ronbug73 Samba Member
Posted: Fri Aug 28, 2015 4:23 am Post subject: crack in the generator stand |
Hi
i drove yesterday and the generator light turned on.
we opened the engine. look whet we found.
the generator turned it self.
look at the crack
we made aquick fix but i need a new 12v generator
stand
Ron |
grandpa pete Samba Member
Posted: Fri Aug 28, 2015 7:39 am Post subject: |
That generator attaches with a strap that is bolted to the top of the fan shroud . if you look at the lower piece in my photo you will see the round shape the gen fits in And the two bolts sticking up with the nuts on them...( I always put the nut on where it came off so I don't loose any)
If your bolt has pulled out the whole piece can be replaced . I'm no metal expert but that is soft metal ...Aluminum or magnesium ????
I suggest you find BooZooK in the Type3 classifieds ; I have bought several parts from him and he is GREAT to work with .
Note ; When removing the 6mm bolts that hold this piece onto the block be VERY careful ; a LOT of type3 owners use Locktite on those small bolts...both mine broke off when removing _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Fri Aug 28, 2015 12:31 pm Post subject: |
One has to wonder WHY that cracked. Either it was overtightened, or your generator seized and turned in the strap, and then broke the strap mount.
I'd check and lube those bearings as long as you have the ten out of the car. Replace the brushed and clean/gap your commutator, too. |
Posted: Sat Aug 29, 2015 12:11 pm Post subject: fan house |
we don't know why
but when we rebuilt the engine. the fan house was already with the crack.
we put an over size screw thread in order to fix the problem.
it hold for three years. the crack became big end the mount jump out.
in order to fix we put a nut from the other side. but this only until i will get the new fan house. in Israel we don't have parts for the type 3.
so im waiting for the fan house. with a big help from Tram.
Ron |
