joescoolcustoms Samba Member
Posted: Tue Mar 02, 2010 1:06 am Post subject: |
BugZyla.com wrote: |
The easiest way to do the front piece is to make it slip over the front hump. Thats how we make ours our of 1/8 plate that is cnc plasma cut.
http://www.thesamba.com/vw/classifieds/detail.php?id=797452
BTW we do sell the front piece separate if you dont want to tackle it yourself. |
I have one that the front hump slips over the nepolean hat area. I have not used it and decided not to use it because I could not come up with a good idea of how to seal it.
How do you seal yours that you make? _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
BugZyla.com Samba Member
Posted: Tue Mar 02, 2010 7:12 am Post subject: |
Silicone the area where it slips over, ours fit nice and tight, and then a body gasket on top. _________________ Daryll http://www.azbaja.com P.R.
http://www.bugzyla.com
"Why is there Braille on a Drive Thru ATM?" |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Sat Nov 21, 2015 11:01 am Post subject: Re: body lift attempt |
I've been considering making something like 1" thick-wall body lift that I weld to the pan channel, not to effect a raise of the body, but to strengthen the pan / chassis / body and provide a place to weld connections for a roll bar or cage.
btw, this is just for a street Baja with occasional easy offroad use, not a serious offroad racer.
any ideas, experience, input or criticism? _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Iguana Samba Member
Posted: Tue Nov 24, 2015 5:38 am Post subject: Re: body lift attempt |
Dully noted, saved and will be buying a 1 inch and a 2 inch in the next 30 days. What a time saver for me.
Thanks! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
