Removing the interior light
Peter - Belgium
Peter - Belgium is offline
PostPosted: Fri Jul 31, 2015 6:41 am    Post subject: Removing the interior light Reply with quote
How do I remove the 2 interior lights from my BT6 without destroying the headliner? I tried to pull... but did not risk to pull to hard so it would break?
any special method?
Thanks!
Peter
356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight=
tallman206
tallman206 is offline
PostPosted: Fri Jul 31, 2015 11:34 am    Post subject: Reply with quote
Porsche dome lights work exactly like VW dome lights
At either end of the dome light, there are spring-loaded brass "bullet" catches that press outward against the mounting hole in the headliner. Use something flat on either end and insert it between the light and the headliner material. But pry it out carefully, as the 50+ year old clear plastic surround can be fragile. It just snaps out, and snaps back in.
Jerry Henning
St Pete FL
Jerry Henning
Southern Classic Works
St.Petersburg, Florida
1973 VW Type 181 with 616/33-6 powerplant
1962 356B-T6 Cabriolet Rustbucket
mr white
mr white is offline
PostPosted: Sat Aug 01, 2015 8:58 pm    Post subject: Reply with quote
Use some small plastic wedges on either end and be careful. Take your time. These parts are fragile!
Peter - Belgium
PostPosted: Sun Aug 02, 2015 4:53 am    Post subject: Reply with quote
Super! Thanks a lot;-)
roy mawbey
roy mawbey is offline
PostPosted: Wed Aug 05, 2015 3:41 am    Post subject: Reply with quote
That was a good question and a good clear answer! I got one out 20 years ago by luck I reckon. The other needing a new bulb ( probably 56 years old ) I could not move without damaging it I think. Now, I will try again.
thanks
Roy
Roy
RHD356A super75 106954
