sraucher Samba Member
Joined: December 13, 2010 Posts: 9 Location: Redwood City,CA 94062
Posted: Tue Aug 18, 2015 5:47 pm Post subject: Help needed with Volt Meter to check 6 volt 356 Porsche. |
Embarrassed to say I have forgotten which setting to put knob to on common volt meter electronic measuring device to check the performance of a 6 volt Optima Red Top Battery. Also want to check out 6 volt voltage regulator and Generator.
Any help on how to do this is much appreciated.
Steve |
MMW Samba Member
Joined: April 30, 2012 Posts: 846 Location: northern NJ
Posted: Wed Aug 19, 2015 3:48 am Post subject: |
For just checking voltage output use dc volts. If it does not say dc then a V with a straight or dashed line is dc. (ac has a squiggly line) Your meter likely has a several volt settings, pick the number closest but above 6. _________________ Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle |
Posted: Wed Aug 19, 2015 7:52 am Post subject: follow up about voltage meter. |
My device has a V- ... and a V squiggly line.
Also choices of voltage 500,200,20,2000m,200m.
Should I choose 20 as this is closest to 6v but above it?
Thanks,
Steve |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Wed Aug 19, 2015 9:15 am Post subject: Help needed with Volt Meter to check 6 volt 356 Porsche. |
Hi Steve,
The 20 volt setting is as close as your meter will get. 6 V will peg the millivolt settings and not register on the higher settings. |
MMW Samba Member
Posted: Wed Aug 19, 2015 10:31 am Post subject: |
Jon is correct. Use the V- setting, this = dc volts. _________________ Mic
1959 356 coupe
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Sat Aug 22, 2015 4:24 pm Post subject: |
Hi. Get back to us with your voltage results. Rational is people always asking what is wrong with their own 6 or 12v charging system. If yours is working tell us the results. Nearly everyone doesn't post their "functioning results". I believe it will help others in deciding if their own scenario is good or bad. The difference between a working and non-working 6v system can be 1.5v.
Hope this helps, Bill. |
