toddb_67 Samba Member
Joined: November 28, 2003 Posts: 1313 Location: Hansville, WA
Posted: Sun Jun 01, 2008 6:04 pm Post subject: 914 speedometer question |
Okay, I've been trying to troubleshoot my non-working speedo. I have verified the cable is good (it spins while driving). I have had the speedometer out of the car and apart and verified it worked with my drill. Just out of curiosity I checked the direction that the cable spins and thats when I discovered the cable is spinning the wrong direction! How is that possible? Has anyone experienced this? I'm stumped, any suggestions? _________________ 1970 Pastel White Westfalia
1971 Super Beetle Convertible (sold) http://www.thesamba.com/vw/forum/viewtopic.php?t=582365&highlight=
1970 Squareback "Savanna" (sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=714683
1974 Karmann Ghia- current project, 1967cc engine. https://www.thesamba.com/vw/forum/viewtopic.php?t=775207
“I have never in my life learned anything from any man who agreed with me.” - Dudley Field Malone |
fadler1 Samba Member
Posted: Mon Jun 16, 2008 3:32 pm Post subject: 914 speedo |
Two choices. It is a notorious crimp ring inside the speedo. On Pelicanparts.com there is a 914 technical guide to fixing things. The speedo repair is in there. Secondly, there is a place in LA that fixes them for $50+ bucks or so. |
towd Samba Member
Posted: Mon Jun 16, 2008 9:03 pm Post subject: |
as you are hooking a cable to a drill it spins counter clockwise..or to the left,,,
if you are standing in front of the speedo it turns clockwise or to the right ...
so if yours turns the wrong direction it must be an Empi chinese cable,, sold in Japan,, that was brought over here by some guy from France to sell to you ... |
pbob42 Samba Member
Posted: Mon Oct 29, 2012 9:00 am Post subject: |
I am trying to find this technical article with no luck. Any help appreciated. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Fri Nov 16, 2012 1:28 pm Post subject: |
Makes sense since the 901 series trans is flipped in the 911 due to rear engine. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Crucker Samba Member
Joined: July 31, 2014 Posts: 3 Location: Edmonton, Alberta
Posted: Mon Nov 30, 2015 4:49 pm Post subject: Re: 914 speedometer question |
Can someone give me a hint on disconnecting the speedometer cables on my 1974 914? Do I disconnect the trip odometer at the reset knob or at the back of the gauge? After that, is there enough play in the main cable to disconnect it after the gauge is pulled partially out of the dash?
Thanks! My back is hurting already just thinking about the process to get the speedometer gauge out of the car. |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2576 Location: The Real NDK So Cal
Posted: Tue Dec 01, 2015 12:43 am Post subject: Re: 914 speedometer question |
Crucker wrote: |
you can unfasten the trip cable from the dash and then you can pull the speedo out and then disconnect the cable for the speedo |
