January 1953 'Smooth Gate SC
Page: 1, 2, 3, 4  Next
Hellberg
Hellberg is offline
PostPosted: Wed Aug 26, 2015 12:19 pm    Post subject: January 1953 'Smooth Gate SC Reply with quote
Bought this from Matt for some months ago. Haven't almost been doing anything on it until today when I started a little smooth!
Got it delivered by Dai from uk so that was perfect! Thanks mate.
I got it drivable for a meeting here in Sweden last month. Borrowed an engine and drove around on the field. So funny! Smile
Video:
_________________________________________________________
Layed my hands on it with the welder for the first time today
New master cylinder with cool ATE cup
New reinforcement pillar from AutoCraft. Wrong, as always... had to cut and reweld it. Made it easy for me but it'll do.
Smile
Type 2 -53 smooth Gate SC (o\!/o) Type 1 -50 |o\ /o| Type 2 -55 Barndoor kombi
...........Driving barndoor to HO 2017............
spit nolan
spit nolan is offline
PostPosted: Wed Aug 26, 2015 1:34 pm    Post subject: Reply with quote
Awesome Jesper, good to see it moving under its own steam. Remember seeing the first time before the cab was on and thinking Matt was mental. Still think Matt's mental now though hahaha! Don't forget about the 55 though dude I want to see it at Hessich!
1963 Squareback
1967 Porsche 912
RSVP VW
52panelvan
52panelvan is offline
PostPosted: Wed Aug 26, 2015 1:59 pm    Post subject: Reply with quote
Nice one getting it moving! I remember sitting on the seat base with no cab around me in Dai's barn a few years back wondering if it would ever get done...
Barndoor side supports are thicker as they get near the bottom from memory. That's probably a later bus support hence why it doesn't touch the sill and you had to change it.
Austrian Kohlruss Deluxe
January 1954, 20-072397
The Kohlruss Barndoor Restoration - https://www.facebook.com/groups/641684399225180/
Instagram - rustykohlruss
Hellberg
Hellberg is offline
PostPosted: Thu Aug 27, 2015 1:03 pm    Post subject: Reply with quote
small progress today
Gareth, I'll do what I can to drive the 55 to Hessish! Very Happy
Hellberg
Hellberg is offline
PostPosted: Mon Dec 07, 2015 8:29 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
Time to make a small update maybe.. Haven't been doing too much on it but small steps! Smile
Bought an engine, 30hp
Also bought an okrasa kit Wink
Felt like christmas Laughing This was like 2-3 months ago
so now I had to assemble it!
Done!
Took me around a day to put it all together! Need to mount the exhaust and plates and then put it in the truck and try to fire it up!
Also some progress on the cab, not so many pics of it tho Laughing
Pod is in!
And I've tried to renovate the fuel tank with POR15. Waiting for the ''paint'' to dry and then we'll see if it works Cool
cheers!
Hellberg
Hellberg is offline
PostPosted: Wed Dec 23, 2015 12:16 pm    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
Almost done with the welding Smile
Panels inside the cab had to be welded
Pod looks way better now too Smile
primer
cab separation panel was repaired and welded
Steeringwheel was taken out carefully...
Looks like new Smile
Primer sprayed on
tried the blue paint
Fuel tank is done!
made one later splitbus door correct for barndoor Smile
Hellberg
Hellberg is offline
PostPosted: Sat Jan 16, 2016 7:11 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
A splitbus front bumper fresched up
Patina? Laughing
throttle pedal fixed
Wheelhouse repaied
must look right Smile
New bolt on the battery tray
Brakes
Blasted the front floor
Some paint Smile
https://www.thesamba.com/vw/gallery/pix/1448894.jpg
weld in adjusters in the front beam
took the gearbox out and waiting to mount the type 1 4:12 in
New rubber to
Brian_1952
Brian_1952 is offline
PostPosted: Sat Jan 16, 2016 10:07 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
I would've liked to seen a picture of the gas tank brackets before you install the tank I just have a question about them would've liked to seen yours
(20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal
Hellberg
Hellberg is offline
PostPosted: Sun Jan 17, 2016 2:02 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
I've already installed the gas tank with new fuel lines etc. What did you want to know? Smile
Hellberg
Hellberg is offline
PostPosted: Sun Jan 17, 2016 2:05 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
Brian_1952
PostPosted: Sun Jan 17, 2016 6:16 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
Can you tell me if the brackets are flat where the well nuts are attached like this
Or they have a dimple like this
(20-035778)kombi
Hellberg
Hellberg is offline
PostPosted: Sun Jan 17, 2016 8:04 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
I'll check under the week if I remember, but I'm almost sure that they aren't flat..
Brian_1952
PostPosted: Sun Jan 17, 2016 10:24 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
Cool thanks ...it may be a 52 thing
(20-035778)kombi
Hellberg
Hellberg is offline
PostPosted: Sun Jan 17, 2016 11:05 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
I just tried to check but since I've screwed the tank in, the washers is in the way so can't see Sad
Hellberg
Hellberg is offline
PostPosted: Tue Feb 02, 2016 10:51 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
fixed the type 1 spindles. still need some work but I hope that I can mount them soon!
Mounted adjustable springplates made by Franke and put in the new gearbox!
Something like that Smile
Also been connecting the new loom and got almost everything working!
All glass is in too
And engine Smile
mandraks
mandraks is offline
PostPosted: Tue Feb 02, 2016 12:46 pm    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
great stuff, always exciting when the motor fires up, and the semaphores pop out. At first i wondered what was wrong with the motor, but it was just the beetle exhaust. A proper bus exhaust will fix that Smile
regards
Uli
Trevor P
Trevor P is offline
PostPosted: Tue Feb 02, 2016 6:19 pm    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
Cool to see this thing coming together piece by piece. Those gates look familiar Wink
Keep up the good work!
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy
Hellberg
Hellberg is offline
PostPosted: Wed Feb 03, 2016 11:40 am    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
Yes, just took what I had Smile
I actually realized last week when I looked in your thread that it's the same gates! cool Laughing think I heard myself saying ''what the f...'' when I realized Wink
Hellberg
Hellberg is offline
PostPosted: Fri Feb 19, 2016 12:16 pm    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
I've test-driven it now, feels great! Smile
busben
busben is offline
PostPosted: Fri Feb 19, 2016 12:29 pm    Post subject: Re: January 1953 'Smooth Gate SC Reply with quote
Looks ace Jesper. You've done well with the paint dude, it looks really sweet now! Wish it was sat on my driveway!! Smile
Page 1 of 4
