piperj Samba Member
Joined: October 17, 2011 Posts: 35 Location: Silverton, Oregon
Posted: Mon Aug 31, 2015 7:29 pm Post subject: Urethane or Rubber Torsion Bar Bushings? |
Hi, I'm getting ready to replace my original 1967 bug bushings and am wondering what the forum recommends? I understand that Empi purchased Bugpack and some of the grommet /bushing options we once had are no longer available. So do we only choose between Empi red urethane or original rubber types? Suggestions/Ideas appreciated.
My car is stock except for 1915 dual carb and performance exhaust and I'm just looking for good replacement bushings that will last .
John _________________ 67 Sun Roof Bug |
grandpa pete Samba Member
piperj Samba Member
Posted: Mon Aug 31, 2015 8:50 pm Post subject: |
Grandpa Pete, thanks for the tip. I did quite a bit of searching prior to posting my question and really didn't find what I was looking for. Would appreciate your being a bit more specific; if you can provide me with a link to a post I would appreciate it. If the net of your answer is to just use rubber; I'm ok with that; just want to know best choice for longevity.
Thanks!
from one Grandpa to another... _________________ 67 Sun Roof Bug |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Tue Sep 01, 2015 4:52 am Post subject: |
Not sure if it relates to torsion bar bushings, but I've seen red urethane motor and trans mounts dry up, disintegrate and crumble into small pellets after about 10-15 years.
Rubber on the other hand may harden, shrink and crack, but still hang in there.
Changed the originals just for good measure on my '66 when I was messing around with the torsion bar adjustments. They were 45+ years and still looked in good to fair shape.
I went with WW's replacements, which claim to be from an OEM maker...
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=311511246 _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
vwnut1 Samba Member
Posted: Tue Sep 01, 2015 5:53 am Post subject: |
Make sure to apply grease to the urethane bushings if you decide to go that route. They are known to squeek without lube. _________________ 1957 VW Oval Resto Mod |
allsidius Samba Member
Joined: February 02, 2010 Posts: 1475 Location: Norway
Posted: Tue Sep 01, 2015 6:09 am Post subject: |
Considering that the rubber bushes on my 1972 made car are probably never replaced and still hanging in there, I'd go for OG rubber stuff when they finally need replacement. I went out and got the lot from reputable dealers, always went for the best german quality I could. But the MOT guy said they did not need replacement yet, so it is kept on a shelf in a cold dark place until further notice. But stay away for those cheap chinese knockoffs, they will crumble in a season or two. _________________ 1973 1303S w sunroof Click to view image
1978 1303 convertible (sold)Click to view image
1966 1300 RIPClick to view image
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Tue Sep 01, 2015 7:22 am Post subject: |
I just replaced my year old squeaking red urethane bushings with rubber ones. No more squeak. No noticeable change in handling. When I took it apart, there was still lots of thick silicone based grease on the inside of the urethane bushings. I don't get it. I recommend rubber unless you are using it for some extreme application like autocross or road racing. _________________ 1958 Karmann Ghia owner |
Markymarc Samba Member
Joined: August 12, 2015 Posts: 116 Location: Las Vegas
Posted: Tue Sep 01, 2015 9:29 am Post subject: Re: Urethane or Rubber Torsion Bar Bushings? |
piperj wrote: |
John |
urethane will crack, stay with rubber |
piperj Samba Member
Posted: Tue Sep 01, 2015 10:11 am Post subject: |
I appreciate the input from everyone. Sounds like the consensus is to stay with rubber. I ordered a set from WW today. From some other forum topics it sounds like using talcum powder is the way to install.... Any other thoughts , let me know!
Have a great day!
ThingBeast Samba Member
Posted: Tue Sep 01, 2015 7:44 pm Post subject: |
If you are speaking about the bushings that mount on the beam, I went with Delrin. They are the best out there. I know Airkewld suggests them too. Do not try to skimp out on this, you will be replacing the red polyurethane ones as they squeak. I've had absolutely zero issues with mine going on 2 years. Just my 2 cents worth |
piperj Samba Member
Posted: Wed Sep 02, 2015 12:35 pm Post subject: |
I should have mentioned that my post is in regard to my rear torsion bar suspension springs... I guess that would help a bunch I guess the technology between urethane and rubber applies to either but I am just working on the rear suspension at this time. The front is stock on mine. _________________ 67 Sun Roof Bug |
Posted: Wed Sep 02, 2015 1:44 pm Post subject: |
The rear housing bushings were the urethane one's that squeaked like heck on mine. Rubber handles just fine. _________________ 1958 Karmann Ghia owner |
