76VwBug1600 Samba Member
Joined: July 02, 2012 Posts: 575 Location: Lakeside, Arizona
Posted: Wed Nov 25, 2015 2:30 pm Post subject: 95 VW Jetta Trans issue |
So im looking to buy a 1995 2.0T Jetta.
Its a 5 speed and the owner is selling it due to the issue of when he puts it in gear it dies.. Engine just shuts off..
Due to it being a 5 speed im wondering if there is a sensor or what?
Any Ideas would be great! _________________ 1976 Fuely Bug
1973 Super beetle with 26k Original miles.
1968 1600cc
1973 1641cc
1966 Rat-rod
1981 VrRabbit
Not Just our cars.. They are our best friends. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Nov 25, 2015 3:33 pm Post subject: Re: 95 VW Jetta Trans issue |
Nope, normally no sensors. But, you say "2.0T", aftermarket turbo or a typo? Could be a busted tranny or failed clutch if it does have a snail attached. |
Posted: Wed Nov 25, 2015 5:48 pm Post subject: Re: 95 VW Jetta Trans issue |
was some kit they got aftermarket turbo inner cooler setup but it idles fine.
soon as it touches a gear splat lol.. _________________ 1976 Fuely Bug
1968 1600cc
1973 1641cc
1966 Rat-rod
1981 VrRabbit
ps2375 Samba Member
Posted: Wed Nov 25, 2015 5:55 pm Post subject: Re: 95 VW Jetta Trans issue |
Can you scan it for codes? The only sensor on the trans is the speed sensor, since there is no speedo cable on these. Sounds like maybe the shift linkage might be hitting something. Does it do it if you go to second gear? Also the reverse light switch is on there, but that doesn't go to cluster or ECU, at least not normally. |
