Frank'nbug Samba Member
Joined: November 14, 2013 Posts: 3 Location: Beaverton, OR
Posted: Fri Nov 15, 2013 2:38 pm Post subject: Beating the Wiper Motor Wiring again |
I have a 1970 Beetle that has been Baja converted. Wiper motor went bad. I bought a replacement, says 1972 and up. Wiring does NOT match diagram. HELP |
Brian Samba Moderator
Posted: Fri Nov 15, 2013 2:41 pm Post subject: |
So you have a '70 and bought a replacement for a '72+? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
1970VWGUY Samba Member
Joined: September 15, 2013 Posts: 864 Location: Natrona Heights, PA
Posted: Fri Nov 15, 2013 9:20 pm Post subject: |
Does it mount up correctly? |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Fri Nov 15, 2013 11:34 pm Post subject: |
72 and later have a totally different wiring layout as they are designed for the steering column stalk style switch not the dash switch.
High and low speed wire up as normal but the self parking can't be wired up without adding a relay and altering the wiring. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Sun Nov 17, 2013 10:42 pm Post subject: |
The original motor was small with one mounting bolt. I salvaged a newer bracket out of a '71. It bolts up correctly and everything looks correct. I am just trying to get the wiring to work. I had one motor (new), hooked it up like the wiring said to do and shorted out the motor, frying the black wire and almost causing a fire. Melted several wires. Returned the motor and now it says for '72 and up. It has four wires (black, green, blue, red) in a terminal and a brown loose. Any help would be great. Last thing to get completed to get it (Baja) on the road. |
Posted: Sun Nov 17, 2013 11:56 pm Post subject: |
Are there any numbers where the wires come out? |
don't_bug_me Samba Member
Posted: Mon Nov 18, 2013 5:48 am Post subject: |
Frank'nbug wrote: |
That motor isn't from a bug, any year that I can find, wrong wiring colors, Like Joel said, later wiper motors require a relay, latching relay I believe to function properly, I believe they are wired internally different.
You may still be able to use it, but not sure if the parking wiper mechanism can be used properly without a lot of additional mods to your electrical system with the fore mentioned relays, but, test the wiring on the motor prior to installation, some color coding should remain the same, such as, brown is ground, black will be your main power to the motor, not positive now on the remaining 3, green is most likely the latching wire circuit for later model vw's, the other two switch the motors input from low to high speed.
Get some wires and test first, once you figure out which wires do what, you might be able to hook them up to your 70 wiring, but again, if it is wired internally different, you may have to park it manually by shutting them off in the lowered position, I'd get an older wiper motor and have it done right, but experiment with what you have off the car, as not to cause additional electrical problems.
edit;
in fact, I just checked the wiring colors from everything from of vw type 1 to a thing, and no wiper motor colors match to that one any year.
it's aftermarket or who knows what it's from. _________________ 70 Street Baja http://www.thesamba.com/vw/forum/viewtopic.php?t=566113
"Necessity is the mother of invention" |
Posted: Wed Nov 20, 2013 7:50 pm Post subject: |
Well to put this to bed. I have spent the last three evenings after work at the parts store working the store manager to figure out the wiring for the wiper motors they sell for '70 and '72 & up beetle.
The first night he hooked the later model ('70) up like the wiring diagram shows and it fried the motor just like the first one that I had.
So, the second night he hooked up the '72 motor, got it to work, but not self park. No problem.
The third night, he hooked up another later model motor and couldn't get it to turn at all. (really tight, even with a rachet)
So, three nights, still no wiper motor. STILL NOTHING!!!!!!!!!!!!! Trying to get another motor - might have to use the small "loaf" size later model instead.
Thanks for the discussion.
Frank'nbug
1970 Baja |
Posted: Thu Nov 21, 2013 4:07 am Post subject: |
Frank'nbug wrote: |
1) The first night he hooked the later model ('70) up like the wiring diagram shows and it fried the motor just like the first one that I had.
2) So, the second night he hooked up the '72 motor, got it to work, but not self park. No problem.
3) The third night, he hooked up another later model motor and couldn't get it to turn at all. (really tight, even with a rachet)
Frank'nbug
1970 Baja |
Sounds like either your extremely frustrated, or don't want any additional help...
1) sounds like you have some wiring issues, I'd double check everything before you continue burning up wiper motors, may have been why the first one failed, especially look into the switch.
2) exactly as I and Joel said
3) moot point
If you don't wish any ADDITIONAL HELP....GOOD LUCK _________________ 70 Street Baja http://www.thesamba.com/vw/forum/viewtopic.php?t=566113
Posted: Thu Nov 21, 2013 7:05 am Post subject: |
What's the original part number for that motor.... |
mbjeeper Samba Member
Posted: Mon Jul 14, 2014 5:40 am Post subject: |
I have a similar problem. I am working on a car that someone has installed a later model (appears to be '72 up standard Beetle) into a 1965, which has been converted to 12 volts, and appears to be using a '67 wiper switch.
Both speeds work fine, but, alas, no park feature. He would like to have the wipers park where they should.
I have read in my searches that it can be done with some wiring changes and possibly the addition of a relay, but I haven't seen how this can be accomplished.
This is one of the last issues on this car and I'd like to get it straightened out so he can have his car back while there is still some summer left.
Any and all help appreciated...
Greg |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Mon Jul 14, 2014 11:28 am Post subject: |
The problem with the self park system, up thru 1971, the switch was grounded and provided a ground path for the self park system. This ground was dropped for the redesigned wiper system in 72. Also, the 67-71 setup, the wiper motor gets all of its power from the switch. The 72-up style, the wiper motor always has one power lead "hot". So quite different wiring setups.
Joel Samba Member
Posted: Mon Jul 14, 2014 3:51 pm Post subject: |
The positive self parking system came out in 72 so the intermittent option worked
it was an option in some markets and became standard on a few models
mbjeeper wrote: |
I have read in my searches that it can be done with some wiring changes and possibly the addition of a relay, but I haven't seen how this can be accomplished. |
Here you go.
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
Posted: Tue Jul 15, 2014 5:15 am Post subject: |
Thanks for the help, guys. I will try to wire in the relay and see what I get...
Greg
13-14, maybe 15 air cooleds... |
Posted: Wed Jul 16, 2014 1:14 pm Post subject: |
For anyone wondering or checking into this thread later, Joel's diagram with the relay above does work beautifully.
If I remember correctly, the only impediment to putting a later ('72 up) wiper system into a '67 and earlier car is that the holes in the cowl have to be enlarged just a little, and you need to make up a support bracket.
Seems to me the above diagram would be the hot ticket for updating a 6 volt car, as the '72 up wiper motors seem to be pretty common and cheap.
Again, thanks for the info!
Greg |
Tenor66 Samba Member
Joined: April 04, 2011 Posts: 24 Location: Berlin, Germany
Posted: Mon Aug 03, 2015 10:59 am Post subject: |
Hello Everyone!
I'm pulling up this old thread to ask if any of you experts have some advice for me. I'm trying to wire up a replacement wiper motor that I purchased from CIP along with a 68-71 Beetle switch that I also bought from CIP. The numbers on the back of the switch seem like they should simply correspond with the numbers on the motor assembly, but when I turn the switch on, the fuse blows. Side note: when I tried following the instructions for 'parking the motor' prior to assembly, the motor turns over just fine on the respective low or high possibilities. So, I know the motor is good. I'm wiring #30 to fused power and #31 to ground.
_________________ Martin---
'72 1302 |
