vwfye Samba Member
Posted: Fri Jan 01, 2016 3:35 pm Post subject: Re: Kellison XP 1 Sandpiper |
Removed the gauges/switch and started to try and get rid of the decades of goo on the dash. Any suggestions? I've tried, Awesome, Simple Green, white vinegar with a scotchbrite and a tooth brush.
As you can see, there is a bunch to get off of there. Thanks!
_________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sun Jan 03, 2016 8:50 am Post subject: Re: Kellison XP 1 Sandpiper |
Awesome.
I thought I had the only kellison XP1 on the east coast..
Mine is a never built body I've been sitting on for about 15yrs. Did the chassis (IRS) set the body on top, had a kid, and am just now getting back to building it.
GS guy Samba Member
Joined: December 03, 2007 Posts: 968 Location: Maryland
Posted: Sun Jan 03, 2016 3:13 pm Post subject: Re: Kellison XP 1 Sandpiper |
vwfye wrote: |
Not sure what kind of "goo" you're referring to, but my primary goo remover is mineral spirits. It can take a little while, but doesn't evaporate too fast and you can keep soaking and working it. Also good on painted surfaces to remove excess trim adhesive or sticker residue. For the really tough stuff, acetone sometimes works the best. _________________ 70's vintage Deserter GS buggy - undergoing transformation to Super GS! |
vwfye Samba Member
Posted: Sun Jan 03, 2016 6:31 pm Post subject: Re: Kellison XP 1 Sandpiper |
vwinnovator wrote: |
Awesome.
I'm on the west coast _________________ 64 No'back Speedster "Pearl"
Ratt Samba Member
Joined: April 15, 2003 Posts: 753 Location: Puyallup, Wa
Posted: Mon Jan 04, 2016 10:56 am Post subject: Re: Kellison XP 1 Sandpiper |
Bought mine in Esperance NY in 2013. With. Sweet hard top too. |
vwfye Samba Member
Posted: Mon Jan 04, 2016 2:11 pm Post subject: Re: Kellison XP 1 Sandpiper |
Ratt wrote: |
How is it to play in? Oh, do you have any side views? _________________ 64 No'back Speedster "Pearl"
jtime101 Samba Member
vwfye Samba Member
Posted: Wed Jan 06, 2016 12:34 pm Post subject: Re: Kellison XP 1 Sandpiper |
I would have never guessed, with the slope of the hood, that the windscreen would be so upright! _________________ 64 No'back Speedster "Pearl"
Ratt Samba Member
Posted: Thu Jan 07, 2016 12:04 am Post subject: Re: Kellison XP 1 Sandpiper |
It's better than the alternative. The original window was made with a pivot. Kind of like the Thing. The windshield doesn't go all the way down. [/img] |
vwfye Samba Member
Posted: Thu Jan 07, 2016 12:06 am Post subject: Re: Kellison XP 1 Sandpiper |
Well, that seems silly. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Jan 11, 2016 12:34 pm Post subject: Re: Kellison XP 1 Sandpiper |
color wiring diagram done. Saturday we make the harness! Woot!!! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Jan 15, 2016 9:12 pm Post subject: Re: Kellison XP 1 Sandpiper |
After an examination of the buggy body, post pressure watch, I will be painting over the old color instead of trying to save it. There is LOTS of repair work needed and I have a gallon of New Holland Tractor Blue I can lay over it and the repairs.
vwfye Samba Member
Posted: Sat Jan 16, 2016 11:00 pm Post subject: Re: Kellison XP 1 Sandpiper |
Main loom done! Gauges and under dash left to do.
vwfye Samba Member
Posted: Wed Jan 20, 2016 3:03 pm Post subject: Re: Kellison XP 1 Sandpiper |
I'm going to mount the gauges on aluminum panels in the dash recesses just for a bit of visual improvement. _________________ 64 No'back Speedster "Pearl"
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Thu Jan 21, 2016 10:09 am Post subject: Re: Kellison XP 1 Sandpiper |
Is that a water injection system? |
vwfye Samba Member
Posted: Thu Jan 21, 2016 10:10 am Post subject: Re: Kellison XP 1 Sandpiper |
Yes it is. Gots to keep that intake air from the turbo cool.
That turbo set up is going on my 2275 _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Jan 26, 2016 12:04 pm Post subject: Re: Kellison XP 1 Sandpiper |
Is it the weekend yet? Man... this week is crawling. I just want the cage build to start already! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Jan 28, 2016 6:26 pm Post subject: Re: Kellison XP 1 Sandpiper |
Trailer hooked up. Pan and body secured. Seat and seatbelt in the tow rig. Ready for a cage!
Brian is stoked! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Feb 09, 2016 10:50 am Post subject: Re: Kellison XP 1 Sandpiper |
While the buggy is at the cage builder's place, I have been working on othe things.
I now have the front end, steering box and collapsible shaft for the steering in my possession. The transmission has been opened up to access the damage when it broke at the track in a different car. The only failure was the driver's side axle spade. The gear stack and the differential are good to go.
So, until the body/pan/cage return, I'm in a holding pattern. _________________ 64 No'back Speedster "Pearl"
GoMopar440 Samba Member
Joined: February 06, 2015 Posts: 491 Location: Montana
Posted: Tue Feb 09, 2016 11:21 am Post subject: Re: Kellison XP 1 Sandpiper |
It's looking pretty good so far. I'd be stoked too.
vwfye wrote: |
I really like that shade of blue. It looks fairly close to the rattle can color I'm using on my rail now. I want to use a real spray on paint when I build my replacement frame, not a rattle can job like I did on this one.
BTW, where did you happen to find that paint and how much is a gallon of it going for (ballpark) these days? It's probably a single stage paint like most tractor and implement paints right? I've heard that tractor/implement paints are more durable and a lot cheaper than two stage automotive paints and was wondering if there's any truth to that rumor. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Link to my rail (re)build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=629493
