Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Apr 25, 2016 1:38 pm Post subject: How does my engine sound? |
The engine: 1700cc duel webbers (new) electronic points, no vacuum advances that I see. I think it is fairly stock, but it may have been rebuilt before.
So it's been sitting about ten months now. I changed out the gas, gas filter, oil, and oil filter. Please let me know what else you think I should check up/tuneup or if I should just run it. (I have tin and such to get on still)
https://youtu.be/fIJaX5OvlAQ
**edited whoops. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Mon Apr 25, 2016 1:59 pm Post subject: Re: How does my engine sound? |
Pretty damn quiet |
DHVW Samba Member
Posted: Mon Apr 25, 2016 2:10 pm Post subject: Re: How does my engine sound? |
Maybe the question is rhetorical ... |
Howard 111 Samba Member
Posted: Mon Apr 25, 2016 2:15 pm Post subject: Re: How does my engine sound? |
Or a Volt. Anyone ridden in an electric yet? It's silent at a stop light, and mostly road noise moving. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Mon Apr 25, 2016 2:25 pm Post subject: Re: How does my engine sound? |
How? Mostly it's the expanding gases pulsing pressure waves out your muffler, hence sound. _________________ "...swingaxle...transaxle...same diff." |
vamram Samba Member
Posted: Mon Apr 25, 2016 2:48 pm Post subject: Re: How does my engine sound? |
Nice steady idle, but what is the knock that you can hear? _________________ Eventually, "we are what we pretend to be.
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Mon Apr 25, 2016 3:13 pm Post subject: Re: How does my engine sound? |
vamram wrote: |
Nice steady idle, but what is the knock that you can hear? |
My guess is, since oil was recently drained and changed, the new oil yet didn't reach all places or splashed enough. |
Posted: Mon Apr 25, 2016 3:17 pm Post subject: Re: How does my engine sound? |
PumaVW79 wrote: |
vamram wrote: |
I'll run it longer tomorrow and let you know if it goes away. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Danwvw Samba Member
Posted: Mon Apr 25, 2016 3:39 pm Post subject: Re: How does my engine sound? |
That Knock sound is timed with one valve's movement! Is your engine a Hydraulic Lifter Engine? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Apr 25, 2016 5:45 pm Post subject: Re: How does my engine sound? |
Danwvw wrote: |
That Knock sound is timed with one valve's movement! Is your engine a Hydraulic Lifter Engine? |
I should not be hydraulic. What's your thoughts on it being with one valves movement? Needs a valve adjustment? And timing set? I haven't been running it much since I got it back. Just a minute or two Here and there to move the oil around, so it shouldn't be detrimental. (I don't remember that noise when I got it for restoration ten Months ago. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Mon Apr 25, 2016 5:53 pm Post subject: Re: How does my engine sound? |
Sounds good IMO
i assume it has solid lifters |
Danwvw Samba Member
Posted: Tue Apr 26, 2016 1:43 pm Post subject: Re: How does my engine sound? |
Those 1700's were pretty solid holding valve adjustment well, it should clear up with the valve adjustment you may have to adjust them at different valve timing than Just TDC & BDC positions to clear the knock up. Figure out which one it is. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Wed Sep 21, 2016 12:12 pm Post subject: Re: How does my engine sound? |
Hey guys, just wanted to post a quick update on this, for the edumafication of us all
This car was subject to substantial bodywork with no crankcase breather hose hooked up. When we pulled the left side valve cover for a routine check, we found NO oil residue. None. Zip. Zilch. Nada. The rocker box was as dry as a bone, and the gold indication of past burnt oil was smooth and dry. We removed the rocker arms, and blew through the pushrods with carb cleaner, and found brown-ish and grey-ish residue coming out several pushrods in droves. Upon starting the engine again, we were rewarded with oil coming out the pushrods and rocker arms as designed.
I can not understate, enough, the importance of crankcase hygiene, even with an oil filter! Too many people haphazardly adjust valves on a dirty slab with both valve covers off on a windy day, or then ignore the fact that their crankcase breather must connect to filtered air, not JUST for emissions, but for sitting when the crankcase cools and sucks in air too!! (Hot air is larger in volume, so when an engine cools, air is sucked into the crankcase through the breather system. Volkswagen filtered this air. Do you?)
A routine valve adjustment saved this engine. I hope we can all pay better attentional as a collective.
www.airschooled.com |
Posted: Tue Dec 06, 2016 1:09 pm Post subject: Re: How does my engine sound? |
**Engine is of unknown origin.**
Alright. Well... she sounds hideous... My best guess is that due to poor control of the crankcase cleanliness I got a bunch of bando dust and other crap into my engine while doing my body work, and that is clogging up my smaller oil passages.
I'm looking for input on what I should be looking for when doing my tear down. If you hear that tick... Idea's? I get backfiring through the carbs on cold starts. And the starts have becoming more and more difficult. Though there was a point where it became significantly more difficult, suddenly. Not sure what is going on. Questions?
I'm hoping to do a super cheap rebuild if needed. I'm currently planning on removing the engine this winter for a top end cleaning/deconstruction.
Current Game Plan: (1)Change oil to something cheap to rinse it out before removing the engine. (2) Remove Engine. (3) Take off engine tin/alternator /accessories. (4) Break into heads, inspect valves. (5) Inspect Bottom end for excess thrust play. (disassemble to replace bearings only if required. I will avoid breaking into bottom end if at all possible) (6) re-assemble. Replace throw-out bearing and re-install.
