Porsche 914 Drivers side Headlight not retracting
mhoule1951
mhoule1951 is offline
PostPosted: Sat Oct 10, 2015 3:57 pm    Post subject: Porsche 914 Drivers side Headlight not retracting Reply with quote
Hi there. I have a '75 Porsche 914 2 Litre, and the driver's side headlamp lifts but does not retract. I tried switching the relays, to see if the issue moved to the passenger side, but the malfunction stays on the driver's side. Any suggestions?
bluebus86
Banned
bluebus86 is offline
PostPosted: Sat Oct 10, 2015 4:03 pm    Post subject: Re: Porsche 914 Drivers side Headlight not retracting Reply with quote
Ok tried the relay swap no good. then confirm you have power to that relay with a meter or jumper wire in the relay socket jumper pin 30 to 86 in the socket. pin numbers should be stamped on relay.
also confirm that motor limit switches are working, you can turn the motor emergency open knob to see if the motor will kick in. that knob is on the end of the motor shaft inside the trunk. should be a black plastic cone shaped knob. Of course it could be missing leaving you with just a threaded shaft end, which you could put a screw in and turn via the screw.
the motors use one fuse for both sides, so if the other side works, the fuse is good.
good luck
