vintage fiberglass Samba Member
Joined: January 23, 2006 Posts: 485 Location: Reading, Pa
Posted: Sat Oct 31, 2015 6:36 pm Post subject: What year is this split beetle speedo pod? is it barndoor? |
I got this older split speedo pod for a standard split? or so I think. It has a L part number on the back as you see in the picture. The key code is odd?? like HU and so is the key (maybe after market)? Is this a 1949? or 1950?
Bruce Samba Member
Posted: Sat Oct 31, 2015 7:05 pm Post subject: |
Turn your lights on. _________________
Retrovan Samba Member
Joined: July 15, 2011 Posts: 524 Location: Port Elisabeth - RSA
Posted: Sun Nov 01, 2015 7:13 am Post subject: |
Not sure, is from a STD model
If you do not need it, I would be interested to buy it for my Split.
PM me and we can talk.
Herman _________________ 1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
2019 Beetle Flatbed Truck called MeFusco
1973 FT Hahn SP - Project 1776cc |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Sun Nov 01, 2015 10:33 am Post subject: |
If you make a better pic of the whole rear side, I am sure here are people around wich are able to tell you if that is bus or beetle.
And if you suspect it to be bus you might better ask in the bus forum? _________________ Master of my domain! |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Sun Nov 01, 2015 9:12 pm Post subject: |
There is usually a date code stamped on the ground fork. I can see just bit of it on the right side in one of your pics. Being that it is on the right, it is a '49 and later pod.
Some pods (rare ones) don't have date codes on the ground fork. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sun Nov 01, 2015 9:13 pm Post subject: |
Also, looks like a P profile key, not an A profile, but it could have been changed out.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
