Iggy1492 Samba Member
Joined: January 01, 2013 Posts: 11 Location: Houston, Tx
Posted: Mon Dec 14, 2015 8:30 pm Post subject: Rust in door. Treating vs. replacement |
I am fixing up my 1974 super. I aim to get it painted soon but I see rust in one of the doors and I am not sure if it is something that can be fixed, like applying rust converter and weld a piece of metal, or if it calls for a door replacement. I am hoping for the first option. Words of advise are welcome. this is a daily driver super. see pics
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Mon Dec 14, 2015 11:12 pm Post subject: Re: Rust in door. Treating vs. replacement |
Anything can be fixed/saved, but it is always easier to start with a better part. Your door is probably rusting through on the outside too. I would look for a used door that can be prepared for paint easier/better. Nothing wrong with stripping this door down and cutting/welding on it though. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Tue Dec 15, 2015 6:18 am Post subject: Re: Rust in door. Treating vs. replacement |
Mike Fisher wrote: |
Anything can be fixed/saved, but it is always easier to start with a better part. Your door is probably rusting through on the outside too. I would look for a used door that can be prepared for paint easier/better. Nothing wrong with stripping this door down and cutting/welding on it though. |
What Mike sez.
That door is past "treating"; it needs welding. If you've got the skill & time & tools & just love welding, it may be salvageable.
I'd' find a better door. _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Tue Dec 15, 2015 10:06 pm Post subject: Re: Rust in door. Treating vs. replacement |
Thank you both for your advise. I will call my local vw salvage yard to check if they have a decent door. in the meantime I will start cutting the door as a bug experiment. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Wed Dec 16, 2015 2:50 pm Post subject: Re: Rust in door. Treating vs. replacement |
That is the type of rust...that muriatic acid is superb on. Its waaay too deep and crusty for phosphoric acid treatment or other rust converters.
Muriatic acid will dissolve it down to bare metal. Neutralize it...and then you can wee what metal is thick enough to weld and what needs to be trimmed away to do welding patches.
Ray |
Posted: Wed Dec 16, 2015 3:41 pm Post subject: Re: Rust in door. Treating vs. replacement |
Iggy1492 wrote: |
You have a local VW salvage yard?
Me jealous! _________________ Everything known to man has been written.
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Tue Jan 26, 2016 9:24 pm Post subject: Re: Rust in door. Treating vs. replacement |
I had the same issue with my sunroof. I opted to buy a new one instead. When I cut away the outer layer of metal skin there was TONS of rust where I could not see. |
