khalimadeath Samba Member
Posted: Tue Jul 21, 2015 8:08 pm Post subject: Front torsion bars dust cover? |
Where can I buy the dust covers that go on the outside of the arms that cover circular area where the bars slide into. The new arms I got didnt come with them..
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Jul 22, 2015 9:12 am Post subject: |
Off your old arms. |
Tcash Samba Member
SGKent Samba Member
Posted: Wed Jul 22, 2015 1:52 pm Post subject: |
that part #33 N116041 was probably NLA 30 years ago. Off an old one is the only way. Maybe get a hold of folks who rebuild them and they can pull them off no good cores. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Jul 22, 2015 2:01 pm Post subject: |
Maybe something in the way of a freeze plug from you FLAPS. |
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
1967250s Samba Member
SGKent Samba Member
Posted: Wed Jul 22, 2015 8:44 pm Post subject: |
Are we all talking about the same part? The part some of us believe he is describing is the small round cover that pops into the arm in this position. It is a dust cap and it is NLA. They should have been installed in the replacement arms. If it is that part send them back on their dime and ask for a set that is complete.
Posted: Tue Jul 28, 2015 7:47 pm Post subject: |
SGKent wrote: |
Yes sorry I was late on this post.. But that IS the piece I am talking about. I got new arms and only one of them had that piece. I assume the others were lost in whatever cleaning system they have to clean them and they didnt bother to replace it. |
Posted: Tue Jul 28, 2015 7:53 pm Post subject: |
Call your supplier and see if they have any spared laying around. As I already posted you might be able to get a freeze plug that will work from your FLAPS. |
Bannedwagen Samba Member
Joined: December 28, 2009 Posts: 86 Location: Beaverton, OR
Posted: Thu Oct 29, 2015 2:22 pm Post subject: Trailing arm dust cover removal |
How are these dust caps removed?
I have the end of a torsion ?bar? broken off inside my trailing arm and need to get it out. I see that removing the cap will give me access to the broken piece but I'm not sure how to remove the cap. Can't find how to in my Bentley either. The arm is out of the beam so I can get a long bar or pipe and hammer it out unless it'll be damaged. Thanks _________________ 68 squareback
68 deluxe bus
67 type 1
66 type 1 |
wcfvw69 Samba Purist
Posted: Thu Oct 29, 2015 8:10 pm Post subject: Re: Trailing arm dust cover removal |
Bannedwagen wrote: |
The arm is out of the beam so I can get a long bar or pipe and hammer it out unless it'll be damaged. Thanks |
That's what I'd do. Tap it gently from the inside to see if it will pop off from the outside. _________________ Contact me at [email protected]
The Samba member since 2004.
LivinInnaVWBus Samba Member
Posted: Tue Nov 03, 2015 10:34 am Post subject: |
Awesome! Gonna order some asap, ill have to get new screws too. |
Posted: Thu Dec 08, 2016 9:12 pm Post subject: Re: Front torsion bars dust cover? |
SO.. I am going to bump my old thread as I ended up not ordering these. I attempted to place my old caps back on but after smashing my finger with a hammer doing this I gave up. I went off roading this last weekend and went through a lot of snow and mud. There is now a lot of dirt and mud in and around these ares with no covers.. so the inside of the arms are exposed and dirty. How bad is this? Best way to clean it?[/code] _________________ The United States Constitution
(c) 1787. All Rights Reserved
1970 Bus Westfalia
1964 Kombi |
BayAllTheWay Samba Member
Posted: Thu Dec 08, 2016 10:20 pm Post subject: Re: Front torsion bars dust cover? |
a) I bet you bought them at Vintage Vdubs, as mine came from them with these removed. Thanks! Regardless, I asked them after 17 phone calls to try to get a hold of someone what was the deal, and finally he agreed to send me the little bolt-on covers pictured above.
b) They are half baked, complete sh*t and don't keep anything except, perhaps, marble sized rockes from getting in there.
Unfortunately I wasn't concerned about rock marbles getting in there, but grime and grit and other such sh*t.
</rant> dont' order from Vdubs if you did, and don't order those things if you're thinking about it. Find some original ones; maybe Nate at Wagenswest can hook you up.
Good luck, |
Posted: Thu Dec 08, 2016 10:33 pm Post subject: Re: Front torsion bars dust cover? |
BayAllTheWay wrote: |
Good luck, |
Thanks for the tip I will not order them then.. I have the OG ones but I cant get them to fit in the new arms.. _________________ The United States Constitution
1970 Bus Westfalia
1964 Kombi |
Posted: Thu Dec 08, 2016 11:23 pm Post subject: Re: Front torsion bars dust cover? |
Some RTV silicone should work well enough.
I don't think much of the plastic caps that have a tab sitting under the lock nut. Having the lock nut come loose because the plastic fails, followed by the grub screw backing out, could ruin anyone's day. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51120 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 08, 2016 11:25 pm Post subject: Re: Front torsion bars dust cover? |
I agree, a smear of RTV or JB weld would seal it up better with no risk of the bolt coming loose. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Fri Dec 09, 2016 7:57 am Post subject: Re: Front torsion bars dust cover? |
busdaddy wrote: |
I agree, a smear of RTV or JB weld would seal it up better with no risk of the bolt coming loose. |
and what Mike said
X3 _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
