jeffros 58 Samba Member
Joined: January 01, 2009 Posts: 349 Location: jackson mi
Posted: Thu Jan 28, 2010 5:20 pm Post subject: Louver sanding and primering? |
finishing the primering and wet sanding on my 58 but do not like the way the inside of the louvers over the rear deck lid is any good way to clean up a bit or sand with out removing the lover section ? the car had been soda blasted and they were real nice before metal etch primer and filler primer . any help would be great !! |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
Posted: Fri Jan 29, 2010 5:34 am Post subject: |
there is no easy way,
if you don't sand then it will be textured
for show cars we remove vents
for drivers we will tape off the paint
and black out that area with a rubberized
truck bed liner . _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
Posted: Fri Jan 29, 2010 7:38 am Post subject: |
do you remove the bottom section at the sopt welds and all the way to the vertical of the package tray? so it would be the complete pannel.any photos of a completed one to show me the seams . |
spook Samba Member
Posted: Fri Jan 29, 2010 7:57 am Post subject: |
this is it in paint,
use a spotweld cutter with care, do the panel like any other
(weld, fix, seal,prime,block,paint) panel,then when eveything is ready to
go back together, use a panel adhesive to bond it back in place. _________________ www.airkooledkustoms.com
SBS US #10
Posted: Fri Jan 29, 2010 2:05 pm Post subject: |
thanks spook will look at the removal of vents and see what is needed . |
crowe66 Samba Member
Posted: Sat May 15, 2010 7:19 am Post subject: |
anyone have any pics of the locations of the welds to remove the louvered panel? |
slowtwitch Samba Member
Joined: July 03, 2004 Posts: 730 Location: just north of philly
Posted: Sun May 16, 2010 3:01 am Post subject: |
here are some pics of my louver removal...
the spot welds at the firewall, I'm not going to grind these done as they help in reinstalling the louver.
the spot welds under the vents, watch that spot weld cutter..
the piece removed..
After welding up the holes and some filler...
When all is done, I will be using panel adhesive to reinstall the louver _________________ pete |
Posted: Sun May 16, 2010 7:41 am Post subject: |
thanks man that is just what i needed. good job too! |
Posted: Sun May 16, 2010 8:42 am Post subject: |
I forgot to mention that I used a right angle drill to get to the spot welds. I bought a right angle drill from harbor frieght that did the job. _________________ pete |
_Pascal_ Samba Member
Posted: Mon Sep 24, 2012 6:47 am Post subject: |
sorry for bringing up this old topic but i have a (stupid) question.
If you attach the louver using an adhesive and you ever need to access the area again, how will you remove it? |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Thu Oct 11, 2012 12:52 am Post subject: |
Chainsaw. _________________ Plate of shrimp |
planenut Samba Member
Posted: Sat Feb 06, 2016 4:54 pm Post subject: Re: Louver sanding and primering? |
Remove with heat gun. |
cjnfiremn Samba Member
Joined: June 05, 2006 Posts: 26 Location: Eunice, Louisiana
Posted: Sun Nov 04, 2018 10:58 am Post subject: Re: Louver sanding and primering? |
Sorry to bring up old topic, but what would it hurt if you left out the piece once you remove it? Seems like you would get more air flow. It may weeken things from hood attachment. _________________ Sam
'69 Std Beetle
God Bless America |
