Gauges
Page: Previous  1, 2, 3 ... 12, 13, 14, 15  Next
ib-bus
ib-bus is offline
PostPosted: Thu Sep 24, 2015 8:53 am    Post subject: Re: Stork Oil Temp Guage Reply with quote
buggen wrote:
Has anyone ever seen this Stork Oil Temp gauge? It is the mechanical dip stick style and it has a green light what the oil is to cold and a red light when the oil is to hot. When I got it the seller said it was NOS and the gauge holder came with the gauge and looks to have always been with the gauge. When you slide the gauge out of the holder there is clean ring around the gauge where the holder was.
We offer similar gauge holders by Aircooled Accessories , they come in black , ivory or chrome.
Check my ads here on The Samba.
Peter_KG
Peter_KG is offline
PostPosted: Mon Oct 19, 2015 3:56 am    Post subject: Reply with quote
Hi,
I have these two VDO temp gauges, as they go to 120°C, could these both be oil temperature ones?
Anyone familiar with these VDO's?
Thanks!
Peter
VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54
tstracy39
tstracy39 is offline
PostPosted: Fri Oct 23, 2015 3:01 pm    Post subject: Reply with quote
Peter_KG wrote:
Hi,
Thanks!
Peter
The first pic is of a water temperature gauge, so it's not for a VW. The redline on the dial is at 100 degrees Celsius (boiling point of engine coolant) so it's only for water cooled engines. The second pic is of an industrial temperature gauge that can be used for either oil or water temp applications, but not designed for VW.
Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
I like your fork.
Harris
Harris is offline
PostPosted: Fri Oct 23, 2015 6:57 pm    Post subject: Gauges Reply with quote
My short 12 year experience searching for a specific VDO gauge tells me one thing. VDO was prolific in producing gauges for numerous auto manufactures.
If you can by number on back of gauge determine a time span in years, then Google images of different car (European mainly) makers may lead you to the exact automobile your gauge was produced for. The VDO archives in Frankfurt has limited info left that gives the facts you need.
I don't think VDO had a long run of producing any one gauge even for one car manufacturer.
bigdish2
bigdish2 is offline
PostPosted: Tue Feb 06, 2018 1:18 am    Post subject: Re: Gauges Reply with quote
Just picked up this March 54 vdo clock. Not many this old posted on here.
For lastest finds check out
@texasvintagevdubs on Instagram or Facebook
In the stash
1954 & 63 Vert
1956 Dove blue camper
(2) 1958 23w deluxes
1958 PGSG 11w og paint
1958 logo dd panel
1959 dove blue 11w
(5) 15w deluxes
(2) 1960,63,65 double cabs
1963 swr/bg 11w og paint
1964 limo bus 350 powered
1964 SO36 Dormobile flipseat Westy
1966 (2) so42’s og paint
1969 (2) porsche 912s
1969 dart swinger 340
(3) Porsche 911s sunroof,targa,cab
NASkeet
NASkeet is offline
PostPosted: Tue Feb 06, 2018 9:14 am    Post subject: VDO Gauges Reply with quote
tstracy39 wrote:
Peter_KG wrote:
Hi,
Thanks!
Peter
VDO oil-temperature gauges commonly have 50~150 ºC temperature scales, although there were some on various Audi cars which were calibrated up to 170 ºC.
On German E-bay, I have seen some VDO temperature gauges with calibrated scales of 60~200 ºC, but I have yet to discover their intended application.
For at least 30 years, VDO have been making 40~120 ºC temperature gauges and a variety of matching sender units with different screw-thread sizes; some with a temperature-switch (various switch temperatures) incorporated to activate a warning light or audible warning device.
For a pressurised liquid-cooling system (typically 13 or 15 psi above standard atmospheric pressure), the boiling point of pure water exceeds 100 ºC.
Various mixture proportions of water & antifreeze (typically glycol) have different boiling points, which exceed 100 ºC at standard atmospheric pressure.
https://www.thoughtco.com/what-is-the-boiling-point-of-water-607865
http://www.compoundchem.com/2016/03/22/boiling-point/
Regards.
Nigel A. Skeet
http://www.vwt2oc.net
swanlakers
swanlakers is offline
PostPosted: Mon May 07, 2018 11:44 am    Post subject: Re: Gauges Reply with quote
Not the kind of gauge you can put in the dash, but pretty cool nevertheless
Bowmonk acceleration and brake gauge - measures in % of G.
In use:
NASkeet
NASkeet is offline
PostPosted: Wed Jun 13, 2018 8:41 am    Post subject: Re: Gauges Reply with quote
Until recently, mine was the only VDO Cockpit 'Night Design' instrument (i.e. VDO Cockpit 'Night Design' alternator-sensed 0~6000 rpm engine-tachometer) I have come across, but I have since discovered a few more on E-bay.
52 mm VDO Cockpit 'Night Design' alternator-sensed 0~6000 rpm engine-tachometer
52 mm VDO Cockpit "Night Design" 7000 rpm engine-tachometer
VDO Cockpit "Night Design" 50~150 degC oil-temperature gauge
VDO Cockpit "Night Design" 40~120 degC water-temperature gauge
VDO Cockpit "Night Design" -30~0~30 A ammeter
VDO Cockpit "Night Design" -25~0~40 degC ambient-air temp gauge
I also recently discovered a VDO Cockpit "Night Design" 120~350 ºF oil-temperature gauge listed in The Samba Classified advertisements as follows:
https://www.thesamba.com/vw/classifieds/detail.php?id=1893001
Regards.
Nigel A. Skeet
NASkeet
NASkeet is offline
PostPosted: Thu Aug 23, 2018 8:04 am    Post subject: Re: Gauges Reply with quote
Here is a VDO combination accessory gauge unit of a type I have never previously seen, which incorporates a fuel gauge and oil-temperature gauge. Although I cannot see any measurement units specified, I deduce from the number scale that the oil temperature is being measured in degrees Fahrenheit; much favoured in the USA, but declining in use even here in Great Britain where the metric system is now the norm for most things.
VDO combination fuel & oil-temperature gauge unit
I found it recently listed on British Ebay, for a prohibitively high asking price of £265 + shipping, but I thought you might be interested to see this example, which the vendor says he originally bought for his 1954 VW Beetle.
VW Camper Van / Beetle fuel & oil temp gauge made by VDO
https://www.ebay.co.uk/itm/VW-Camper-Van-Beetle-Fu...Sw4CFYodKl
Regards.
Nigel A. Skeet
NASkeet
NASkeet is offline
PostPosted: Fri Aug 31, 2018 8:46 am    Post subject: Re: Gauges Reply with quote
The asking price has now been reduced to £195 + shipping, which is still extremely expensive
Regards.
Nigel A. Skeet
Lind
Lind is offline
PostPosted: Fri Aug 31, 2018 3:19 pm    Post subject: Re: Gauges Reply with quote
That gauge was made by VDO for '58-'61 beetles. It fits at the top middle of the dash. It is also bulky, ugly and not desired by many people if anyone. It is a neat item, but not nearly as precious as the ebay seller thinks it is.
Wanted:
NASkeet
NASkeet is offline
PostPosted: Sat Sep 01, 2018 8:05 am    Post subject: Re: Gauges Reply with quote
If I had had a vehicle for which it was appropriate, I might have stretched my budget to maybe the equivalent of US$50 for one of those, but by my standards, even a reduction to £195 + shipping, would be a silly price. Rolling Eyes
Regards.
Nigel A. Skeet
NASkeet
NASkeet is offline
PostPosted: Mon Dec 24, 2018 4:58 am    Post subject: Re: Gauges Reply with quote
Here are a few more that I discovered recently, that have been listed on British E-bay for some time, at an asking price of £200, which is too rich for my taste:
https://www.ebay.co.uk/itm/VDO-GAUGES-OIL-PRESSURE...rk:41:pf:0
VDO Cockpit "Nightdesign" 0~10 Bar oil-pressure gauge
VDO Cockpit "Nightdesign" 8~16 V voltmeter
VDO Cockpit "Nightdesign" 50~150 ºC oil-temperature gauge
Regards.
Nigel A. Skeet
ALLWAGONS
ALLWAGONS is offline
PostPosted: Fri Jan 04, 2019 8:46 am    Post subject: Re: Gauges Reply with quote
My VDO shop counter display.
NON INFLUENCER APPROVED
muffler bearing
muffler bearing is offline
PostPosted: Sat Jun 08, 2019 6:19 pm    Post subject: Re: Gauges Reply with quote
Anyone know a little about this one?
" A poor ride is better than a proud walk"
56 Beetle
72 Westfalia (Driving project)
75 Riviera
Yes, I do have a Bentley.
Jos.Hall
Jos.Hall is offline
PostPosted: Sun Jun 30, 2019 7:27 pm    Post subject: Re: Gauges Reply with quote
Radatron Space Saver Dancing
kalymnos Premium Member
kalymnos is offline
PostPosted: Thu Jan 16, 2020 11:56 am    Post subject: Re: Gauges Reply with quote
I got hold of an old 6 V tachometer made by VDO: 85/1/10
There are 3 pins: the one in the middle is marked G, the ones left and right of it have no indication, and there is a screw with the ground symbol
I want to test it with an adjustable resistor. Is it correct to connect (+) with pin G and (-) with ground?
What are the other pins for?
Any idea what the blue T means?
Thank you
IN2VWS
IN2VWS is offline
PostPosted: Thu Jan 16, 2020 1:39 pm    Post subject: Re: Gauges Reply with quote
Thank you
Have a look here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=568158&highlight=5000+tach
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³
kalymnos is offline
PostPosted: Thu Jan 16, 2020 2:20 pm    Post subject: Re: Gauges Reply with quote
Thank you for the link, IN2VWS.
So the tach is fed by the current of the tiny dynamo.
I don't have this dynamo, but there must be a way to drive the tach by reading the frequency at the coil (contact 1) and converting the signal into current, like modern tachometers do.
I would never install the tiny dynamo in my car, but I would like to own one though.
NASkeet
NASkeet is offline
PostPosted: Wed Jan 22, 2020 9:37 am    Post subject: Re: Gauges Reply with quote
Nigel A. Skeet, “How to: Fitting an Oil-Pressure Gauge-Sender, Installation Adapter, to the Type 4 Engine”, Volkswagen Camper & Commercial, Issue 17, Winter 2004, Pages 44~45.
When I submitted this article (which was based upon my own investigation of the then readily available new & second-hand parts that could potentially be used as installation adapters), I marked the photographic prints on the back to show which edge was at the top, and coloured the text for the picture titles and captions in RED & GREEN respectively. Sadly, the magazine layout designers appear to have COMPLETELY ignored my guidelines, so several pictures are incorrectly orientated and it’s more difficult to read and interpret the article than it should be!
At the time, I had not long since completed two supplementary part-time courses in desktop publishing and graphic design using Quark Xpress, Adobe Photoshop & Adobe Illustrator, so I knew what could reasonably be done! Fortunately, more recent issues of Volkswagen Camper & Commercial magazine (first published in Winter 2000, there have now been 147 issues so far, which were originally quarterly, then bi-monthly and finally monthly) are much better laid out these days.
www.volkswagencamper.co.uk
Regards.
Nigel A. Skeet
Page 13 of 15
