Correct cylinder tins for 1950?
1953Volks
1953Volks is offline
PostPosted: Thu Feb 04, 2016 6:17 pm    Post subject: Correct cylinder tins for 1950? Reply with quote
I have a question regarding cylinder tin for my 1950 engine, are all two piece cylinder tins the same or are the tins for KDF cars different? I just want to make sure a I am purchasing the correct tins.Thanks for your help.Pictures will be a tremendous help.
1950 Hoffman 11 G 1-0174999
1953 11G
1955-6 GHIA 1-0925660
1962 DOUBLE CAB
1957 11G
1958 Single cab
1967 camper bus
1959 ragtop 2226460 (in Japan)
1964 Karmann Ghia
1964 Cadillac coupe De Ville (a.k.a. Husslah)
virtanen
virtanen is offline
PostPosted: Thu Feb 04, 2016 11:51 pm    Post subject: Re: Correct cylinder tins for 1950? Reply with quote
They are not all the same.
Early tins has no cylinder number stamps. Also they have different outlines at some areas for the early engine case pre49.
A cut out added when thermostat introduced.
The early on the left.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
