Shewster Samba Member
Joined: February 26, 2011 Posts: 200 Location: Modesto, CA
Posted: Sat Nov 28, 2015 8:28 pm Post subject: Oil Screen Not Fitting Right? |
I've done more oil changes on my 72 Bug than I can count. But..... this time the screen did not fit right. It was hitting something and would not seat without putting some pressure on it. It was a bitch to get the oil plate on. Now it is leaking just a little bit more than normal.
I got the oil screen from Wolfsburg West. Defective? Has anyone seen this before? Not a big deal to put on another one, but just really odd.
Cheers. _________________ '72 Bug, One-family car, 350k happy miles (ok, a few of those miles were not so happy) |
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Sat Nov 28, 2015 8:36 pm Post subject: Re: Oil Screen Not Fitting Right? |
Hey another Modesto person.
What about pulling it back out and matching it up with the old one? |
Posted: Sat Nov 28, 2015 8:42 pm Post subject: Re: Oil Screen Not Fitting Right? |
Cali_Army_Guy wrote: |
Hey there Modesto person. I did that initially when it did not seat right. But I was in a hurry to get to Bugorama and just bolted it down and left. Then I threw away the old one.
Quick question. I just moved to Modesto. Do you have a mechanic/shop to recommend? _________________ '72 Bug, One-family car, 350k happy miles (ok, a few of those miles were not so happy) |
Posted: Sat Nov 28, 2015 8:52 pm Post subject: Re: Oil Screen Not Fitting Right? |
Shewster wrote: |
Quick question. I just moved to Modesto. Do you have a mechanic/shop to recommend? |
Mahoney Motors
1002 9th St
Modesto, CA 95354
209-522-7248
He's been working on ACVW stuff for like 45 years in Modesto.
My second choice:
The Parts House
939 McHenry Ave
Modesto, CA 95350-5416
209-524-8800
This place also works on ACVW stuff. They also sell a bunch of little parts. Most of it is Empi stuff, but they do have other stuff as well.
Third option:
Auto Recyclers of Modesto
432 S 9th St
Modesto, CA 95351
209-526-0181
This is a ACVW junkyard of sorts. Great place for original German parts. |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Sat Nov 28, 2015 9:50 pm Post subject: Re: Oil Screen Not Fitting Right? |
I ran into the same problem once. There are 2 different size holes in the center of the screen. That is what was stopping mine from seating. You might have run into the same problem. It's the center hole in the screen that fits up into the oil sump. Just a thought.
The screen with the bigger hole has 3 "slices" cut into that hole while the smaller one has 6 "slices". Look at the center of the screen and you'll see what I'm talking about. The one with the smaller hole is just slightly smaller and it won't allow the screen plate to seat correctly. |
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Sun Nov 29, 2015 11:12 pm Post subject: Re: Oil Screen Not Fitting Right? |
And just to help you, some vendors are selling the one that takes the 5/8" p/u numbered as the later one for 3/4"! Nothing is simple these days. _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
Posted: Fri Dec 04, 2015 8:31 pm Post subject: Re: Oil Screen Not Fitting Right? |
Dwayne1m wrote: |
Dwayne. You are awesome. You totally nailed it. Pulled off the old and guess what; 6 slices in the center. Put in the new "3 slice" screen and I'm back to my NASCAR speed oil change.
Thank You. Thank You. Thank You. _________________ '72 Bug, One-family car, 350k happy miles (ok, a few of those miles were not so happy) |
Posted: Fri Dec 04, 2015 8:35 pm Post subject: Re: Oil Screen Not Fitting Right? |
Glad you got it sorted out. I'll keep that in mind if I ever run across that problem. |
Posted: Fri Dec 04, 2015 8:45 pm Post subject: Re: Oil Screen Not Fitting Right? |
The size difference is SO small you wouldn't know to look for it. At least I didn't.
Also, thanks for the local recommendations. _________________ '72 Bug, One-family car, 350k happy miles (ok, a few of those miles were not so happy) |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Sat Dec 05, 2015 9:16 am Post subject: Re: Oil Screen Not Fitting Right? |
Shewster wrote: |
Dwayne1m wrote: |
I ran into the same problem once. There are 2 different size holes in the center of the screen. ... |
Dwayne. You are awesome. You totally nailed it. Pulled off the old and guess what; 6 slices in the center. Put in the new "3 slice" screen and I'm back to my NASCAR speed oil change. |
For future reference, here are the different Beetle oil screens I could find:
40HP 1200cc VW Bug Beetle 1961-1965 (16mm pickup tube)
1300cc-1600cc With Sleeve VW Bug Beetle 1962-1969 (14mm pickup tube)
1600cc Beetle 1970-1979 Air Cooled VW Engines (19mm pickup tube)
While I'm no expert on the early engines I believe there is also a screen for pre-'1960 25/36HP engines as well. I just couldn't find a link. _________________ AshMan40
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sat Dec 05, 2015 5:54 pm Post subject: Re: Oil Screen Not Fitting Right? |
Thanks for the comparisons, Ashman. I've also come across a cheapo style that had no center ring at all at the top of the screen. No, the ring was not stuck on my engine's pickup tube, having ripped out of the screen. Just a cheap new part at swap meets. The screen's center hole conformed to the pickup tube size when you pushed it back up. |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sun Dec 06, 2015 7:29 pm Post subject: Re: Oil Screen Not Fitting Right? |
Rome wrote: |
You mean this one (part number 113115175)
http://www.autohausaz.com/search/product.aspx?sid=...ner/Screen
I ordered one for my '66 but the holes don't line up for the studs. Had to drill and "stretch" them some to get a fit. As far as I know there are no longer any replacements being made that fit. _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
