Ian Samba Moderator
Posted: Tue Jan 26, 2016 9:57 pm Post subject: VW 120v Generator Industrial |
Looking for any information, pictures, leads, etc. on VW 1100/1200/1300/1500/1600 aircooled powered industrial generators (gas or propane). I know they have different things than a normal motor, like a special industrial camshaft and distributor. I'm sure they all end in a normal flywheel, but then what would they connect with to create AC current? Looking to make semi-OK electrical power. I searched "generator" but most of the results are about 12v generator issues. Thanks! _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Tue Jan 26, 2016 10:56 pm Post subject: Re: VW 120v Generator Industrial |
Wow. Tough hunt for this one pic. It was the only generator pic in the 12 pages that I searched through. I used the search term "industrial".
There were a few references to a back up power supply for the original Disney trains using VW industrial engines.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
busdaddy Samba Member
Posted: Wed Jan 27, 2016 8:53 am Post subject: Re: VW 120v Generator Industrial |
I'm reasonably sure the cam is the same as a road motor, but the flywheel is oddball (see the black starter motor sticking out towards the camera in the pic?).
Are you thinking of building something Ian? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jan 27, 2016 10:23 am Post subject: Re: VW 120v Generator Industrial |
Wow! That's a lot of engineering just to keep the generator armature as close to engine as possible. Interesting though. I too wonder if there is a generator build in the works. I have seen VW industrial powered saw mills in the past. Seemed like a sound idea.
I think there might be cam differences. When I was searching for the above image, I did notice that there were a few pics of cams. Also a majority of the industrial engines utilized magneto's. A magneto might not be required if a generator is used to recharge the starter battery. Seems that most of the magneto engines were hand crank style.
Buy Once, Cry Once!
Ian Samba Moderator
Posted: Wed Jan 27, 2016 6:38 pm Post subject: Re: VW 120v Generator Industrial |
67rustavenger wrote: |
Good Luck. |
I know right! I'd like to purchase a few of these things, but if I have to I will make them, once I get it figured out. Maybe I could make a unit that bolts on to a typical flywheel ended Type 1 motor, just add your starter, battery, and gas and go. I've heard about that Disney one before. I can't believe there isn't more information out there, someone has to have one of these!! Maybe a scan of an instruction booklet or an old advertisement page or something?! I've seen quite a few of the VW air compressor units but never any AC power generators.
I'm trying to build a new workshop that runs entirely off VW power, blood, sweat, and tears. _________________ All your Buses are belong to us.
Posted: Wed Jan 27, 2016 7:19 pm Post subject: Re: VW 120v Generator Industrial |
Then you need to hit Craigslist for a PTO generator, ditch the gearbox and devise a coupler to fit the splines on a cut down bellhousing. Careful when shopping, some make thier power at 1800 RPM and others at 3600, don't know if you'd be in the peak VW HP range at 1800. I don't know what math would determine how many HP it would take to drive it directly but most are geared up from 540 RPM PTO shaft speed, maybe compare KW output VS: HP to similar direct drive units?
Слава Україні! |
coad Samba Scapegoat
Ian Samba Moderator
Posted: Wed Feb 17, 2021 11:57 am Post subject: Re: VW 120v Generator Industrial |
I live in Houston and need to figure something out for the long term as I posted this several years ago.
A 220v generator would be fine if I could split a leg off for 110v.
Test, recalibrate, test. _________________ All your Buses are belong to us.
goober Samba Member
goober Samba Member
Posted: Wed Feb 17, 2021 9:30 pm Post subject: Re: VW 120v Generator Industrial |
If you were good with electronics you could probably control it with a microprocessor circuit. Even an old slow 1mhz 8-bit microprocessor should be fast enough.
You could determine rpm with a sensor on the fan pulley, control the throttle position with a small step motor/pot and check the output for frequency to maintain a steady 60hz.
I wouldn't think you'd need a 1 to 1 connection. The engine should be capable of producing power for 10000 watts at a lower rpm while still maintaining 3600 for the gen.
You'd have to calculate it all out. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12743 Location: Western Canada
Posted: Thu Feb 18, 2021 5:30 am Post subject: Re: VW 120v Generator Industrial |
I would be extremely surprised if there was a different cam shaft in the industrial engine. The power band and the cooling system as designed are a good match and changing the cam to have peak power at a different rpm would also entail changing the fan speed to match. The stock set up peaks in the 3 to 4K range which is exactly where you want it for power generation.
I am not sure why you would go with an air cooled VW engine. A diesel would last longer, be more fuel efficient and you could burn heating grade diesel without the road taxes. Running a gasoline engine at pump prices makes for expensive power.
The other option if you insist on an air cooled engine is to go natural gas for fuel if you have a line to your home. Next best cost wise would be propane with a big tank in the yard. That will get you under the road tax issue too. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Sat Feb 20, 2021 6:52 pm Post subject: Re: VW 120v Generator Industrial |
Ian wrote: |
Test, recalibrate, test. |
What all are you planning on powering with your generator? |
Ian Samba Moderator
Posted: Sun Feb 21, 2021 6:35 am Post subject: Re: VW 120v Generator Industrial |
Not sure yet.
The little Honda 3000 powered the furnace, a space heater, and some miscellaneous electrical outlets for 3 days.
Just for emergencies, nothing crazy like a Willy Wonka granola bar factory or anything. _________________ All your Buses are belong to us.
Posted: Sun Feb 21, 2021 9:06 am Post subject: Re: VW 120v Generator Industrial |
Ian wrote: |
Not sure yet.
Just for emergencies, nothing crazy like a Willy Wonka granola bar factory or anything. |
My entire house is 12v DC. I use solar for my main power source and a VW engine as my generator for back up when the days are short and I don’t get enough sunlight for the amount of electricity I consume that day. I know it’s not the same as what you’re trying to do, but it works out great for me.
One thing to keep in mind if you build one, if you want to have remote start you should probably plan on fuel injection rather than a carb so there is no choke issues. |
Abscate Samba Member
Posted: Sun Feb 21, 2021 9:18 am Post subject: Re: VW 120v Generator Industrial |
Ian wrote: |
Not sure yet.
Burning fuel to make electricity to heat makes no sense at all, if that space heater is electric.
In our outages a Honda 2000 powers our furnaces , fridge, freezer, limited -lights. We had a longer shot down where we shut down those and ran washer and dishwasher once. _________________ .ssS! |
oprn Samba Member
Posted: Sun Feb 21, 2021 7:47 pm Post subject: Re: VW 120v Generator Industrial |
We have a 3000 watt and it does not have enough jam to start the water well. Runs everything else but water is pretty essential! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Mon Feb 22, 2021 3:43 am Post subject: Re: VW 120v Generator Industrial |
oprn wrote: |
We have a 3000 watt and it does not have enough jam to start the water well. Runs everything else but water is pretty essential! |
Did we ever figure out why your start current seemed so High compared to others? Was it as simple as you had a much deeper well than most?
I have a point at my cottage and can pull water at full,pressure with my Honda, but it is only 10-12 meters or so _________________ .ssS! |
