zodlaw Samba Member
Joined: July 27, 2005 Posts: 507 Location: Battle Ground, Wa.
Posted: Fri Jun 19, 2015 8:05 am Post subject: |
Yeah I am 44 so right behind you. Air ride will take care of the no clearance issue. there is no way I am running it all aired out like this. Its only for rolling really slow and parking. When I am aired up in the front its about 65lbs for air, but no gas and tank so prob be around 70ish. As for the tires
175/55/15 Contenentals front
175/65/15 Dunlops rear _________________ 68 build that had been sitting for 18yr in a garage.
http://www.thesamba.com/vw/forum/viewtopic.php?p=8119987#8119
Bagged 69 pile (SOLD)
http://www.thesamba.com/vw/forum/viewtopic.php?t=591100&start=0 |
zodlaw Samba Member
Posted: Sat Jul 25, 2015 6:14 pm Post subject: |
Well not much of an update but I did pick this up to fix my screw up.
But realizing that this is a full day job and I wanted to move the bug and it was driving me nuts. So found this in the dumpster and few welds and some bolts with 2ft of fuel hose.
My next task should be the fuel line and brakes but I have an e brake. Note this is only for pulling in and out not driving on the street.
This is aired up, prob run little more but I can get into my drive way now.
and this is layed out
So next going to hook up my compressor and run my air lines. My priority's are way off. LOL
So shopping list prob:
1/4 dot lines get a work discount 21 cents a foot
2 90 dot brass fittings $2
1 brass t $4
Flapper valve with guage
and some 2500 bags for the rear. (to come later) _________________ 68 build that had been sitting for 18yr in a garage.
zodlaw Samba Member
Posted: Fri Jul 31, 2015 4:37 pm Post subject: |
Well I broke down and blew what I had left. This is going to head into the winter so master cylinder comes later. Got a really nice set of Bags from a mini truck guy at work. Nice set of Firesone 255c 1.5 bags 1/4 port and they look like new. Also my dual paddle valve gauge set up came in the mail today.
Specs:
Firestone 255c Air Bag 2500lb Single 1/4" Port
Min. Height: 2.80"
Installed Height: 5.50"-6.50"
Max Height: 8.30"
Diameter(Inflated): 6.60"
Port: 1/4" NPT
Manufacturer: Firestone
Manufacturer Part #: 6957
As for the paddle valve set up, I could have made it myself buying all the parts but it was almost a wash by about 30 bucks shipping,tax and time . Ebay has the best price on these looked for about a week fast shipping too. The main reason I bought it now is so I can get my fronts hooked up. Tired of have to pump it up, though the 1/8 crap lines have held air for a week. I need to clean the garage and put the 1/4 lines in. My son wants to help with the bug so this should be a good project.
Been working on the bag assy. It will prob change a little deepening how things measure out. I looked at a few other options but this set up is the best by far for irs.All for now.
zodlaw Samba Member
Posted: Thu Sep 24, 2015 9:38 pm Post subject: |
Fighting the fittings on the front monroes. 7/16 20 thread. What were they thinking. I mean I did not pay much but man I can not find a solution for under $40. I went to napa and they were talking $60 get real. I finally found a tap at work so prob going to try this. I get a small discount at granger from work.
The guy says 1/8 npt tapped out to 7/16 20 with 1/4 dot push lock. $9 each going to order them tomorrow hopefully.
Planning to do some major work soon, all for now. _________________ 68 build that had been sitting for 18yr in a garage.
zodlaw Samba Member
zodlaw Samba Member
Posted: Tue Oct 20, 2015 9:27 pm Post subject: |
Finally got everything hooked up.
I know its a mess but its a good place holder.
Prob going to rework a lot of it.
After I get everything working good going to pull the whole front end out and paint etc.
I have been picking away at it about 10 min a day or so not much time at all, but I got it installed.
So tank pump sorta installed.
Ran the Dot lines along with the dot fittings in the front.
Found out It also had a check ball valve already! Did not have to buy one sweet!
Got my adapters they seem to fine. I still have not leak tested the system yet.
I finally found out some info on these pumps. I guess they are low duty and rebuild-able.
18amp 12v ect. I ran some 12ga lines all the way to the battery.
and here is the spec sheet. This seems more like and industrial pump so I guess we will see how long it last.
So it takes 1:30 sec to fill up the tank. After I let out below the switch it takes 20sec to refill to full psi. Not bad really.
I have a switch under the dash that is hooked up to the ignition. That way it will not come on when the car is off.
I also can shut it off via the dash switch.
Used a spot in speedo where there was an extra assy light to let me know the pump is running.
I still need to check for clearance on the shocks to the arms they are pretty tight so might have to take the flapper wheel and smooth out some material.
Also drill the shocks out for the .25 dot line. Id of the dot line is about 3/16 and its got maybe less than a 1/8 hole.
Its a bit slow on the drop and raising. I am pretty happy with the set up so far I just need to figure out where my alignment is I think its pretty out of wack again. _________________ 68 build that had been sitting for 18yr in a garage.
zodlaw Samba Member
Posted: Thu Oct 22, 2015 8:06 pm Post subject: |
Got my air bag mounts cut out of 1/4 plate. I know its prob over kill but just need some time to get this done. Need to get them cut and tacked in so I can get placement for the top brackets. I think I am going to notch my arms for shock mount clearance too rather than cutting them off.
So aired up the front. I have a leak somewhere it prob just a loose fitting or its at the shocks where my adapters go. I don't know if I put enough tape.
zodlaw Samba Member
Posted: Thu Oct 29, 2015 4:23 pm Post subject: |
Got my upper mount plates done been waiting a while for these.
Also I was chasing down a leak in my system and it turns out it was a tee fitting on the airlift gauge set up. I emailed them told them how I checked and replaced the hose and it still did not seal. Same day I sent the email off kid you not, "sending you out one today". I good company to deal with! Played around with the fuel tank on how I am going to mount it. I think I am going to just raise it about Inch and quarter. The next time I post I hope to be doing some cutting and fitting on the rear. _________________ 68 build that had been sitting for 18yr in a garage.
mfergel Samba Member
Joined: July 24, 2013 Posts: 247 Location: Richmond, VA
zodlaw Samba Member
zodlaw Samba Member
Posted: Fri Nov 06, 2015 2:17 pm Post subject: |
Got my fittings from Airlift. They sent me two instead of just one. I got the fitting replaced and its been holding are for few days. Also messed with my fuel tank little to see how much I have to raise it to clear the front beam. I am sure if the front was not smashed in I would only have to move it up about an inch or so.
So for the want list to get it driving again. ( well I can move it but no brakes) Don't want to blow my budget again. I already did that once.
Mast brake cylinder
Brake line
pop out window gasket
fuel gauge sender _________________ 68 build that had been sitting for 18yr in a garage.
zodlaw Samba Member
M_atthewanderson Samba Member
Joined: January 25, 2005 Posts: 288 Location: Seattle
Posted: Sun Dec 06, 2015 2:14 pm Post subject: Re: 1969 bug yard find build |
Looking good. Have you driven it? _________________ 1980 2.0 Sunroof Vanagon |
zodlaw Samba Member
zodlaw Samba Member
Posted: Fri Dec 18, 2015 11:26 am Post subject: Re: 1969 bug yard find build |
Ok, so I decided to take off thur and fri of this week at the last minute. I am have taken the rest of the month off and I wont be back to work till the 4th of Jan. I spent most of yesterday cleaning the garage for the big switch to bags in the rear. I hate working in unorganized shop. I eyeballed the front wheels again at ride height and flipped the tie rod on the drivers side back. As far as I can tell I will be able to run pretty low. Put in new door seals that came with the car and cleaned a few other things up. All this so I could park the dub in sideways
I thought I was going to pull the motor but I need it to make sure everything clears and I don't think it will do much for space anyways. So the plan is to re index down to 4 clicks on the inside and make clearance for that. I only have prob 3 inches left till I hit my pan or jack mount. I don't plan on driving that low anyways, just for layout. I will post more pics as stuff gets done.
so:
rear bags
fuel line
gas tank raise _________________ 68 build that had been sitting for 18yr in a garage.
zodlaw Samba Member
Posted: Sat Dec 19, 2015 3:46 pm Post subject: Re: 1969 bug yard find build |
Well got It done so no going back now.
I cut the shock mounts off.
I re indexed it to 4 clicks on the inside.
I used the jack to jack it up to see what else was binding up. I might have to take some material off of the spring plate, maybe 1/4 inch or so.
Need to clearance for the bolt not to much more.
The heater box and axle look fine.
Prob have to cut some more for the cv boot to clear.
I am playing most of this by ear and kinda new to the air bag stuff. I might end up taking the torsion bars out depending how it rides. I will def have to figure out where to mount the shocks. Thats the update for now I will prob clean everything up and half way mount the fenders and put it on the ground. I have at least dropped it another 2 inches. I can fine tune the plates the road. I am mainly concerned about getting the bags set up right for the height I want. As always open for some suggestions if anyone has some. More to come later _________________ 68 build that had been sitting for 18yr in a garage.
dubjeep Samba Member
Joined: December 24, 2011 Posts: 354 Location: Rhode Island
zodlaw Samba Member
CB75 Samba Member
Joined: August 16, 2012 Posts: 88 Location: Ontario Canada
Posted: Sun Dec 20, 2015 2:54 pm Post subject: Re: 1969 bug yard find build |
Your doing a great job imo!! I've been 4 years and still going lol. |
