capping off heater line? any reason why someone would?
74superTN
74superTN is offline
PostPosted: Fri Nov 27, 2015 6:54 am    Post subject: capping off heater line? any reason why someone would? Reply with quote
So the new bus I just got doesn't have heat. I looked under her and there's two tubes running under the bus that are missing sections. On one end someone used a soup can and clamped it down to close it off. Any reason for this? I wasn't sure if maybe when he got Rabys Camper Special installed that maybe it was needed.
73 Thing
80 Vanagon Westy
grandpa pete
grandpa pete is offline
PostPosted: Fri Nov 27, 2015 8:49 am    Post subject: Re: capping off heater line? any reason why someone would? Reply with quote
someone in the last 37 years didn't want to fix the heater .
common "fix"
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Amskeptic
Amskeptic is offline
PostPosted: Fri Nov 27, 2015 8:56 am    Post subject: Re: capping off heater line? any reason why someone would? Reply with quote
So rodents don't climb up into the interior through the heater ducts.
Colin
www.itinerant-air-cooled.com
Wildthings
Wildthings is offline
PostPosted: Fri Nov 27, 2015 10:36 am    Post subject: Re: capping off heater line? any reason why someone would? Reply with quote
Colin
Yes block off any ducts that are open as rodents will get in. It is also best to leave the heater flapper boxes in the "OFF" position when parking a bus for a long period of time as the closed flapper is one more deterrent to mice getting into the ducts and from there into the cab.
