alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Fri Jul 03, 2015 7:59 pm Post subject: suby 2.5 MAF |
What does it mean when your suby only runs when you disconnect the MAF? I can fire it up and then plug in the MAF and it kills the engine. |
jmranger Samba Member
Posted: Fri Jul 03, 2015 8:40 pm Post subject: |
My guess: bad MAF or MAF wiring. Same thing as when you unplug your O2 sensor and suddenly, the van runs better. The ECU designers integrated a fail-safe mode that allows the vehicle to run (albeit non-optimally) that is triggered when the sensor isn't present - but the vehicle may not run at all when the sensor is stuck at either end of the sensing range and is providing invalid input. |
AKWesty Samba Member
Joined: April 12, 2014 Posts: 680 Location: Haines, Alaska
Posted: Fri Jul 03, 2015 11:27 pm Post subject: |
I am not positive but I am pretty sure you can bench test your MAF with a meter. Haynes or Chilton manual will have it. May just need a good cleaning. Good Luck. _________________ 84' Westy 2wd
EJ22 - 4spd - Peloquin TBD
GW +1.5 Springs
215/70-16's
www.CatchTheKraken.com
"Never go to Alaska as a young man because you'll never be satisfied with any other place as long as you live." -John Muir |
Zeitgeist 13 Samba Member
Posted: Sat Jul 04, 2015 12:50 am Post subject: |
I'm sure there's a website for these kind of off topic questions |
insyncro Banned
Posted: Sat Jul 04, 2015 2:36 am Post subject: |
Zeitgeist 13 wrote: |
Subaru Conversion Yahoo Group |
Posted: Sat Jul 04, 2015 7:01 am Post subject: |
Ok. Didnt realize talking about our various engine conversions was off topic. Ive never had good luck on the yahoo site but i will go there. |
Posted: Sat Jul 04, 2015 7:14 am Post subject: |
As usuall that !#&%? site wont let me create an account. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3099 Location: ABQ NM USA.... Except when not
Posted: Sat Jul 04, 2015 8:05 am Post subject: |
seems like the folks on the subaru yahoo groups love to talk (sometimes about the same thing over and over) which is good since the search function sux on yahoo. But I'm sure you'll get a response.
in my experience and bad or dirty MAF. when I did my transplant the MAF was in the elements for a few months while I did the conversion and then the engine didn't run well with it connected. Before I replaced it I cleaned it with this available everywhere -
http://crcindustries.com/ei/product_detail.aspx?id=05110
Also, when testing my engine I had the MAF connected but not in the intake airflow, the ECU didn't like that and the engine ran bad when connected like that and good when I disconnected the MAF.
Also, when testing my engine I had the MAF connected but not in the intake airflow, the ECU didn't like that and the engine rad when I disconnected the MAF. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Sat Jul 04, 2015 8:30 am Post subject: |
dobryan wrote: |
YAEC topics. |
Yankee Atomic Energy Company ?
http://acronyms.thefreedictionary.com/YAEC _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Sat Jul 04, 2015 8:52 am Post subject: |
Its this kinda BS that gives the samba a bad rap. If engine conversions are off topic then thesamba need some new rules. _________________ 84' Westy 2wd
GW +1.5 Springs
215/70-16's
Sodo Samba Member
Joined: July 06, 2007 Posts: 9610 Location: Western WA
Posted: Sat Jul 04, 2015 9:33 am Post subject: |
I'm interested.
OP should re-title post "Vanagon Suby 2.5 MAF". _________________
....KTMs, GasGas, SPOT mtb
insyncro Banned
Posted: Sun Jul 05, 2015 4:57 am Post subject: |
The title and question phrased have nothing to do with Vanagons, it has to do with a part of Subaru engine.
The answer will be found quickly in any Subaru forum out there.
Since it isn't running properly, what codes are being thrown by the ECU.
If the answer to this question is ?????....it won't matter what site you are on.
Who did the wiring conversion?
Yes to above, sensors can be bench tested and all wiring should be also....regardless of brand or site you are on. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sun Jul 05, 2015 5:18 am Post subject: |
Not at all an off topic question.
We deal with Vanagons, pure factory setups, Air Cooled, Diesel, and Gasoline......... be they North American fuel injected or European carburetors,
Add into this factory mix we add the vast array of power plant "upgrades" and we've got quite a spectrum!
We are even dipping our toes in TESLA transplants now!
You will however find knowledge about Subaru power plants and the various running nuances limited here seeing as many of us haven't ever touched or seen one.
The recommendation to seek out a Subaru forum makes sense, not because such a question is off topic here but rather our collective knowledge base is severely limited on Subaru engines.
In the same manner we often advise our 2.0 Air Cooled friends to visit the Type 2 Bay Window forum for their knowledge on these engines is vast compared to most members here who drive Water Cooled units.
Don't let one comment scare you away.
We are not a negative site though some seem to feel that way.
I've noticed that Other sites practice very heavy handed editing, we edit but more to keep on topic and to create a searchable data base at the same time.
Sure, heavy handed editing does make a more mellow place but it also eliminates certain individuals who have a LOT of knowledge that many /most "social" posters may not have.
There seems to be a need in some to bash place "A" to make place "B" look better. There is no need to bash, just accept that each place is different and meets ones particular needs.
And Yes, I'm on the facebook pages among others but this is home right here where the real knowledge lies.
In my personal observations.......... On any other Vanagon site or forum...... Thesamba is almost always referred to as the place to go to get the answers to life's perplexing questions.
Ghia
Vanagon
Beetle
Posted: Sun Jul 05, 2015 7:14 am Post subject: |
No problem here. I have tried to sign up on the yahoo a few times and to no avail. . The wiring is suspect at this point. I had someone do my harness who has done harnesses before and used to work for a conversion shop. I now question that decision. Though he wasvery helpfull in many ways. So now ive been looking for a wiring diagram so i can pull it out and go through it. When plugging in a scanner it just reads ERROR. . Can anyone steer me towards a wiring diagram for an 07 2.5 conversion? Thanks. |
insyncro Banned
Posted: Sun Jul 05, 2015 7:24 am Post subject: |
Error means pin test every wire and double check the work done, sounding suspect.
I hate to say it but the wiring diagrams are right in the yahoo group pages and easily downloaded.
If yahoo is not cooperating, time to start monitoring scripts on your computer browser of choice and blocking them. Done deal...surf with ease. |
Posted: Sun Jul 05, 2015 10:35 am Post subject: |
insyncro wrote: |
I hate to say it but the wiring diagrams are right in the yahoo group pages and easily downloaded. |
Newest I found (there and elsewhere) is for a Forester 2001. If you have diagrams for his 2007, I'd like them too. |
insyncro Banned
Posted: Sun Jul 05, 2015 1:26 pm Post subject: |
jmranger wrote: |
insyncro wrote: |
OK, maybe the later ones were taken down or were shared via pmails.
Years ago I grabbed many off that group, but haven't spent any time there in a while.
Call me crazy, I just buy the year and model printout from Small Car when I need them now. |
Nimbus'87 Samba Member
Joined: January 03, 2013 Posts: 125 Location: Murrieta, Ca.
Posted: Mon Jul 06, 2015 6:07 am Post subject: Subie MAF... |
Don't know if your a FaceBook user or not.
A couple of groups that might help you:
Subaru Powered Volkswagens, &
Modified Subaru Wiring Harness Community
Not FB but Shoptalkforums.com has knowledgeable peeps too.
G'luck. SS. _________________ '87 Wolfram Grey Westy. '92 2.2 Subie, KEP/Calif. Reg. |
