conradyd Samba Member
Posted: Fri Nov 27, 2015 5:24 pm Post subject: Transmission Not Engaging |
I purchased a rebuilt transmission front Der Buggy Shop in Anaheim (which has since closed shop) several years back for a restore that I'm just now finishing. It manually seems to be moving through the shift pattern but is not engaging in any of the gears. Any input/advice would be greatly appreciated. |
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 952 Location: Sacramento, CA
Posted: Fri Nov 27, 2015 5:42 pm Post subject: Re: Transmission Not Engaging |
Make sure your clutch is adjusted properly. I had that problem once and it turns out the I adjust my clutch cable to the clutch arm spring. I adjusted it more to the pressure plate "spring" and it worked fine. |
Posted: Fri Nov 27, 2015 5:51 pm Post subject: Re: Transmission Not Engaging |
Thank you very much. We will give that try. |
Posted: Fri Nov 27, 2015 6:40 pm Post subject: Re: Transmission Not Engaging |
You want 1/4 inch freeplay in your clutch pedal.
Edit: 3/4 inch freeplay. Thank you Cusser.
Last edited by mikeonthebike on Fri Nov 27, 2015 7:48 pm; edited 1 time in total |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Fri Nov 27, 2015 7:29 pm Post subject: Re: Transmission Not Engaging |
mikeonthebike wrote: |
You want 1/4 inch freeplay in your clutch pedal. |
No, you want about 3/4 inch free play measured at the clutch pedal.
Also make sure that an axle shaft is not actually spinning and that the drum spline is stripped. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Nov 27, 2015 7:47 pm Post subject: Re: Transmission Not Engaging |
Thanks for the correction, Cusser. |
