wridej Samba Member
Joined: February 24, 2015 Posts: 19 Location: Perth, Western Australia
Posted: Fri Aug 21, 2015 7:14 pm Post subject: Front torsion arm help |
So I had a go at lowering the front of my Notch and followed this guide which also helped me with the rear.
http://www.thesamba.com/vw/forum/viewtopic.php?t=188457
But now I'm in a bit of trouble. I didn't know I wasn't supposed to completely remove the pinch bolt and now I can't get it to thread back in.
Of course I read after I took it out that it can be very difficult to get back in without stripping the bolt. I've also read that you don't even have to undo this bolt anyway but I'm unsure. Hopefully someone can shed some light on this.
So is there any way I can get it back in? Or could I just roadkill it and put a longer bolt with a nut on the other end to hold it?
Still new.. still learning from every mistake I make. |
Yabbadubbadoo Samba Member
Posted: Fri Aug 21, 2015 8:28 pm Post subject: |
I doubt you're gonna get the answer you want to hear but looks to me like you have to assemble it from scratch with the proper bolt. Don't cobble it together. I don't see why you can't remove the lock bolt from the top swaybar/torsion rod and push it out so it disconnects it from acting in unison with the opposite wheel then drop your wheel spindle down carefully by supporting the weight (the one requiring the bolt in the lower ball joint). Looking at your pic the only thing stopping you dropping that wheel spindle down to get that bolt back in is the top arm which is connected via its internal sway bar to the opposite side wheel. That's why you won't be able to lift the ball joint out or drop the spindle down at this point to put the bolt back in.
If you feel uncomfortable disconnecting the sway bar you can always unlock the top ball joint and drop the spindle that way but it could get a little awkward to do by yourself. _________________ Sydney, Australia.
66 Type 3 Fastback |
wridej Samba Member
Posted: Fri Aug 21, 2015 10:54 pm Post subject: |
Bummer. What a mess I've got myself into. Thankfully I only took one side out. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Aug 22, 2015 8:41 am Post subject: |
I messed up the threads on my bolts not taking the pressure off them with my jack, while removing them. I bought/ordered new strong Grade 12 Allen head bolts at my local Specialty Fastener store. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch Samba Member
Posted: Sat Aug 22, 2015 12:50 pm Post subject: Re: Front torsion arm help |
wridej wrote: |
What I've found is that the ball joint actually eats the threads off the bolt when removing it, whilst not lifting the the lower arm. The bolt itself is kind of special, in that it's a 10.9 grade bolt with an extended shoulder to hold the ball joint in place. If you could a similar sized bolt (shoulder part, and grade, even though it's longer), you could use that in it's place. I normally wedge a screw driver (actually tap it in place) into the slot, as that allows the clamping forces to release the ball joint.
You could remove the 30mm nut on the top ball joint to release the hold the opposite side of the car has on it (like mentioned above), but if you're only lowering/raising, then you only need to mess with the lower ball joint.
Definitely use a longer bolt in the other end of the torsion bar to allow the bar to slip out of the splines for adjusting it, then replace with the short bolt that was in place. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
wridej Samba Member
Posted: Tue Aug 25, 2015 8:13 am Post subject: |
I'm looking at the diagrams in my Haynes manual and it shows the lower ball joint as having a sort of cone shape where it sits on the clamp.
Would that and the downward forces from the torsion bar be why I can't thread anything into it because it's being stretched outwards? So if I released that tension a little by raising the lower torsion arm with a jack could I maybe thread a new bolt in? I can't try as I have to go find a new bolt now.
That's just me being logical but I've learnt that logical isn't always right when it comes to these kind of things.
If I did botch it together just for a drive down to someone who could help me reassemble everything would that be a problem? _________________ 1972 Honey Brown Aussie Notchback |
Posted: Tue Aug 25, 2015 9:55 am Post subject: |
wridej wrote: |
If I did botch it together just for a drive down to someone who could help me reassemble everything would that be a problem? |
Yes, putting a jack under the lower shock mount will help take some load off, and allow the bolt to pass thru. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
