2true Samba Member
CB75 Samba Member
Joined: August 16, 2012 Posts: 88 Location: Ontario Canada
Posted: Fri Sep 20, 2013 11:46 pm Post subject: |
Wow that's pretty cool!!! I didn't see a price tag though. For the right price I think it would be an awesome tool. Would have to hide it from the kids though lol! |
Derek Cobb Annoying
Posted: Sat Sep 21, 2013 4:37 am Post subject: |
Price is likely to be outrageous. I see a serious heat issue with it as well. Likely to warp every piece of sheet metal you point it at. And probably the most dangerous tool in the shop. One bad aim and you'll be blind forever.
Cool video though. |
77Campmobile Samba Member
Joined: June 18, 2006 Posts: 102 Location: New Hampshire
Posted: Sun Sep 22, 2013 7:46 am Post subject: |
Wouldn't necessarily cause heat damage, depends on the type of laser. Different lasers have different wavelengths of light and some materials absorb the wavelength better than others. For instance CO2 lasers are infrared which doesn't get absorbed easily by metals. Most large metal cutting lasers are CO2 but they get around the wavelength issue by using enormous amounts of power i.e. 1000 Watts and much higher.
UV lasers like Nd-YaG and excimer have totally different wavelengths. It's definitely not an excimer as the UV light is highly damaging to human tissue.
Anyways, if the rust and rubber are easily removed with a certain wavelength it doesn't necessarily mean the metal is or it may be at a much slower rate. |
Hank22 Samba Member
Joined: March 16, 2004 Posts: 452 Location: Inside the pizza oven
Posted: Sun Sep 22, 2013 1:40 pm Post subject: |
not knowing the wave length or the power used and to put the price into perspective, a 20mW 488nM laser is about 7k. This will not remove rust or rubber. a 5 mw 700nM laser will run you about 50k and will burn a hole in paper, give a nasty burn to your skin and blind you. I have not used one to try and remove and coatings but a surely would not want one reflecting uncontrolled off any shiny metal. |
Pinetops Samba Member
Posted: Tue Nov 03, 2015 4:25 pm Post subject: |
Just saw this and searched and found this thread. Pretty interesting.
_________________ "A rolling bus gathers no rust." |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Wed Nov 04, 2015 10:56 am Post subject: |
WHOA!
That is by far the coolest thing to date that I have seen for rust removal.
Beats the hell outta that grinding, sanding, ospho, prime, and top coat B.S.
Any idea where a shop is that can do that on the left coast? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Thu Nov 05, 2015 8:55 am Post subject: |
All we have to do is wait for Horror Freight to make a cheap knock-off. _________________ Everything known to man has been written.
Readers are Leaders! |
clausa Samba Member
Joined: November 02, 2015 Posts: 5 Location: Papenburg
