaned all grounds
Removed and cleaned the ISV
Removed and cleaned the MAF (it was quite gross inside)
Replaced breather tower O-ring and hose
Replaced injector seals
Replaced fuel lines
Replaced fuel rails (as preventative maintenance)
Replaced fuel pressure regulator (as preventative maintenance)
Replaced air filter
Replaced Temp II sensor (original was still good aside from the seal; just doing preventative maintenance while cooling system was drained; original tossed into van's parts box)
Replaced rubber vacuum hose connections
Replaced gas cap seal
Fuel tank/evap reseal is slated to be done in a week or two... that will be the only real major work to my '90's fuel system thus far (182,000 miles, roughly). _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Jul 03, 2015 5:20 pm Post subject: |
Wow, thank you for all the input so far! I am making a list and will post a summary of the parts that have been suggested.
In response to a couple people who wondered why I was asking about the FI system specifically - I have been over the rest of the van in some detail (suspension, brakes, cooling system - yes I replaced the long pipes - resealed the fuel tank, rebuilt the A/T with new cooler and seals), but when I stand there looking at the van the digifiant system seems to have an awful lot of components that are now twenty-odd years old.
In general I believe in the "ain't broke/don't fix" approach, and also feel like good original parts may be in many cases less apt to fail than a brand new aftermarket one. After all they have years of proven reliability. But I do like to be prepared, as much as possible. And I figure in the event of a breakdown, parts may not be so easy to come by for a '91 vanagon.
I've had the van a while and have a good knowledge of its history, but this will be the first time I trust it to take myself and family for a long trip.
and RE: jmranger - I am a firm believer in murphy's law - but also that there is a perverse rule of automotive misfortune, by which if you have a spare part handy, it will increase the odds that the original part will not fail.
Re: wildthings - on the idle control valve. I was thinking about that. If I understand the digifiant correctly the idle control valve and idle control computer (along with correctly functioning and adjusted TPS) are all necessary for the van to idle. Is the idle control valve the most likely part to fail? And if it does, is the van still driveable? It is an automatic so I can't do the 3-pedal-softshoe like I could with my old saab.
Thanks again for the input. And humoring me with this. |
Posted: Fri Jul 03, 2015 7:38 pm Post subject: |
Yes, if the idle control valve goes bad it will only effect the idle. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Fri Jul 03, 2015 8:39 pm Post subject: |
check all coolant hoses... small and big...
you may want to replace some that are not easy to do on the road (near the oil filter) ...
if everything went right but you have a coolant leak.. err... you go nowhere... |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sat Jul 04, 2015 5:27 am Post subject: |
Merian wrote: |
The plastic things that injectors feed from fail, about 5yrs ago about 70mi out i stopp, smelled gas, the short nipple on that part had cracked with gas drip onto lg metal water pipe on drivers side, hadn't got onto exhaust yet, dodged bullit by lucky stop, i replaced with metal ones from a late bay, looks a bit odd but works. Only fi parts i carry is 3ft of hose & odd sizes of clamps. I guess fuel filters parts too, a tps i consider not a critical part, goes bad unplug it, hunting idle u can live with 4 awhile. usual no warranty offered at this time.
