I Ride Dirt Samba Member
Joined: August 16, 2014 Posts: 33 Location: The Badger Hole
Posted: Thu Feb 11, 2016 12:47 am Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
So its 2016, and I am getting ready to upgrade my rear brakes. I was looking at a set of rear disks and have come to the conclusion from by buddies rear disks that they are waaaaaaay heavy.. So I was looking into T3. I pull some of a cut up torsion 6 months ago, (I will have to load a couple pictures) and I have to measure them to make sure they are T3. However, when I was looking for T3 drums, Chirco doesn't sell them anymore.. Does anybody know where I could order 2? |
Dale M. Samba Member
Jem5649 Samba Member
Joined: August 29, 2014 Posts: 106 Location: Denver, CO
Posted: Sat Apr 30, 2016 1:56 pm Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
Hey guys... I just picked up my first Baja and need to fix the brakes in a bad way. I don't have a clue what direction to go. I want to stick to drums, but would type 3 be the way to go?
Anyways, any guidance would be great. I don't quite know where to go with this.
Thanks! _________________ I am a rock climber, not very mechanical...
1980 air cooled Westy named Beer... Yes you read that right! |
Brian Samba Moderator
Posted: Sat Apr 30, 2016 2:57 pm Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
Cool, thanks! I think I might already on T3s In the back. I'll take measurements once the snow melts tomorrow morning and get back on it. _________________ I am a rock climber, not very mechanical...
dustymojave Samba Member
Posted: Sat Apr 30, 2016 4:19 pm Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
I'm pretty sure from that photo I re-posted in your other thread that you have stock 65 Type 1 drums.
Type 3 drums are bigger and stronger and take offroad abuse better. Definitely a good choice for when you upgrade the suspension.
But you shouldn't have the long spline long axles installed that are necessary to fit the T3 drums. 68 Bug or Type 3 swingaxle shafts and outer housings or IRS are required to step up to the T3 drums. Your car almost certainly has short axle/short spline swingaxles typical of a 65 Bug.
Long spline long axles and housings can be installed in your 65 gearbox. It requires taking the trans out of the car for that. _________________ Richard
SoCalBajas Member
I Ride Sand Samba Member
Posted: Wed May 11, 2016 9:43 pm Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
just as a heads up, i have the EMPI cheapo $250ish disks and 100% recommend the type 3 drum setup. the disks have only marginally better braking, and they are HEAVY, poor quality and replacement parts are a PITA to locate. hell, they aren't even a bolt on affair. it took me several days to get them installed after machining the bearing caps and locating spacers for a kit that was meant for my trailing arms.
so, if you go disks, spend some real money and buy something good, or go type 3 drums |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Thu May 12, 2016 4:35 am Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
parking brakes. all VW parts. the choice of wide 5 or 4 lug. drums stay dry in wet weather. replacement parts.
nottalotta reasons to choose anything else. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Thu Feb 23, 2017 6:21 am Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
I am getting ready to do this swap to type 3 in the rear. As I a understand, all the bearings and spacers etc are the same as my type 1. Correct,yes?
The backing plate is larger, this must move the location of the brake cylinder slightly. Will my hard line to the brake cylinder still reach?
Thanks |
Posted: Thu Feb 23, 2017 7:23 am Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
dirtkeeper wrote: |
Thanks |
Correct...
Posted: Thu Jul 27, 2017 3:19 pm Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
Any difference in backing plates over the years? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Lowlightmafia Samba Member
Posted: Thu Nov 09, 2017 11:30 pm Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
[url]Hi, I’m building a 69 Ghia (track use mostly) and looking into type 3 drums or disc brakes for my rear brakes. Looking to run a 15*6 Fuchs with a 205 or 195 Tire (depending on how much clearance my rear fenders allow, since ghias are all slightly different). I know that this can be done with stock drum brakes and want to know if the rim to drum mounting point for the type 3 drums will be pushed out and push my wheels out? Also is it dangerous for my use to redrill type 3 drums for 5-130 porsche pattern? pretty much the same question but is there a rear disc brake kit out there that doesn’t effect the offset of the rim mounting point.
Check out my build, all knowledge helps, thank you https://www.thesamba.com/vw/forum/viewtopic.php?p=8608415#8608415 |
Posted: Fri Nov 10, 2017 3:28 am Post subject: Re: Rear Drum Brakes , comparing type 3 vs type 1 |
Type 3 drums Do move the mounting flange outboard a bit compared to type 1 brakes. I would NOT try to drill a 5x130 pattern in a wide 5 or 4x 112 drum or hub flange plate. You MIGHT be able to use Porsche 914-6 front rotors on rear hub flanges to get the result you are looking for. Or possibly VW bus 5-lug. _________________ Richard
SoCalBajas Member
