oilspot Samba Member
Joined: July 11, 2002 Posts: 909 Location: Southern NM
Posted: Mon Mar 21, 2005 6:14 am Post subject: |
nick1 wrote: |
i just got a allstate trailer but i need a new tire. did you have to get one for yours. and if so where is a good place. |
480/8 tires
$13.98 at walmart. Common size for boat trailers. |
coad Samba Scapegoat
Posted: Mon Mar 21, 2005 7:03 am Post subject: |
oilspot wrote: |
nick1 wrote: |
480/8 tires
Make sure it is a trailer tire and not a tire for a motor scooter. Scooter tires are very rounded at the tread and they nake a trailer handle very poorly.
The cute little whitewall 4.80 X 8 tires are all scooter tires-- resist the temptation. |
EvilBus Samba Art Critic
Joined: June 18, 2004 Posts: 1523 Location: Texas Damnit!
Posted: Mon Mar 21, 2005 8:45 am Post subject: |
I agree that the symptoms you describe aren't the brackets, but when you slam on the brakes or put too much load on them, they'll taco shell. _________________ - JHC de Tejas - |
LHG Samba Moderator
Joined: April 13, 2000 Posts: 1855 Location: LostHillsGuy, CA
Posted: Mon Mar 21, 2005 9:13 am Post subject: |
Here is the new and improved version.
Changes...
Added gussets,
doubled tounge thickness,
lowered the hitch pin plates (holes yet to be drilled).
_________________ Brian O'Kelly
Central Coast Chapter, CA - Vintage Volkswagen Club of America
www.centralcoastvwclub.com
www.facebook.com/groups/vintagevwclub/ |
Posted: Mon Mar 21, 2005 9:15 am Post subject: |
LHG wrote: |
Changes...
Added gussets,
Better, but'd I'd still go U channel like an OG Bumper Bracket. what are you fastening them with, the holes look awfully small? Nice job though. _________________ - JHC de Tejas - |
LHG Samba Moderator
Posted: Mon Mar 21, 2005 9:26 am Post subject: |
The channel on the brackets is quite thin. These are 3/8" and very stout. When they are attached you can jump on one and there is no play or give. I used the existing two bumper bolt holes and added a third. So each side is attached with 3 - 3/8" bolts. _________________ Brian O'Kelly
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Mon Mar 21, 2005 8:55 pm Post subject: |
I put a 25pound weight right above the wheel in the trailer and it stopped any wheel bounce or vibration. lonotch _________________ It's not about the window, it's about the people.
German Folks |
JoelH Samba Member
Joined: October 16, 2003 Posts: 1312 Location: North Dakota
MonkeySee Samba Member
Posted: Thu Apr 14, 2016 9:07 pm Post subject: |
EvilBus wrote: |
LHG wrote: |
Changes...
Added gussets,
Interested in making another set? |
I second that question as my bus is too tall for any kind of bumper mount.
And I plan on going a little higher.
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sun Mar 19, 2017 10:15 am Post subject: |
Does anyone have the trailer's forward-arm pin hole height... to ground... dimension that works?
In other words... what is a good center of pin to ground distance?
(not using a scooter tire... but a normal trailer tire on the stock rim)
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
copellos Samba Member
Joined: February 18, 2004 Posts: 937 Location: sonora ca
Posted: Sat Mar 25, 2017 3:00 pm Post subject: Re: Allstate Trailers and Wheel Wobble |
The dreaded all state hop happened to everyone Sam has had several on several vw car bus bug I've had it on a ghia and now my baywindow... and no there is no cure..it happens when it wants too.
Some help ..add some weight in the trailer always even if it a bag of sand and tire pressure can help.. |
AngieB Samba Member
Joined: February 27, 2017 Posts: 135 Location: Oregon
Posted: Thu Mar 21, 2019 10:38 am Post subject: |
northern tool has log splitter tires.. you can get the exact set up.. just the bearings are different.. so you must use a spacer. hope this helps.. I just did this to my trailer a few days ago.. you can also join the facebook page singlewheel trailers.. we are on there helping eachother
nick1 wrote: |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Mar 21, 2019 10:55 am Post subject: Re: Allstate Trailers and Wheel Wobble |
copellos wrote: |
I had a clamshell allstate that got the hop pretty bad. I actually solved the problem.
after the last time it did that, I sold it. Problem solved. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Thu Mar 21, 2019 2:23 pm Post subject: Re: Allstate Trailers and Wheel Wobble |
crofty wrote: |
copellos wrote: |
after the last time it did that, I sold it. Problem solved. |
_________________ Some people are so busy being clever they don't have time enough to be wise. |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Sat Mar 23, 2019 6:47 am Post subject: |
nick1 wrote: |
Check out motor scooter parts sellers.
I have a Motorvation motorcycle trailer that needed tires.They are a non standard size but found some at a motor scooter parts place online. _________________ '72 Beetle |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1037 Location: Calgary, AB
Posted: Sat Mar 23, 2019 8:02 am Post subject: Re: Allstate Trailers and Wheel Wobble |
crofty wrote: |
I got a clamshell last year. After I spent a couple days of trial and error with adjusting the wheel bearings, angle of the trailer, and testing different amounts of weight in the back, I cured the hop. In fact, I drove well over 3000 miles with the trailer and never had it hop even once after the initial dial-in. Too bad so many others have had so many issues with it. Maybe I got lucky? |
AngieB Samba Member
Posted: Sat Mar 23, 2019 12:01 pm Post subject: Tire |
Northern tool has log splitter tires that work. Just need a spacer for the bearing gap
nick1 wrote: |
Posted: Mon Mar 25, 2019 9:27 am Post subject: Re: Allstate Trailers and Wheel Wobble |
CanStan wrote: |
crofty wrote: |
Maybe! I opted for something more stable...
Posted: Mon Mar 25, 2019 11:47 am Post subject: Re: Allstate Trailers and Wheel Wobble |
I’d trade my Allstate and my Besco folding trailer for one of those. |
JLT Samba Member
Joined: September 23, 2008 Posts: 162 Location: Sacramento CA
Posted: Sat Sep 17, 2022 10:15 am Post subject: Re: Allstate Trailers and Wheel Wobble |
In the mid-sixties, Sears finally got smart and put in an adjustment for their latest model of SWTs, so that the angle of the trailer could be modified. The trick is to run them slightly nose-down, as previous posters have noted. I don't have an exact angle, and suspect that it's different for the various makes and models. I arrived at my estimate through trial and error.
I've also found that the trailer is much happier if I'm putting at least fifty pounds of cargo in it.
I didn't see the URL for my write-up on Allstate single-wheel trailers anywhere else on the thread, but here it is:
http://www.dragonwing.biz/sears%20swt.htm _________________ -- JLT
Present bus: '71 Dormobile Westie
with an Allstate single-wheel trailer
Past buses: '61 17-window
'70 Frankenwestie
'71 Frankenwestie |
