Will this pulley work
Jrb572
Jrb572 is offline
PostPosted: Fri Nov 06, 2015 9:59 pm    Post subject: Will this pulley work Reply with quote
Will this pulley work on a 36hp?
http://vwparts.aircooled.net/Stock-Crankshaft-Pulley-1200-1600cc-113-105-251G-p/113-105-251g.htm
Bruce
Bruce is offline
PostPosted: Sat Nov 07, 2015 12:18 am    Post subject: Reply with quote
That's the wrong pulley for your engine. If you use this one, it will slow your cooling fan since it is smaller.
If you need a pulley, search the classifieds here on the Samba.
Jrb572
Jrb572 is offline
PostPosted: Sat Nov 07, 2015 6:42 am    Post subject: Reply with quote
Yeah I already did that and got one that was messed up. Now I need to find another one.
rud helsen
rud helsen is offline
PostPosted: Sat Nov 07, 2015 12:40 pm    Post subject: Reply with quote
I have got a spare NOS one.
If you're interested let me know!
RareAir
RareAir is offline
PostPosted: Sat Nov 07, 2015 2:20 pm    Post subject: Reply with quote
From reading the ad link, it looks to be a regular sized pulley Confused
What Bruce is describing is a power pulley. much smaller in diameter.
I believe the stock sized pulley ( http://vwparts.aircooled.net/Stock-Crankshaft-Pulley-1200-1600cc-113-105-251G-p/113-105-251g.htm ) will work just fine for the OPs needs
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
Jrb572
Jrb572 is offline
PostPosted: Sat Nov 07, 2015 3:30 pm    Post subject: Reply with quote
I ordered one. We will have to see how it compares when it arrives. It has to be better than this dented one I have now.
Bruce
Bruce is offline
PostPosted: Sat Nov 07, 2015 4:38 pm    Post subject: Reply with quote
No, the new one John sells is a 40hp-1600 size pulley. They are smaller in diameter than a 25-36hp pulley.
Using a 1600 size pulley slows the cooling fan making the engine run hotter. = bad idea.
Snort
Snort is offline
PostPosted: Sat Nov 07, 2015 6:09 pm    Post subject: Reply with quote
Just think of it as a winter pulley. You're going to also have to play around with different sized fan belts to find one that fits. Keep looking for the correct pulley and you should be able to get set up properly before summer comes.
Jrb572
Jrb572 is offline
PostPosted: Sun Nov 08, 2015 6:50 am    Post subject: Reply with quote
Then they should not state it works for a 1200 on there site.
Jrb572
Jrb572 is offline
PostPosted: Sun Nov 08, 2015 7:12 am    Post subject: Reply with quote
I emailed them about canceling my order if the pulley size didn't match mine.
Ben Dover
Banned
Ben Dover is offline
PostPosted: Sun Nov 08, 2015 8:24 am    Post subject: Reply with quote
A 36hp is NOT a 1200. You said your pulley is bent;straighten it.
Bruce
Bruce is offline
PostPosted: Sun Nov 08, 2015 3:47 pm    Post subject: Reply with quote
It is correct for a 61-65 40-hp, 1200cc engine.
The 36hp engine is exactly 1192ccs, or in advertising, 1200.
EVfun
EVfun is offline
PostPosted: Sun Nov 08, 2015 4:40 pm    Post subject: Reply with quote
There are 2, 1200 cc motors. Both have a 77 mm bore. Both have a 64 mm stroke. Both are air cooled. That is pretty much all they have in common.
Wildthings wrote:
Jrb572
Jrb572 is offline
PostPosted: Sun Nov 08, 2015 5:29 pm    Post subject: Reply with quote
They cancelled my order no problem. I have one place here to call locally so I can go see it in person.
Ben Dover
Banned
PostPosted: Sun Nov 08, 2015 5:48 pm    Post subject: Reply with quote
I understand that Bruce,but every advertiser calls the 36 horse a 36 horse and the 40 horse a 1200.
56Cabrio
56Cabrio is offline
PostPosted: Tue Nov 10, 2015 10:57 am    Post subject: Reply with quote
Is this what you need ?
http://www.thesamba.com/vw/classifieds/detail.php?id=1858586
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
Jrb572
Jrb572 is offline
PostPosted: Tue Nov 10, 2015 6:14 pm    Post subject: Re: Will this pulley work Reply with quote
I seen that and ordered one from him along with an intake. Thanks for sharing it though.
txoval
txoval is offline
PostPosted: Tue Nov 10, 2015 7:10 pm    Post subject: Re: Will this pulley work Reply with quote
I see that you already cancelled, but that pulley would have worked just fine.
The size difference is minimal. 36 hp engines run cold anyways.
I've been running a 1600cc pulley on my 36hp for a couple of years now. I had to switch due to running a machined in sand seal. My 36hp also runs higher compression, ported/polished heads, and larger valves, etc. Engine still runs cold, and even did when I was running my speedwell blower.
A good used 36hp pulley is great too, but you would have been fine.
Original belt works with 1600cc pulley as well...you just need to adjust slightly with generator pulley washers(as designed).
