Intrinsic Samba Member
Joined: November 16, 2011 Posts: 262 Location: Clearwater, FL
Posted: Mon Apr 21, 2014 6:02 am Post subject: Towing an Automatic on a Dolly type trailer |
I will tow my '70 Auto Fastback to the invasion this summer. I need to select a trailer to rent.
To save costs I am thinking of renting a dolly trailer and loading the Fastback backwards. With the rear wheels on the trailer and the front wheels on the ground.
Has anyone trailered an automatic TIII in this way?
Will the car track well with the front wheels on the ground?
Should I rely on the steering wheel lock or lock the steering in some other way?
Thanks |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Apr 21, 2014 7:34 am Post subject: |
I haven't towed one that way, but as an alternative you could remove the CV's and axles, and tow it with the back wheels on the ground. _________________ 71 Elm Green FI A/T Squareback |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Mon Apr 21, 2014 7:50 am Post subject: |
I would use a full car trailer to prevent damage or incident...it's cheap insurance when you consider the full trip. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Mon Apr 21, 2014 7:53 am Post subject: |
My tow dolly works great & is much lighter than a trailer. I've towed them both ways. You can only do about 55 mph backwards before it will start swerving. Forwards with the outer cv joints unbolted you can do 65 mph. Tie up the outer axles with baler twine etc. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
grandpa pete Samba Member
Posted: Mon Apr 21, 2014 8:05 am Post subject: |
Hi Donnie !.. ... Finally I can help you with something >>>>
The tow dolly is a great way to move a car ..
.The front wheels on the ground assure you that NOTHING happens to your AUTOMATIC transmission...
.The tow hitch and tow dolly swivel do all of the steering for you ........TIE DOWN THE STEERING WHEEL......
NEVER BACK UP WITH A TOW DOLLY ( I know YOU KNOW THAT )...but remember it when your pulling into the truck stop on the highway
Double check the DATES on the tow dolly tires
ON the sidewall right by the DOT # is an indented "branded" oval with numbers in it....0511...means the tire was made the 5th week of 2011........4506.....means the 45th week of 2006.............make an informed decision to replace $100 set of trailer tires or are you OK with what you have
NOTE ; commercial truck steering tires CANNOT be more than 5 years old...I check the tire dates everytime I pick up the rental trucks we use _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22356 Location: Kimball, Mi
Posted: Mon Apr 21, 2014 8:40 am Post subject: |
Mike Fisher wrote: |
My tow dolly works great & is much lighter than a trailer. I've towed them both ways. You can only do about 55 mph backwards before it will start swerving. Forwards with the outer cv joints unbolted you can do 65 mph. Tie up the outer axles with baler twine etc. |
Yup, pull the CV joints at the drive axles, and tie them up. Only pull it facing forward, as the cars toe in is not designed to travel in a rearward direction. At the 2002 type 3 Invasion, someone from either Oregion or Washington had a problem with their car, so they loaded it up backward on the dolly. After about 10 miles, the car got into a violent swerve, and tried to flip the car-dolly-truck combination. It all ended up in the center median facing the wrong way. Not the way to start an Invasion weekend. I'd never tow a car facing the wrong way, unless it's on a trailer.
Either tow it in the correct direction, or use a trailer. I've towed t-3s on a tow dolly from Idaho to Michigan, Missouri to Michigan, and Iowa to Michigan without issue (other than loosing some rust chunks coming back from Idaho), but I've always towed with the car's front wheels on the dolly. Same applied to an S-10 I towed back from Missouri last fall, pull the drive shaft, tie it up, and haul butt. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Apr 21, 2014 9:38 am Post subject: |
grandpa pete wrote: |
Hi Donnie !.. ... Finally I can help you with something >>>> |
Sorry GP, it wasn't me asking _________________ 71 Elm Green FI A/T Squareback |
Posted: Mon Apr 21, 2014 10:07 am Post subject: |
I towed Tram's blue Mercedes over to him (a little muddy) backwards @ 45mph last week.
Posted: Mon Apr 21, 2014 4:51 pm Post subject: |
What are you, 10 miles away from Tram? Try doing that 700 miles each way. It would really make for a long day. I can garrantee you'd be under it disconnectiong the drive shaft IF you had to drag it over a 100 miles.
OP; An alternative would be to fab up a tow bar for it. Do a search, as you can modify an existing super beetle tow bar for less than a days rental of a tow dolly. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
roverjosh Samba Member
Joined: October 16, 2007 Posts: 361 Location: Omaha, NE
Posted: Sun Aug 30, 2015 10:57 am Post subject: |
Sorry to revive an old post, but why can't I tow an Automatic on all 4 wheels if the car is in neutral? Is it something to do with the torque converter?
I have to move to Omaha in a couple months and the car won't be ready by then... I do not have a truck strong enough to tow it on a trailer so I was going to buy/make one of those tow behind bars that attach to the front suspension...
Thoughts? _________________ ~I should change my cars name to "Leaky". |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Sun Aug 30, 2015 11:01 am Post subject: |
Here is why:
Posted: Sun Aug 30, 2015 1:37 pm Post subject: |
Then there you have it! Thanks Phil. I wish I had more time to post and work in the Notch but I am always so thankful that this site exists.
I will buy a bigger truck and tow it on a trailer or just drive the thing.
Thanks Samba! _________________ ~I should change my cars name to "Leaky". |
Posted: Sun Aug 30, 2015 9:20 pm Post subject: |
roverjosh wrote: |
Thanks Samba! |
As long as you disconnect the outer CV's, you can flat tow it behind something. Otherwise, you'll rip the govenor out of the trans. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sun Aug 30, 2015 9:58 pm Post subject: towing |
........News Flash....................please just spent 15 MORE minutes and remove both axle assemblies and put um in the trunk until you GIT wear yer goin...........
MUCH SAFER having both cv joint axles OFF completely
Seriously _________________ V.W.owner since 1967 |
Posted: Sun Aug 30, 2015 10:09 pm Post subject: |
That makes sense. It's just six more bolts, right?
Bob, as always, thanks! Hey how far are you from Omaha NE... I'm moving there in a couple months. I've noticed I have some welding repair to do on the Notch... _________________ ~I should change my cars name to "Leaky". |
Posted: Sun Aug 30, 2015 10:47 pm Post subject: 12 move cv bolts |
12 more cv bolts _________________ V.W.owner since 1967 |
Posted: Mon Aug 31, 2015 9:19 am Post subject: |
roverjosh wrote: |
Bob, as always, thanks! Hey how far are you from Omaha NE... I'm moving there in a couple months. I've noticed I have some welding repair to do on the Notch... |
Not sure. But, I'm about 10-11 hours east of Des Moines Iowa. I think Omaha is another 3 or 4 hours west of Des Moines. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Sep 02, 2015 7:06 pm Post subject: |
That sounds a little far. I'll have to post lots pics and get your advice via "The Interwebs!"
Thanks Bob _________________ ~I should change my cars name to "Leaky". |
Posted: Wed Sep 02, 2015 8:48 pm Post subject: |
roverjosh wrote: |
Thanks Bob |
No problem. I offered Monte a bunch of help over his build. We even talked on the phone too.
Omaha is a lot closer than the east coast was. I think you were in southern Maryland, right? That's probably closer to 20 hours away. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Sep 06, 2015 10:04 am Post subject: |
Thanks Bob, yeah, we were in DC before we moved to San Diego... Now we're heading to the Midwest. Should be fun! Thanks for the offer. _________________ ~I should change my cars name to "Leaky". |
