jimj90 Samba Member
Posted: Sat Nov 28, 2015 10:14 am Post subject: emergency advice. Engine seized |
please help.
engine was free and fine then seized out of nowhere....
pushed car tried to free it up by popping clutch
removed spark plugs,
removed starter,
still seized.
any tricks?
update......tried to pry at the flywheel gear while the starter is out.....couldnt really get a good prying angle...
have no clue what would cause the engine to seize.
P.S.
I had the fuel pump push rod stuck down in there recently.....I did get it out....could a small shard of that be down there seizing things up? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31266 Location: Hot Arizona
Posted: Sat Nov 28, 2015 12:26 pm Post subject: Re: emergency advice. Engine seized |
1. You're trying to turn the engine with a wrench on the crankshaft bolt, right?
2. If you recently did something with that fuel pump pushrod, certainly would be worth your time to pull the fuel pump and pushrod and try to turn the engine.
3. Also, does your clutch pedal still feel exactly the same when you push that down ? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Sat Nov 28, 2015 12:48 pm Post subject: Re: emergency advice. Engine seized |
Did you scream allahu akbar, allahu akbar, allahu akbar as it blew up? |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Nov 28, 2015 1:08 pm Post subject: Re: emergency advice. Engine seized |
DeathTrap wrote: |
You gotta be wearing a vest when you do that-- by the way Allah is listening-- Watch much GoPro siria on youtube do we _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
jimj90 Samba Member
Posted: Sat Nov 28, 2015 1:17 pm Post subject: Re: emergency advice. Engine seized |
Cusser wrote: |
yes.....wont budge
we thought the push rod fell deeper......it was stuck down in there but the engine was free........now that it was seized....we RAMMED it out if there with a pry bar and hammer....
still seized.
seems fine....we were able to put in gear and neutral when trying to pop it free....
answered your questions above....in your quote... |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Sat Nov 28, 2015 1:31 pm Post subject: Re: emergency advice. Engine seized |
Were you driving? Was there oil in it? Drain the oil and check for metal. Did you hear a bang or clunk or anything? Was the motor running fine for days/months/years? Do not panic. Check to see if the bakelite foot for the fuel pump has broken and stuck down there. Check the fan housing to see if something got in astuck in the fan. Take off the fan belt see if motor will turn. Take off valve covers and see if everything looks ok on both sides. _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Mon Nov 30, 2015 3:29 pm Post subject: Re: emergency advice. Engine seized |
I'm gonna take a WAG (Wild Azz Guess) and say, spun bearing. Happened to me: Half a block out of the driveway, the engine just stops. (I don't remember hearing anything unusual.) Won't even crank over.
Much diagnostics later, I found a bent pin & spun crank bearing. _________________ Everything known to man has been written.
Readers are Leaders! |
