Suggested wire gauges
Axitech
Axitech is offline
PostPosted: Fri Oct 02, 2015 6:03 pm    Post subject: Suggested wire gauges Reply with quote
Ok, had enough of waiting for new engine case to arrive, and decided to tackle a couple other issues that bother me. The first is, my control panel REALLY starts to bother my right outer lower leg on about mile 230. I decided to move the entire panel to an overhead position. Two gauges, oil and volts, Ignition switch, headlight switch, horn switch, and indicators for left and right turn, and high beam.
I'm going with a 10 gauge Batt wire, and I have a bundle of 18AWG wires in their own sheathing. I am using 18gauge to trigger headlight and horn relays that will be mounted remotely behind seat(probably behind seat, this may change), so no big deal there. What I need to know is:
is 18 gauge wire big enough to use as a starter solenoid wire? (let's say the distance is 15 feet)
is 18 gauge big enough to drive the coil?
I think they are, but I'd like to hear your thoughts. Thanks.
He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson
Dale M.
Dale M. is offline
PostPosted: Fri Oct 02, 2015 6:57 pm    Post subject: Re: Suggested wire gauges Reply with quote
Probably not.....18 gauge is ok for sensors and control of relays.....But I would use at least16 gauge for any tail/turn/marker lights and14 gauge for coil circuit and for headlights..... These are my minimums and it does not bother me to go one size larger....
Wire sizes are predicated on amperage load and voltage drop in circuit.... Coil circuit is critical, if voltage drop is to much coil will no fire effiently and it will rob you of power...
When I was in work world, we had saying "when in doubt go larger gauge wire" ... Wire sizes larger than required are usually not much of a problem, but to small and it may go up in smoke, and it will happen when you are 10 past "nowhere"...
Tyring to cut corners with electrical and its a sure ticket to grief...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Axitech
Axitech is offline
PostPosted: Fri Oct 02, 2015 8:52 pm    Post subject: Reply with quote
Thanks Dale. The ignition coil circuit is the one I was worried about. I don't want to run a lot of heavy wire into the overhead console, so I'm going to look into running another relay for the ignition circuit.
All the lights are going on relay circuits already, so one more relay on the block won't hurt me.
dustymojave
dustymojave is offline
PostPosted: Sun Oct 04, 2015 10:45 am    Post subject: Reply with quote
18ga is DEFINITELY too small for starter relay wire.
But if you are already running a 10 ga for power, I see no problem running a couple of 14 ga for coil and starter. It's not as if it's going to make the car top heavy. You could maybe fish the wires through holes in the roll cage too. Be sure to use grommets if you do that though.
Richard
SoCalBajas Member
Axitech
Axitech is offline
PostPosted: Sun Oct 04, 2015 12:36 pm    Post subject: Reply with quote
That's the point. I want as little wiring overhead (small wires as opposed to large wires). I can run small overhead wires and use them to trigger relays behind the seats. I'm not a fan of running things inside roll cage. That merely weakens the cage as far as I'm concerned. Thanks for the input. I wasn't sure what size I needed for starter relay.
dustymojave
PostPosted: Mon Oct 05, 2015 11:06 am    Post subject: Reply with quote
Actually the FAA allows holes in a 1.5" structural tube as large as 3/8". I'm not a fan of relays as they add complexity, something else to fail, and cost.
My old Hi Jumper offroad race champion buggy (avatar) has such wires for the lights inside the cage tubes and got endoed while flat out in 4th gear. Quadruple flip and no damage to the cage AT ALL!
For a wire run from the starter switch direct to the solenoid on the starter 14ga works great. For wiring from a switch to a relay, 18ga would probably work OK.
If you're gonna use relays, whether on the street or in the dirt, I suggest they be mounted inside of a sealed box with grommets, etc. to keep out dust, water and mud. In a car used hard offroad, I've observed trouble with the relays shaking loose and having trouble with poor connections.
Richard
SoCalBajas Member
Dale M.
Dale M. is offline
PostPosted: Mon Oct 05, 2015 11:50 am    Post subject: Reply with quote
For any application like off road, yes you probably need some way to clamp relays to socket .... Even a zip tie around relay body and socket would be good...
Dale
ponyboy88
ponyboy88 is offline
PostPosted: Wed Oct 07, 2015 2:44 pm    Post subject: Reply with quote
i'm using leftover stuff when i can on my baja and running 1/0 gauge for the starter via a ford style solenoid mounted near the battery (which is getting moved outfront for a little better weight balance (my battery and tank are currently in the backseat)...and 2 gauge for the alternator with a mega fuse. its overkill, but honestly i wouldnt want to go much smaller. (im using 2 gauge for the ground too, although if i had more 1/0 id use that.) If everything in the switch panel is run via relays, your overhead switches should only need smallish 14-16 gauge wires since they are only taking a small load.
1970 Baja Bug.
dustymojave
PostPosted: Thu Oct 08, 2015 11:36 pm    Post subject: Reply with quote
14ga will carry all the current for all the things he wants to wire overhead without using relays at all.
Richard
SoCalBajas Member
Dale M.
Dale M. is offline
PostPosted: Fri Oct 09, 2015 8:35 am    Post subject: Reply with quote
I agree that 14 gauge is probably a good "one size fits all" size wire for most wiring application...
Dale
