daanbc Samba Member
Posted: Tue Sep 01, 2015 7:12 am Post subject: |
heywebonya wrote: |
Daanbc,
Any help on the wiring? I ordered the switch and all that came was a switch in a baggie. Looks nice.
There are five terminals:
+ positive
- negative
C ???
NO normally open
NC normally closed
I understand to hook up + and - to the 12 volt supply (likely for the light). The NO should go to the horn.
What about C?
Thank you, Jeff |
The + and - are for the light. The horn connects to the "C" and "NO". Nothing is connected to the "NC"
C = common
NO = Normally open
NC = Normally closed
Don't forget to add the resistor. |
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Tue Sep 01, 2015 3:48 pm Post subject: |
Resistor? I did not notice this before, could you give some more help? _________________ If I knew what I was doing; I wouldn't be building a buggy! |
daanbc Samba Member
Posted: Tue Sep 01, 2015 4:45 pm Post subject: |
heywebonya wrote: |
Resistor? I did not notice this before, could you give some more help? |
As a precaution use a 1/2 watt resistor on the + side. This way the LED won't blow. You can get 25 of them from amazon for $4.26 ( E-Projects - 470 Ohm Resistors - 1/2 Watt - 5% - 470R )
I just soldered them in line then covered them in heat shrink/wrap. |
Posted: Tue Sep 01, 2015 5:44 pm Post subject: |
Daanbc, thanks for the help. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
daanbc Samba Member
Posted: Tue Sep 01, 2015 8:27 pm Post subject: |
heywebonya wrote: |
Daanbc, thanks for the help. |
Let me know how you make out. |
Skulptorchaz Samba Member
Joined: June 11, 2013 Posts: 839 Location: S.E. Indiana
Posted: Wed Sep 02, 2015 10:00 am Post subject: |
Very cool button! I was looking for the actual button for my steering wheel but can't find one. I may just fab one up and use the one you are showing. I too prefer it on the wheel, as some have said. Here is what I "rigged" till then.
I know.......but it works and the holes were perfect! LOL |
daanbc Samba Member
Posted: Wed Sep 02, 2015 12:11 pm Post subject: |
Skulptorchaz wrote: |
You could place that button on the roll cage and use your knee to hit it. |
Posted: Wed Sep 02, 2015 7:18 pm Post subject: |
HA!! True! I actually have the horn button on my '56 Chevy on the floor (For 36 years) But no 3rd pedal in the '56. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Sep 03, 2015 8:33 pm Post subject: |
Had a friend in high school (around 1974) that had the horn button under the carpet on the floor of his 1962 Impala SS. 2 pedals in that car too! _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Fri Sep 04, 2015 9:43 am Post subject: |
That horn button served me well in college on my super beetle brake pedal Awesome brake light switch _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
