TwinkyZulu Samba Member
Joined: September 10, 2011 Posts: 129 Location: Texas
Posted: Mon Nov 23, 2015 4:05 pm Post subject: Generator backing plate coming loose! |
The generator backing plate is coming loose from my generator so the fan is hitting the fan shroud.
Are the two screws holding the backing plate to the generator on the back of the generator, so I would need to remove it from the car to tighten them or is there a way to tighten them without removing it?? |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Nov 23, 2015 4:22 pm Post subject: Re: Generator backing plate coming loose! |
you need to pull the gen- sorry _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
grandpa pete Samba Member
Posted: Mon Nov 23, 2015 5:13 pm Post subject: Re: Generator backing plate coming loose! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Mon Nov 23, 2015 6:58 pm Post subject: Re: Generator backing plate coming loose! |
Lets just say: when you "get there", you should use Loctite, and you'll need a 10mm wrench !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Nov 23, 2015 10:15 pm Post subject: Re: Generator backing plate coming loose! |
a lot of locktight! two of the screws that hold the backing plate to the fan shrout shook loose too. |
Cusser Samba Member
Posted: Tue Nov 24, 2015 6:49 am Post subject: Re: Generator backing plate coming loose! |
TwinkyZulu wrote: |
It's "LocTite", a sister company of my employer, makes high-quality products. For you, the blue-colored threadlocker should work fine; if you use red, then some heat might be required if one ever needs to loosen it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Tue Nov 24, 2015 8:08 pm Post subject: Re: Generator backing plate coming loose! |
TwinkyZulu: this may be helpful:
http://youtu.be/4ewXkdPgsa4 _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
