veg-head Samba Member
Joined: June 17, 2014 Posts: 108 Location: Metro Detroit
Posted: Wed Jul 29, 2015 8:59 am Post subject: |
So this thing rides like ass,, I want to get some suspension, do I , add air shocks, notch the plate, or 're-index, It's on the bumpstops, what's the best way to fix without losing my lowered ride hight. |
Posted: Wed Jul 29, 2015 8:59 am Post subject: too low |
Double post? Best way to fix |
Posted: Thu Jul 30, 2015 3:52 am Post subject: |
Sorry about the double posts not sure why my phone does that. So ANYBODY a little help, I not so sure what should I do? In the back, Air shocks, 're-index or notch the plate. INPUT AND help please. |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Thu Jul 30, 2015 1:47 pm Post subject: |
have you looked in to lowering plates?
Atomwerks manufacturers lowering/raising plates that allow the suspension to work as factory but relocates the axle height.
they will keep you from notching or riding on bump stops etc.
he offers different drop heights.
fair warning before someone flames me:
I have raised plates and pleased with them. others have differing thoughts on Charles/product delivery. Not weighing on that topic. just sharing possible solution. I believe plates are in stock at least beetle. You may need to call and see if Thing plates are ready for delivery. |
Posted: Fri Jul 31, 2015 10:45 am Post subject: |
Atomwerx kit looks good, $398 comes with the plates,shocks, tool and bolts. Anyone have any experience with this kit or some good how to links, and should I get the 2" or 3" drop plates, what do you think will match up best with the bug front beam on the thing? Or are there better options to try first? |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
ernieballbass Samba Member
Joined: June 14, 2006 Posts: 191 Location: Orlando, Fl
Posted: Thu Aug 06, 2015 11:39 am Post subject: |
veg-head wrote: |
i actually just bought/installed those drop plates on my thing (well...the pan anyways). i went for the 2in drop. but if i was going to drop it super low like yours, then i would have done the 3in drop.
i just bought the plates (no kit), reused old bolts, and made my own tool out of threaded rod. i did have to cut the trailing arm a little. other than that, it was pretty easy.
atomwerks is good people. _________________ What I lack in brains, I make up for with good intentions. |
Posted: Tue Jul 28, 2020 9:17 am Post subject: Re: first thing post 74 lower thing |
Still got this thing, been sitting 5 years.
So l Just recently picked up a new/reworked stock ball joint beam.
I knew I'd never get that low stance worked out. And honestly my taste changed for the look of a stock or slightly lifted thing intereste me more. So that's what I'm going for on ride hight, stock.
Now l have the front beam and some motivation I'm gonna try and get this THING on the road.
Pointers input welcome. Happy thinging. _________________ 1972 Bus Camper :motor 74 2.0l
1974 Thing 1915 cc
Metro Detroit, Michigan |
BJT Samba Member
Posted: Tue Jul 28, 2020 2:01 pm Post subject: Re: first thing post 74 lower thing |
Good luck! I replaced the Beetle beam that was in my Thing when I bought it with a stock Thing beam, looks much better. Wasn’t a very complicated process either, getting the springs into the beam and figuring out the correct was to mount the steering box were the hardest two things I ran into. |
