bluebus86 Banned
Posted: Thu Apr 28, 2016 11:00 am Post subject: Re: Fuel Filter? |
a $40 clamp for a 89 cent filter
I went with a slightly larger filter, with a metal housing, nice barbed ends too. I have found many of the little plastic ones have no barb, infact some have a slight taper down towards the tip!
I no longer use the little plastic filters although having a clear body does aid in seeing how much dirt they collect.
I now exclusivly use lined hoses, SAE 30R9 rated. I got tired of frequent replacement of the cloth wrapped hoses. I got to many vintage cars to put them on a every two or three year hose change schedule. If i did Id be replacing hoses on a car every few months. just keeping up with brake fluid flushing is time consumming. I have converted a couple of my cars to silicone fluid, so they dont need the frequent flushing. keeping up a small fleet can be time consuming even if miles driven is small, things still need to be maintained!
I highly recommend the newest lined hoses. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Harris Samba Member
Posted: Thu Apr 28, 2016 4:29 pm Post subject: Re: Fuel Filter? |
So is this guy an authority on the subject???? And by What means! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Thu Apr 28, 2016 5:26 pm Post subject: Re: Fuel Filter? |
splitjunkie wrote: |
I would have used captive nuts and made it so you only have to remove one screw and the right section would clamp around the grommet and rotate out of the way. That would make it much easier to replace the filter. |
Even better would be to have one end just hinge away from the filter. Held closed with a spring loaded hinge or a spring strung from one end to the other. Be helpful when ever the filter clogs up on a part of the road that one would not want to be stuck on for very long. _________________ In Stereo, Where Available! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Thu Apr 28, 2016 5:30 pm Post subject: Re: Fuel Filter? |
Harris wrote: |
Go pick a fight with someone else. A bracket that mounts to the heater box was shown, so I showed an alternative. I don't make it, profit form it or endorse it.
Personally I have my fuel filter zipped tied to the mechanical oil pressure hose that runs from my engine to the body of the car.... it works for me. I don't really care if anyone else likes or dislikes it.
_________________ Glenn
Member #1009
#BlueSquare |
Harris Samba Member
Posted: Thu Apr 28, 2016 5:51 pm Post subject: Re: Fuel Filter? |
Glenn wrote: |
Harris wrote: |
It was entitled by you that this was the correctt solution. I wanted to know who made that statement--you or someone else. Chill out, Not picking a fight. Get your facts straight Glenn |
Glenn Mr. 010
Posted: Thu Apr 28, 2016 6:07 pm Post subject: Re: Fuel Filter? |
Harris wrote: |
Wrong.... I'll make it easy for you.
Helfen wrote: |
I saw that too vapor lock induction. |
Helfen wrote: |
If you are going to do a bracket for the filter do it the right way. This is the right way. away from the heat, away from the boot. Nice job!!!! |
Harris wrote: |
Get your facts straight |
Member #1009
#BlueSquare |
Harris Samba Member
Posted: Thu Apr 28, 2016 6:42 pm Post subject: Re: Fuel Filter? |
boo boo
Glenn Mr. 010
Posted: Thu Apr 28, 2016 6:47 pm Post subject: Re: Fuel Filter? |
Harris wrote: |
No fucking vapor who ever in the hell bought that up. |
Just get your facts straight before you accuse someone of something they didn't do.
And YES... i'm not an authority one many things. But i never said i was.
Moving on..... _________________ Glenn
Member #1009
#BlueSquare |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Thu Apr 28, 2016 7:32 pm Post subject: Re: Fuel Filter? |
I think this tread has run it's course. I know Glenn has the "locked" thread power here and chooses not to lock it.
But my vote is lock it. Maybe Everett will lock it.
Seconds? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Harris Samba Member
Posted: Fri Apr 29, 2016 9:26 pm Post subject: Re: Fuel Filter? |
I apologize Glenn for my language and attitude. No excuse here. Always been a fan of your post.
Lou Harris |
nreslifer Samba Member
Posted: Sun Jan 01, 2017 10:08 am Post subject: Re: Fuel Filter? |
Who has a fuel filter and who doesn't and do the ones that just have the screen in the tank have any problems with only that? |
Posted: Sun Jan 01, 2017 10:37 am Post subject: Re: Fuel Filter? |
nreslifer wrote: |
That would all depend on how badly rusted your tank and metal fuel lines might be. Even with a filter you can have rust in carb problems. _________________ In Stereo, Where Available! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Jan 01, 2017 11:24 am Post subject: Re: Fuel Filter? |
To avoid that question sounding more like the prelude to another (inconclusive and needlessly rehashing and argumentative) poll, I'd offer this:
A: Folks who do a concourse restoration with all new lines and a clean tank likely do not need a third filter you reference (in addition to the two in the tank and the fuel pump).
B: Folks who have any part of their fuel system more than 30 years old or so have some form of corrosion in the tank and/or metal lines and are smart to run an easily serviced, additional filter- and service it/them often.
C: Folks who willingly do not service their tank or hard lines use an additional filter as a crutch to avoid real service on their vehicles.
I fit into the 'B' category.
There may be a "D" category- temporary use while flushing a tank or line. _________________
EverettB wrote: |
FU#5 |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Sun Jan 01, 2017 12:08 pm Post subject: Re: Fuel Filter? |
hitest wrote: |
There may be a "D" category- temporary use while flushing a tank or line. |
I agree, I'll go a step further and say I would probably remove the sock and just let the filter from the back of the tunnel do that job so it could be serviced. I have seen the sock so plugged up that using compressed air from the other side ( at the back of the pan ) to free the crud had the opposite effect and just blew the sock right off. besides the sock does not have the same filtering capacity of a good fuel filter ( micron wise it can let more debris through ). |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Jan 01, 2017 2:20 pm Post subject: Re: Fuel Filter? |
My 2 cents. Most of my cars and my customer cars have some or most of the original fuel system components. This means you have a tank and/or lines that are 40+ years old. There is rust and crud in them and its foolish to not use a proper filter rather than constantly tear apart a carb to clean it. The tank screen isnt enough.
Depending on the car and condition, I will run 1 to 3 filters. Since I will have replaced the soft fuel lines and usually the metal line to the fuel pump, 1 above the rear axle is usually adequate. IF I have replaced the main line thru the tunnel, then I may just use one under the tank. If the car has an electric fuel pump I will definitely run one before the pump.
In the case of "barn finds" or other cars that have been sitting for a very long time, and I have replaced the engine line and the soft lines, I will run 3. 1 under the tank to catch crap before it hits and possibly clogs the main line, 1 at the axle and a TEMPORARY one before the carb. _________________ D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Sun Jan 01, 2017 3:45 pm Post subject: Re: Fuel Filter? |
I have utilized the mini plastic filters for decades. It has been the primary choice of dealers and independents. Its locations have been debated here for as long as one can remember.
I as a young dealer tech back in the '70's obtained a '71 bay. Even as a young type 2 bus it had been sitting long enough to rust up the tanks inside. I installed two mini filters between the tank and engine thinking it would suffice, but during the most inopportune time would get restricted. Around '78 or '79 the dealer had a few totaled diesel Rabbits and I borrowed the diesel fuel filter brkt and its fittings and made this fit my bus with a new Bosch filter. Result- no more debris getting into the small places (needle inlet or idle jet). I may replace the filter every 5 years. Here I applied VW/Bosch technology to protect the diesel pump for my basic and daily driver needs.
Bill |
EVfun Samba Member
Posted: Sun Jan 01, 2017 5:17 pm Post subject: Re: Fuel Filter? |
hitest wrote: |
Aren't B and C the same thing? I'm running the tank sock and pump cone filter and a lot of 50 plus year old parts. _________________
Wildthings wrote: |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
kelleyspeed Samba Member
Joined: January 19, 2011 Posts: 80 Location: Surprise, Arizona
Posted: Tue Feb 07, 2017 10:58 pm Post subject: Re: Fuel Filter? |
Harris wrote: |
So Glenn who made it?
I have been going through the SAMBA looking for this guy. The bracket Glenn posted above is a copy of the brackets I build and sell. He actually bought one of mine and copied it. He added the whole goofy top part as well and now claims the idea as his. I just saw this and had to comment. I hope you figured out your fuel filter bracket. Take care.
Justin
lou |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
