1960 23 Window Deluxe restoration
Page: Previous  1, 2, 3 ... 8, 9, 10, 11, 12  Next
lumber-baron
lumber-baron is offline
PostPosted: Tue Jan 13, 2015 9:59 pm    Post subject: Reply with quote
I understand that the consensus here on the Samba is that Sigla skylite glass was clear. Here is a picture of an original skylite next to a side window, granted they are 50 years old, both are cleaned, But the skylite glass definitely has a tint to it.The tint in laminated glass is added to the boning material, not the glass.
If you check out some of the original VW advertisements specifically for a 1960 deluxe the skylites are tinted.
EmpiGT
EmpiGT is offline
PostPosted: Tue Jan 13, 2015 10:15 pm    Post subject: Reply with quote
I have a set of 7 sigla skylights from a 1960 here, they do have a slight tint, but very slight like the laminate is slightly discolored. I read somewhere euro model busses didn't have to use laminate and used the green tempered sekurits like the 50's busses, so the vw adverts are most likely euro market busses with sekurits.
EmpiGT
EmpiGT is offline
PostPosted: Tue Jan 13, 2015 10:30 pm    Post subject: Reply with quote
This bus would have had siglas as well. Doesn't look to have a tint to me?
Not trying to be mean. I love that you eched the logos,just wondering if it was a preference thing that you went green?
lumber-baron
PostPosted: Wed Jan 14, 2015 5:44 am    Post subject: Reply with quote
Page 5 from a 1960 Sales Brochure:
The logo art work was copied from the original skylite.
EmpiGT
EmpiGT is offline
PostPosted: Wed Jan 14, 2015 6:03 am    Post subject: Reply with quote
Yup that's a euro market bus with tempered sekurits I'm sure.
lumber-baron
PostPosted: Wed Jan 14, 2015 6:38 am    Post subject: Reply with quote
Thanks for your input
lumber-baron
PostPosted: Sun Jan 18, 2015 8:49 am    Post subject: Reply with quote
Got the steering box back together. A big thanks to Heart Cameron for providing a nice cover and some front end goodies!
Jerry
Jerry is offline
PostPosted: Wed Mar 11, 2015 7:02 pm    Post subject: Reply with quote
Let's see it Pete!
Looking for SO34 parts.
thevwcompound *instagram*
lumber-baron
PostPosted: Tue Apr 14, 2015 11:31 am    Post subject: Reply with quote
Got the beam and T.A. in over the weekend.
Shaun at Painters lined me up with this recently rebuilt transaxle with a 4:12 R&P Cool
lumber-baron
PostPosted: Tue Aug 11, 2015 8:13 pm    Post subject: Reply with quote
A little update on the project....
Installed all new brake lines, cylinders, and shoes
Color sanded and polished the paint, got the POS WW bumper to fit, and straightened and polished the deluxe trim
Installing the safari seals was a bit of a chore, used Sika urethane adhesive and home made "clamps" to hold them in place.
Painters is building a 1914 for me, should be done in 3-4 weeks
There appears to be a little light at the end of the tunnel Cool
brettsvw
brettsvw is offline
PostPosted: Fri Aug 14, 2015 3:33 am    Post subject: Reply with quote
Great job so far.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
lumber-baron
PostPosted: Tue Sep 01, 2015 1:44 pm    Post subject: Reply with quote
I picked up some steel tube and S spring to rebuild the seat backs.
zimblewinder
zimblewinder is offline
PostPosted: Tue Sep 01, 2015 6:30 pm    Post subject: Reply with quote
Great work. Could you explain your process for shaping the fold back of the s - springs. Did you aneal them?
dale
58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism
lumber-baron
PostPosted: Thu Sep 03, 2015 4:52 am    Post subject: Reply with quote
Fortunately the springs were annealed by the manufacturer and I was able to make the bends using 2 vise grips.
zuggbug
zuggbug is offline
PostPosted: Thu Sep 03, 2015 5:15 am    Post subject: Reply with quote
outstanding work - thanks for the update
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
Stocknazi
Stocknazi is offline
PostPosted: Thu Sep 03, 2015 7:47 am    Post subject: Reply with quote
Nice fab work on the seat frame.
Did you salvage the replacment flat steel strip section from another seat or did you buy new?
WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
lumber-baron
PostPosted: Thu Sep 03, 2015 8:14 am    Post subject: Reply with quote
I was able to salvage about 1/3 of them and replaced the rest - I used 16 gauge hot rolled carbon steel, it had a decent amount of "spring" to it. the metal shop couldn't cut it to 3/8 because it twists in their shear so I had them cut it to 1" strips and then cut those down the middle with the Harbor Freight shear - it takes a 1/4" strip out of the middle. It made it through about 4 6'strips before it bit the dust. Fortunately that was all I needed.
lumber-baron
PostPosted: Tue Sep 08, 2015 1:46 pm    Post subject: Reply with quote
Got this finished up this weekend
Now it's time to get this bad boy installed
1914 built by Eddie at Painters Grinding
silvertonguedevil
silvertonguedevil is offline
PostPosted: Thu Sep 10, 2015 9:58 pm    Post subject: Reply with quote
Sweet bus!! Nice work!
-Greg
lumber-baron
PostPosted: Fri Sep 11, 2015 3:59 pm    Post subject: Reply with quote
Thanks Greg!
Page 9 of 12
