Ghia 1966 Samba Member
Posted: Mon May 02, 2016 12:08 am Post subject: Carburator problems ! Help |
This is my new buggy , no idea what engine is this since its code is not clear to me, have problems with carburator, need to buy new ones I guess but don't know what to buy exactly , any idea ?
_________________ - Split De luxe 1950
- Oval Ragtop 1956
- Karmann Ghia 1966 Convertible
- Bug 1970 Convertible |
drumbum68 Samba Member
Posted: Mon May 02, 2016 6:49 am Post subject: Re: Carburator problems ! Help |
Why do you assume you need new carbs? What is wrong with the pair on there? Looks like a vanagon digi jet ignition without vacuum hooked up. What do you know about the engine and buggy? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon May 02, 2016 6:53 am Post subject: Re: Carburator problems ! Help |
Best I can tell is you have dual Solex carbs... Might want to get part number off carb and see if you can get a couple of rebuild kits and spend afternoon learning about carburetors... If yoiu can get numbers of float chamber (they look like 11 40 4AEIS to me) and do Google search It may turn up a lot of information about carbs... For fact there is KADRON sticker on fan shroud (or whatever) suggest you also use the in your search criteria...You probably have a Kadron dual carb "kit" on engine...
From looks of things if you are going to replace or rebuild one you might as well do other one too....
jspbtown Samba Member
Posted: Mon May 02, 2016 7:16 am Post subject: Re: Carburator problems ! Help |
If you are uncomfortable with carb rebuilds then you can send them out. There are people who specialize in Kadron rebuilding. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Tue May 03, 2016 7:20 am Post subject: Re: Carburator problems ! Help |
Looks like air cleaners have never been serviced - plus carbs are leaking. Remove and mail them to me and I'll send you intake manifolds and a single OEM carb that will hook up to the vacuum port on the distributor.
Clean them, replace air filters and plug the vacuum line. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Tue May 03, 2016 7:56 am Post subject: Re: Carburator problems ! Help |
Solex Kadrons! Great, simple, single-barrel carburetors. Ran 'em on my bus for years. Have a set waiting in the wings to go on my buggy when it's ready.
Just one place that offers parts and service:
http://kaddieshack.com/ _________________ 1963 Manx copy
1968 Bus |
