AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1070 Location: Massachusetts
Posted: Mon Nov 16, 2015 11:56 am Post subject: Source for floor section? |
I'm putting original used floors in my car. The floors didn't have the rear most section and the ones there are cut/rusted/beat. Does anyone make this piece? I'm looking for both left and right. Is the part the same for the later floors?
I was going to try and fix them but they're hammered. Thanks for any help! |
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
splitjunkie Samba Member
Posted: Tue Nov 17, 2015 7:03 am Post subject: Re: Source for floor section? |
That is the wrong part. That is the rear cross member of the body. He needs the rear pan support. WW sells them but as far as I know they only sell them with their pans. They are not 100% accurate for a split. I think John Henry posted some info about them in his 51 standard restore thread. _________________ Chris
rod_vw Samba Member
Posted: Tue Nov 17, 2015 8:45 am Post subject: Re: Source for floor section? |
That part looks pretty close. It doesn't have the part that is contoured to mate with the pan though so you would need to patch the two parts together..
This is the thread where John Henry was using the WW supports. They must sell them separately or he got them from someone who wasn't going to use them with their new pans. The part is close but not perfect.
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=60
Posted: Tue Nov 17, 2015 9:12 am Post subject: Re: Source for floor section? |
Thanks for all the replies! I hadn't noticed any numbers on the left side, but I wasn't looking too closely for them either. That piece in the pic off the Czech site is close but those older ones were a different shape, I guess. They don't contour in at the tunnel either. I will try calling Wolfsburg West and see if they have any available like Johnshenry has. I was just reading his post there (a great resource for fixing an old chassis!). This is an early 53 chassis so it's basically the same. |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Wed Nov 18, 2015 8:40 pm Post subject: Re: Source for floor section? |
I got them from WW. They normally don't sell them separately but they made an exception. I grafted the chassis number from the old into one of the new ones. _________________ John Henry
'57 Deluxe
'56 Single Cab |
