waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
Posted: Wed Aug 05, 2015 7:11 am Post subject: |
I tackled this job last night and it was easier than I expected. The channel on my car is in great shape so that helped, but getting it in (with the engine in the car) wasn't too difficult at all. I used a water/dish soap mix on the rubber and pushed the top lip in with a dull screwdriver. Took a couple of hours.
Now on to the next job! _________________ Mike B. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Aug 13, 2015 6:08 am Post subject: |
The rear edge of my rubber seal is long torn out. I just got the Thing running, so I don't want to pull the engine now, or really dick with the seal until maybe Winter.
I had some duct tape but that didn't stick well to the car side with the oily/dusty residue that is there.
So I wandered around my garage trying to think of an alternative. As I thought of the comments of using the Bus style seal, I spied some 1 inch think foam I had sitting there.
What I did was cut a couple strips of the foam, probably 6 inches wide. I then used some duct tape to roll it in half. Finally, I got some heavy duty aluminum foil and wrapped the foam in the foil, such that it was doubled over on the side facing down.
This jammed into the gap nicely and should work for the time being. _________________ Dave Cook
1973 Wild Westerner
My Thing |
ALANSD Samba Member
Joined: April 16, 2015 Posts: 341 Location: Woodstock, GA
Posted: Mon Aug 17, 2015 6:17 am Post subject: |
Im with ya. I could not get out all the old rubber, and it was not in my plan for now to pull the motor.
So I made it work...Gorilla Tape seems to be holding ok, although it loosened in the spot where I missed cleaning up some grease..Of course..
Kinda stupid |
