Coletrain93 Samba Member
Joined: September 30, 2015 Posts: 25 Location: Michigan
Posted: Wed Oct 07, 2015 8:12 am Post subject: |
the number stamped below the oil filler is B 625 9260.
its not that im expecting more power than it has, the issue is Ive felt the power it has and sometimes it just lacks power under the same conditions and still sounds and runs relatively the same as when it has full power. im thinking maybe something in the carb is plugged or partially plugged because when I ran it at the beginning of the year it was quite underpowered and running poorly and I tracked down the actually injector (cant remember the name for it) that goes into the throat of the carb was plugged with some sort of buildup and I couldn't clear it out so I replaced it and it ran much better |
Posted: Wed Oct 07, 2015 8:23 am Post subject: |
ok so im debating either just fixing it up this winter and maybe also investing in another toy next spring or just going all in on the rail. I convinced my fiancé it would be worth it because it can also be used as a daily driver. so basically what would be the best route to beef this thing up. I want it to atleast be able to lift the tires off the ground which im guessing shouldn't be too far out of reach. ive heard of engine swaps but also seen some vw engines that put them to shame so which would be the cheapest and would the trans stand up to the engine or am I going to have to invest in that too. I don't plan to beat on it. |
dustymojave Samba Member
Posted: Thu Oct 08, 2015 11:59 pm Post subject: |
The VW Bug trans was designed to handle 40 horsepower in mild street use. More hp = more abuse on the trans as well as more abusive driving such as wheelying means more tearing up the gears. Speed costs $$. How fast can you afford to go? _________________ Richard
SoCalBajas Member
Sandjunky Samba Member
Joined: August 03, 2015 Posts: 292 Location: New Mexico
Posted: Fri Oct 09, 2015 6:55 am Post subject: |
Coletrain93 wrote: |
which would be the cheapest |
Your ambition and your budget are on different plains.
Building a powerful bug engine is definitely doable, but much cheaper if you can do it yourself. Plenty of youtube vids out there. Watch a few and you'll see just how quickly it can get expensive!
[/url] |
