trickdog60 Samba Member
Joined: July 25, 2010 Posts: 44 Location: Northern Michigan
Posted: Tue Jul 28, 2015 6:28 am Post subject: gas in oil |
Can a faulty fuel pump cause gas to get into the crankcase? If so, how? Furthermore, if I need to rebuild the pump, where do you recommend sending for a rebuild kit? _________________ current: '64 convertible, all original, 30K miles
priors owned and operated since 1962....
'67 bug
'67 bus
'61 Ghia
'59 bus
'61 bug with sliding rag roof
'66 bus
'57 bug |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue Jul 28, 2015 6:30 am Post subject: Re: gas in oil |
trickdog60 wrote: |
Can a faulty fuel pump cause gas to get into the crankcase? If so, how? |
If diaphragm leaks, gas will flow down into the oil.
A carb issue can sometimes cause similar. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Jul 28, 2015 6:35 am Post subject: |
Any suggestions on where to get a rebuild kit? _________________ current: '64 convertible, all original, 30K miles
'67 bug
'67 bus
'61 Ghia
'59 bus
'66 bus
'57 bug |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Jul 28, 2015 7:04 am Post subject: |
Agreed. Searches are easy. Gaining from the experience of others is what forums are for. _________________ current: '64 convertible, all original, 30K miles
'67 bug
'67 bus
'61 Ghia
'59 bus
'66 bus
'57 bug |
Posted: Tue Jul 28, 2015 7:13 am Post subject: |
such as teaching how to use the seldom used search function for oft ask questions _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Jul 28, 2015 7:44 am Post subject: |
60ragtop wrote: |
such as teaching how to use the seldom used search function for oft ask questions |
Yeah ^
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
VOLKSWAGNUT wrote: |
Yeah ^.
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Tue Jul 28, 2015 8:16 am Post subject: |
Thank you. _________________ current: '64 convertible, all original, 30K miles
'67 bug
'67 bus
'61 Ghia
'59 bus
'66 bus
'57 bug |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
