66 resto ghia Samba Member
Joined: May 27, 2015 Posts: 19 Location: Southern California
Posted: Sun May 31, 2015 7:38 pm Post subject: brake backing plate question |
cant seem to find a lt rr backing plate for a 1966 ghia, anybody know if the 68 and up will fit? |
c21darrel Samba Member
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Mon Jun 01, 2015 2:50 pm Post subject: |
I doubt it will be a match. 66 used short axles and a different type of bearing retainer and seal system. Doesn't yours have the spinning oil slinger? 68 and up would have the oil weep hole system through the backing plate. Possibly even double jointed IRS instead of swing axle. Makes me think there will be a difference or differences. _________________ 1958 Karmann Ghia owner |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Mon Jun 01, 2015 3:09 pm Post subject: |
c21darrel wrote: |
. . . you need 65-67. |
YES!
And one from a Beetle will work also. _________________ Jesucristo es mi Seņor y Salvador! |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Mon Jun 01, 2015 7:02 pm Post subject: |
WELCOME.
Check dutchboy mike over in Irwindale. I don't know where you are at but Mike has plenty of adds here. Looks like his name here is [email protected]. He operates a shop over in Irwindale a few miles east from the Irwwindale drag strip.
Also Russ' in same town. Should be plenty here in SoCal.
Hope this helps, Bill. |
Posted: Mon Jun 01, 2015 8:45 pm Post subject: |
thanks for all the responses, I am really close to Irwindale. will check them out. |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Tue Jun 02, 2015 7:08 am Post subject: |
I have a related question.
My installation has dropped spindles by CB Performance. The version with drum brake spindle with ball joint beam. It is installed with CSP front disks having bearings compatible with the drum brake spindle.
There is no backing plate provided. So I am wonder if running without a backing plate would pose a problem with stones and debris fouling in the brakes? Further, has anyone used this spindle with a backing plate? Perhaps some one has engineered a backing plate that worked?
Speak to me my friends
Nichoals _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Tue Jun 02, 2015 8:35 am Post subject: |
Not sure on a ghia, but I never ran backing plates on any of my offroad vehicles and NEVER had an issue with front brakes (mud/sand/dirt) |
Posted: Tue Jun 02, 2015 8:51 am Post subject: |
I am not running a backing plate on my ghia front discs either, but then again, I'm not running it in the rain or through muddy roads. I imagine the factory did it with good reason, but I do know from reading on here that many have skipped it, to no reported ill effect. _________________ 1958 Karmann Ghia owner |
Posted: Wed Jun 03, 2015 9:02 pm Post subject: |
well, airheads was no help, sent me the wrong side and wrong year...but scored a set out of the classifieds here from a local member. |
jaunio Samba Member
Posted: Tue Feb 02, 2016 5:19 pm Post subject: Re: brake backing plate question |
P.O. put long axles and tubes on my 66 ghia vert, I lowered the arse and had NO tire clearance to the wheel opening. I put 66 Beetle short axles and tubes on and have lotsa tire clearance. Trouble is the backing plates are loose, even when I tourque the bee jesus outta the bearing caps, maybe the threads are bottoming out on the axle tube, put a couple a lock washers on the bolts and still the backing plates are loose. WTF. Cant drive like that!! I dunno, I'm perplexed. HELP!!! |
pistolpetecowboy Samba Member
Joined: February 10, 2014 Posts: 122 Location: Oklahoma
Posted: Wed Feb 03, 2016 4:35 pm Post subject: Re: brake backing plate question |
jaunio wrote: |
Check to make sure your axle tube retainer on the side of the transaxle is not warped. If it is your axle will stick out of your tube a fraction too much at the wheel bearing end and nothing will tighten up correctly. It's been a few years since this happened to a '68 of mine but I think I remember it mostly correct. Had a guy press off the casting, replace the warped retainer, then press the casting back on the tube. Took all the play out. _________________ 70 Beetle, 70 Beetle, 71 Beetle, 71 Super, 73 Super, 74 Beetle, 2000 Vintage Speedster, 2020 Jeep Renegade, 71 Squareback |
