planenut Samba Member
Posted: Thu Sep 17, 2015 3:11 pm Post subject: Engine break in |
Hey guys, I've just got my '66 on the road. It has a 1600, and when I finished it, I looked for break in instructions. I don't recall anyone saying to use non-detergent oil for break in. I have around 200 miles on my engine. At first I used Valvoline straight 30 wt. After the initial 100 mile oil change, my VW shop advised that was the wrong oil, and I should use the Valvoline VR1 because of the zinc content. I have around 200 miles now, and it still smokes when I start it. I don't remember that being normal for even a VW. I know it doesn't have valve seals, but is this to be expected? Or, what did I do wrong? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri Sep 18, 2015 2:33 pm Post subject: Engine Break In |
Cusser, my deck lid isn't vented, but I do carry tennis balls, in case. I did have initial temps up to 235, but all is better with new cooler seals. I'm just puzzled at the smoke on start up. valves and guides were nice and tight, and the cylinders were rehoned at assembly. Oh, and I do have a look out for a vert lid. |
slalombuggy Samba Member
Posted: Fri Sep 18, 2015 3:26 pm Post subject: |
IF you can find someone who has one, get a leak down tester. It's a gauge that pumps air into the cylinder and tests how much is leaking out. That will tell you if it's your rings or valves
Could be that your rings haven't seated yet and now that you switched to synthetic oil, they probably won't. I never switch to synthetics till over 500 miles it's too slippery and won't let rings break in properly. You can try switching to regular oil and add a zinc additive and see if that helps. I had a 1600 in a 57 with a stock lid and never had problems overheating. Look elsewhere for your overheating problem.
brad |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Fri Sep 18, 2015 4:55 pm Post subject: |
Hi. This topic is very touchy with many folks here. You will find brand loyalty is important to people. I hope this post doesn't get locked due to its main interest in motor oil but here goes. Gene Berg was a big time supporter of the non-det Valvoline. I used it and still have some. This is old school and possibly not followed much any more. I prefer the diesel rated oils for my mild engines. I can get a straight weight 30 for a few thousand miles, but changed a few times, then transition to the diesel multi grade. These oils are dual rated (diesel and gas engines) and used by many fleets. Simple and inexpensive.
Bill |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Sep 18, 2015 4:58 pm Post subject: |
Rings need to seal on a new engine.
Yes you want oil with lots of zinc to help the lifters and cam break in. _________________ Glenn
Member #1009
#BlueSquare |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Sep 18, 2015 5:14 pm Post subject: |
Even with rings worn in, you can get oil smoke due to engine tilted to one side in uneven parking spot.
Just in case, what color smoke are you seeing??
White = water vapor which is normal in cooler weather at start up.
Bluish white = oil.
Black = too rich with fuel. _________________ In Stereo, Where Available! |
Danwvw Samba Member
Posted: Fri Sep 18, 2015 6:50 pm Post subject: |
Probably going to need new cylinders and rings, I would go ahead and take it back to the people that rebuilt the engine sounds like the cylinder hone job or the new rings did not seat in right, I have found this to always be the case with do it yourself hone jobs and re-using old piston and cylinders.
The ZDDP is not for the pistons and rings and cylinders, it won't matter, it's for your lifters and cam. Yeah, VR-1 would be fine so would the oil you used too, Just add 1/4 bottle Lucus brake in oil additive with ZDDP.
New P&C's "Think Clean Air"! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Fri Sep 18, 2015 7:22 pm Post subject: |
Thanks guys. It does sound like the rings aren't seated yet. |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Sat Sep 19, 2015 9:16 am Post subject: |
Cylinders want various rpms when break-in. Driving with same rpm for longer time, is no good. It will glaze the cylinders. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Posted: Mon Oct 05, 2015 4:00 pm Post subject: Engine break in |
Seems like my cylinders must've finally broke in. I haven't seen smoke the last 5 or 6 times I've started it. Strange. I've always broken engines in on non-detergent oil. |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Tue Oct 06, 2015 2:59 am Post subject: Re: Engine break in |
planenut wrote: |
Never use non-detergent oil in a bug engine. ALL the owners manuals say " use HD oil". That means "high detergent", not "heavy duty" as some think. Old terminology and all that....
Most modern engine oils are detergent oils, so you would have to look hard to find the inappropriate non-detergent oils these days. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
