1969 Bug Build
Page: Previous  1, 2, 3 ... 8, 9, 10, 11, 12  Next
zodlaw
zodlaw is offline
PostPosted: Mon Dec 21, 2015 1:21 pm    Post subject: Re: 1969 bug yard find build Reply with quote
Got it back together 4 clicks on inside. What fun trying to get it on the ground.
for some reason one side is closer than the other. I think I have two dif fenders on the front.
just enough to move the bug which is what I want.
Jingle BAM!
Perfect!
Don't think I will get much more done today. Now that I have my base I can build the bags up off of the lowest ride height which would be for parking or rolling really low and slow. My biggest thing is I want to still be able to move if my air fails for some reason. The last thing I want is not to be able to move because is layed out on the pan. Razz More updates in the next few days.
68 build that had been sitting for 18yr in a garage.
http://www.thesamba.com/vw/forum/viewtopic.php?p=8119987#8119
Bagged 69 pile (SOLD)
http://www.thesamba.com/vw/forum/viewtopic.php?t=591100&start=0
63Ragtop NZ
63Ragtop NZ is offline
PostPosted: Mon Dec 21, 2015 4:59 pm    Post subject: Re: 1969 bug yard find build Reply with quote
I dig it.
Cool
If you can't join them, beat them!
zodlaw
zodlaw is offline
PostPosted: Thu Dec 24, 2015 2:00 pm    Post subject: Re: 1969 bug yard find build Reply with quote
Well because the rear is so low with almost full sized tires, which I want. I ran into some problems with some clearance on the back package tray. I did not want to do this but it looks like it has to happen anyways.
Cut line
Cram it in there, still trying to figure out the mounts but I am pretty close. I don't think I will get much more done today though.
It looks like I will have to modify the back seat if I want it to fit.
I really don't want to have no back seat cause I really never like that type of set up. More ln a few days
mfergel
mfergel is offline
PostPosted: Mon Dec 28, 2015 11:28 am    Post subject: Re: 1969 bug yard find build Reply with quote
Love the way it's turning out so far.
My 1970 Standard build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=564935&postdays=0&postorder=asc&start=0
zodlaw
zodlaw is offline
PostPosted: Mon Dec 28, 2015 10:37 pm    Post subject: Re: 1969 bug yard find build Reply with quote
I spent most of the day trying to figure out how to do this. I know that when you bag is flat you want it to be strait up and down. So instead of putting the bag in, I made a fixture at the compressed height.
Because the angle is pretty far up I had to angle the top mounting plate so it would be strait up and down. Most of this I am making it up as I go not much info on bag mounting.
I spent a lot of time just fitting this side up. I still have to tie the front into the down tube.
Here is the back side
Here is the the tube that is going into the torsion tube. I will also that into the spring plate back with a small connection. I am trying to get as much triangles in as possible. I should be pretty good as far as flexing goes.
I might have to cut some access holes in the back luggage tray to weld up the top. I really wanted to tie one bar all the way across but it was just not going to line up. Once I get the other side fit up I will tie them both together in the center with some square tube as the load will not be in the middle only on the sides. If this was not such I pile I would not be going this low. It would have been much easier to just drop the tire size down and put an airkewl kit in. Razz One other thing I should point out is if you run this low all the time the cv joints will go out. One way to make them last longer is put thing cv joints in as they have a wider range of travel. More to come in a few days.
zodlaw
zodlaw is offline
PostPosted: Tue Jan 26, 2016 9:44 am    Post subject: Re: 1969 bug yard find build Reply with quote
Someone asked in a pm where the rest of the build is. Smile Its still here, I just got some more material and still looking for a 220 welder. I had to put it back on the ground so I can move it around though. Sad
zodlaw
zodlaw is offline
PostPosted: Fri Feb 05, 2016 12:43 pm    Post subject: Re: 1969 bug yard find build Reply with quote
Well where to start. First off I would like to thank BG Brian for letting me borrow his 230 welder. Its Great that the Samba guys help out when they can. So I am able to move forward now. All I can say is if you have the chance to buy one of these Do it. It very flexible and nuts on the settings.
Notice the old Betsy in the back. She does not cut it when it comes to thicker material. I took today off of work to do some wood lathe work with my son at a friends house so this morning worked on the bug some. Its been a while and it was good to get back to moving forward.
Got some more of the nasty old tar paper up and the cross brace off.
The problem is I could not get the bolt out on the brace on the pass side. So I just wiggled it and bingo, I have a new hole.
I told my son now that I got almost all the mold out and the rat crap out he can really start helping on the interior. The plan is to shave all the tabs and the dash and repaint down the road. I feel this is a good time for him to start to really learn how to weld. He already welded up a battery bracket on my 79 subie brat that I sold few years ago, he was 7. Razz
So on to the bag mounts. The tops are welded in finally. I had to cut my tacks several times to get them to be strait with the hole in the front. If you have not noticed that the back tray is out. Its so much easier to get things fit up.
The left side
The right side
Going to have my 6yr old clean the floor pans out she is excited to help. I try to have them involved as much as possible but I don't force them to do it. Razz
Prob be a bit before I get some more done.
zodlaw
zodlaw is offline
PostPosted: Fri Feb 05, 2016 5:57 pm    Post subject: Re: 1969 bug yard find build Reply with quote
So I got this from my friend who cert these and pressure test them. I had talked to him last year. He know what I needed psi wise and came up with this. I like it, it was a good price too and free. Its suppose to be 3 1/2 gallons but air wise I think prob closer to 4 1/2 gallons. Going to put a high pressure valve on it with a drain. Will see how it works out if it does not no big deal.
zodlaw
zodlaw is offline
PostPosted: Sat Feb 13, 2016 6:03 pm    Post subject: Re: 1969 bug yard find build Reply with quote
Got some time not much, but I was able to focus and get a lot done fit up wise.
The left side is not done still have few other braces to put in.
Back side drivers still going to do another cross brace on the back
Pass side back
Hope to get back on it next week end and glad its moving forward. Smile
DAWGNME
DAWGNME is offline
PostPosted: Mon Feb 15, 2016 8:38 am    Post subject: Re: 1969 bug yard find build Reply with quote
Welcome back ! Let me find my seat Popcorn
zodlaw
zodlaw is offline
PostPosted: Mon Feb 15, 2016 9:35 am    Post subject: Re: 1969 bug yard find build Reply with quote
Yeah it will be nice just to air it up and pull out of the driveway with out getting bottomed out on the exhaust and stuck. Laughing
zodlaw
zodlaw is offline
PostPosted: Tue Feb 16, 2016 12:09 am    Post subject: Re: 1969 bug yard find build Reply with quote
My son and I threw this together. I don't think the pump can handle it. four and half gallon tank. My other tank took minute and thirty seconds. This tank was going on 4 min to fill. It still looks cool though and I have an oil filled gauge too. going to check on it in the morning to see how much air I lost. Ran out of pipe tape so have to redo it prob. Also might throw a 12v small fan on it as it was getting pretty warm. I think it might be too much tank Sad Going to mess around with it some more. If all else fails will revert back so no loss. I am just worried about the bags in the back not having enough air. Smile
DAWGNME
DAWGNME is offline
PostPosted: Wed Feb 17, 2016 6:18 pm    Post subject: Re: 1969 bug yard find build Reply with quote
Zodlaw I am working on a similar setup mine also takes about 7 mins to fill from empty. Not sure how much gallons the tank is.
zodlaw
zodlaw is offline
PostPosted: Wed Feb 17, 2016 7:33 pm    Post subject: Re: 1969 bug yard find build Reply with quote
That tank looks big. Mine takes 5 min to fill up from empty but after it kicks back on at 110 or so and takes under 2 min to top off to 140. I am prob at 5 gallons on mine yours looks more like 8 or so, you might need another pump if you use it a lot. I am resealed my fittings today and going to let it sit overnight at 140 and see where its at in the morning. The tank I am using is suppose to hold 4 and half gallons of water but air is prob five. I would say 5 gallons is pretty good size. You could prob sell that one and get a smaller one if you wanted or just buy another pump but that would prob be pretty hard on one battery.
DAWGNME
DAWGNME is offline
PostPosted: Thu Feb 18, 2016 5:20 am    Post subject: Re: 1969 bug yard find build Reply with quote
Thanks for the advice I will sure ck into that. Let us know how the leak test turns out. Are you only using Teflon tape?
zodlaw
zodlaw is offline
PostPosted: Thu Feb 18, 2016 8:21 am    Post subject: Re: 1969 bug yard find build Reply with quote
I checked this morning and did not drop at all from 140psi. I use five wraps of tef tape and a dab of Loctite pipe sealant. Thats what we use at work and it does great. I also have a viair 175psi pressure relief valve showing up so if the pressure switch fails and pump does not want to stop. Smile. These tanks are tested up to 200psi so I think it will pretty safe the way I have it set up. I will prob have to drain it every so often.
zodlaw
zodlaw is offline
PostPosted: Fri Feb 19, 2016 7:43 pm    Post subject: Re: 1969 bug yard find build Reply with quote
I got to spend little time with my son and show him how to use the porta band saw. Showed him a few things and he fit and tacked up the top center brace. Smile
Good times. Its always good to know how to fit up and weld. Razz
I am going to do two more braces on the back side. I will clean it and weld it out. Then its time for some air bag testing. I can not even wait, been long time coming. Hope to get an hr or so tomorrow and should be able to finish it up. Twisted Evil
zodlaw
zodlaw is offline
PostPosted: Thu Feb 25, 2016 9:23 am    Post subject: Re: 1969 bug yard find build Reply with quote
Last week end got one back side brace done. I had about 20 min or so to get it done. At this pace I am going to be 50 by the time it gets drive able. Laughing
Tomorrow going to try and at least finish the fit up. I can peck away at the welding during the week 5 or 10 min here and there. Rolling Eyes
zodlaw
zodlaw is offline
PostPosted: Thu Feb 25, 2016 11:22 pm    Post subject: Re: 1969 bug yard find build Reply with quote
Got 20 min and finished up the last back brace today. Now just need to clean up the braces and weld it out. Shocked
DAWGNME
DAWGNME is offline
PostPosted: Fri Feb 26, 2016 5:51 pm    Post subject: Re: 1969 bug yard find build Reply with quote
Popcorn
Page 9 of 12
