LeninCas Samba Member
Joined: February 05, 2013 Posts: 447 Location: Orange County, CA
Posted: Fri Jul 03, 2015 12:53 pm Post subject: For the life of me! |
I want to use this center mount fan shroud in my bug on a 1600 motor with dual baby webers. I cannot imagine the fan going behind the shroud as suggested by the way the generator mounts to the shroud. Also, how am I supposed to cover up the space between the generator and shroud?
I've never seen another shroud like this, I believe it's from the late 80's ( before I was born).
_________________ one, two, many
one too many |
JSmith Samba Member
Joined: August 18, 2005 Posts: 89 Location: Over There ->
Posted: Fri Jul 03, 2015 1:03 pm Post subject: |
You may want to start by mounting the alternator on the other side and putting the fan inside the shroud... Then later ask why your motor is running so hot.. :roll:
Sorry for the sarcasm... |
mark tucker Samba Member
Posted: Fri Jul 03, 2015 1:12 pm Post subject: |
ditto. execpt for the why is it running hot, it may or may not. |
Posted: Fri Jul 03, 2015 1:40 pm Post subject: |
Oh God.
I don't even know what to say! That NEVER occurred to me.
Thank you SO much. The sarcasm was great, I really deserved it.
I maybe should've put a little more thinking into it.
Your comment has me literally LOL.
Thanks for your comments guys. Appreciate the help. _________________ one, two, many
one too many |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Fri Jul 03, 2015 1:41 pm Post subject: |
Do you smell that?
It smells like cooked engine. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jul 03, 2015 1:44 pm Post subject: |
I don't think it will run hotter since I will have to use an external oil cooler. We will see though. _________________ one, two, many
one too many |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Fri Jul 03, 2015 1:59 pm Post subject: |
LeninCas wrote: |
I don't think it will run hotter since I will have to use an external oil cooler. We will see though. |
It will run hotter unless it is modified. There's a build on here.....Ray Valero stroker build where the car owner has one of these and had it modified. Claims that it works fine. And avout the external oil cooler....these motors are air cooled...not oil cooled. Unless that shroud is internally modified, it will run hot. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Brian71 Samba Member
Joined: January 22, 2005 Posts: 183 Location: Prineville, OR
Posted: Fri Jul 03, 2015 2:26 pm Post subject: |
Does the shroud have any directional vanes in it? |
Posted: Fri Jul 03, 2015 2:27 pm Post subject: |
I will look for that post in the forums thanks! I'd really like to use it, but only if I can get it to work well. I see in a post by Glenn that it doesn't cool well, since it doesn't have cooling vanes inside, which makes sense. Maybe I can figure out a way to make it cool properly.
@fivelugshortaxle I got the heads yesterday man! I love them, thanks so much again! _________________ one, two, many
one too many |
Posted: Fri Jul 03, 2015 2:39 pm Post subject: |
[quote="modok"]
Hebster52 wrote: |
Old thread I know...
Here's what you can do to improve the shroud...
Glenn doesn't think it will work, others do think it will work. This post was from last year, anyone have any new information on it? Did it work well? _________________ one, two, many
one too many |
LeninCas wrote: |
@fivelugshortaxle I got the heads yesterday man! I love them, thanks so much again! |
Contact the girl who owns the bad ass red car in the Valero build. She may be able to send you oictures of hiw they modified hers. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Fri Jul 03, 2015 2:41 pm Post subject: |
LeninCas wrote: |
Cool. Glad they'll work out well for your build. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Fri Jul 03, 2015 2:59 pm Post subject: |
Hebster's last design
one too many |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Fri Jul 03, 2015 4:52 pm Post subject: |
The center mount fans were for show, not go.
Not only do they not work very well, they will crack too.
Best to leave it alone. They are beautifully made, but poorly designed! |
LivinInnaVWBus Samba Member
Posted: Mon Jul 06, 2015 4:20 pm Post subject: |
Uh oh... not one of those.
Though no one can really be certain, I'd sell my first born if you could make that shroud cool as well as a stock shroud - no matter the mods you do to it.
Also, an external oil cooler does nothing to cool your heads.
You may be underestimating the cooling abilities of a stock fan shroud... take this into consideration. If you run a pair of these drag race fans ( http://www.piersideparts.net/CB2813.html which are dedicated strictly to cooling your heads) on the street, you'll cook your engine in a few miles.
I chuckled at the careful wording CIP1 uses... "Designed to provide equal airflow for uniform and increased cooling. Better cooling means more useable horsepower."
http://www2.cip1.com/ProductDetails.asp?ProductCode=C12-4521
A perfect example of just because it's designed to do something, doesn't mean it works. |
Posted: Mon Jul 06, 2015 4:27 pm Post subject: |
LeninCas wrote: |
Do you build the engines for sale in your classifieds? |
Posted: Mon Jul 06, 2015 4:36 pm Post subject: |
slant shrouds absolutely do NOT cool evenly. Why do you think the VW factory offset the fan on the stock engine, or were they stupidz? _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
64 ragtop volks Samba Member
Posted: Mon Jul 06, 2015 5:24 pm Post subject: |
i ran a old cast feuling center mount set up with a 72 plate cooler, in my ratty 13window bus. drove it from texas to lake havasu, and another trip from texas to daytona beach, and alot of trips to the texas coast. i dont run guages but i grab the dipstick at every fill up and never got it too hot. its a 1600 with 110 cam and cb o44 heads and dual kads pushing a loaded down bus with several hundred pounds of camping gear and big ass rottweiler.
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Mon Jul 06, 2015 8:25 pm Post subject: |
64 ragtop volks wrote: |
Yeah, but... but... and a filterpump? AND a big ass rottweiler? But... but... but...
But, that just can't be!
_________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
manoa Samba Member
Posted: Mon Jul 06, 2015 9:38 pm Post subject: |
Kool _________________ -----
(o\ ! /o)
